Doepke made some that had a thumb wheel to rotate the crane.
Here is a pic that might help with routing the string.
by golly i think we got it right!
for your top servo mount, does it bend down then go to a standoff and bolt to the floor? Also how is the angle aluminum mounted at the floor?
The top mount is only attached at the rear. The bottom angle aluminum has a threaded hole and has one screw coming up from the bottom, towards the front. I made the assembly like a "wedge" and the two mounting points just secure the assembly. Remember that all of the drums only pull in one direction...
Cool you got it running.
It does look like you have the ropes routed properly.
#26
Many thanks to Stuff and Small Haul for the well documented conversions of these older toys. Any chance one of you might put a motor and driveline under one of the cranes?
Lynn |
#27
LOL everyone wants one of them. Scott is making a tracked one and i think im gonna just pull mine around for now lol. kinda expensive upgrade to it for it to move so little. Scott's tracked one is gonna use a separate rc gear for the tracks and i dont blame him. he would have to get one of those center things that lets you run the wires down and being servo that would 6 wires worth and not cheap to do!
#28
Also some info on those servos. Apparently it only has one metal gear... but it does have dual ball bearings.
Modulation: Analog Torque: 4.8V: 201.4 oz-in (14.50 kg-cm) 6.0V: 213.9 oz-in (15.40 kg-cm) Speed: 4.8V: 0.19 sec/60° 6.0V: 0.16 sec/60° not sure what speed works out to but it seems fast enough for me!
#29
them center "things" dean are called slip rings i have heard of ppl using ball bearing. i never try my self yet. just make shere you get steel ball's.
#30
whoops i ment centering things. but yea a metal ring would work to.
#31
this is what i plan to do for an extension of the boom. see how it goes out then back in for thickness? well at the unit crane's hinge point i want to add an extension like Scott did. should make loading trucks easier!
![]() also this crane is for sale on kijiji in alberta :P dont ask why i was looking that up lol
Rc's are like pringles. You can't have just one!! my YouTube is - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Subscribe!! My Facebook - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Stuff; 02-25-2011 at 01:35 PM. Reason: forgot pic lol |
#32
how much
#33
well so far the string arrived, and today the bucket and the magnet arrived. magnet is lame but it was dirt cheap.
![]() ![]() get a feeling how small this stuff is? ![]() another rant. why the h-e-double hockey sticks would you paint up brass parts and brass chain.. *facepalm*
Rc's are like pringles. You can't have just one!! my YouTube is - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Subscribe!! My Facebook - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Stuff; 03-08-2011 at 11:33 PM. |
#34
Anybody who would cut up a vintage toy, especially a crane, and power it up with RC stuff...is OK in my book! I love this stuff! Dan
#35
The way I see it, we are giving these toys a new life. Sure we might be changing and cutting them up, but for the greater good, not a scrap pile.
#36
...And as long as it's OUR toys, well, now they're better toys!
I have plans to power up this 1/25 crane eventually. ![]() ![]() It won't be self contained though. it will be mounted on a diorama, and the motors will be under the table. the upper unit will be fully functional, the tracks will be planted. I may build a truck type carrier chassis for it however. It too would be mounted to the dio. I did a similar convesion on an O scale (1/48) Northwest crane, smaller than this one. It was for a guy with an elaborate big bux model railroad. The crane worked well. I didn't have a digital camera then. |
#37
Ah, kinda like the demo that the coal mines have. its not wireless RC and they have a slot cut out that the cables follow along. Mind you I havent seen one since i was a kid but there has to be a dragline RC sitting in someone's garage or something that worked at the mines...
#38
So I got out to Mog's today again. Lucky bugger gets to go to Vegas monday for the big iron show.
got the vex gear kit in ![]() Got the bottom off the crane house ![]() not without a fight ![]() ![]() got the gear mounted ![]() ![]() ![]() Got it back together ![]() ![]() ![]() Time to play! ![]() Martin got a good bucket full! ![]() Filling the truck ![]() And that is a bout as far as we got before the radio started freaking out. then the bucket lift servo has seemed to stopped working.. gotta take a better look at it i guess. oh well next time!! gotta make Mog a good video to!
#39
Making some good headway on the project Dean, what's next to tackle?
#40
extending the boom and getting a good radio to use in it.
| Currently Active Users Viewing This Thread: 9 (0 members and 9 guests) | |
| Thread Tools | |
| Display Modes | |
