#161
I'm just dumbfounded by the level of detail and exactness of the parts you machine. I feel like a broken record because all I can keep saying is 'wow'! This is one of the neatest builds I have ever seen.
Nathan |
#162
Ari To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Hemi1966; 07-07-2011 at 05:15 AM. |
#163
I just can't design and build as fast as you do. So So NICE! You give many of us inspiration and ideas to build. Bravo!!
#164
Excellent, so smooth and powerful
![]() Great how all the functions fit together in the tight space ![]() Will be interesting to see how the steering feel is, if the stick position is proportional to steering speed and not steering position? |
#165
I am amazed at your engineering and building talent. Can't wait to see it all work together.
#166
I got the blade tilt cylinder done. That´s the last cylinder for now.
![]() I have to abort the build process for a while, because we are moving to new a house. I must start to pack my machine shop to boxes, not to mention all the rest of the house... Luckily I´m on my summer vacation ![]() ![]()
#167
Looks fantastic! great workmanship!
Kerst |
#168
Great looking model! You are working really fast!
#169
My trailer is slightly too short for the 14M
#170
Sounds like an new project, extending the trailer.
That grader is a very nice work of art IMHO. |
#171
Another impressive build!
You guys really know your ways. WOW!!! Great job. Cheers Pip |
#172
Hi guys, I´m finally able to get back to work with the grader after moving to a new house
What a job that was it took a while to get my "machine shop" up and running. First part I made was the front piece of the engine cover top.
#173
Unbelievable, Ari, Just Awesome!!!
I've never seen anything like this, Great Work, Mate ![]() Paul
Drive it like you stole it!! AKA Willsbrook |
#174
Fantastc model! Great job!
regards, Frank |
#175
Wow such an amazing build, would love to see some pics of your work place where you are creating this work of art. So when will you be mass producing the kits for these?
![]() Mike
#176
It's great to see you back to making progress on this fine project Ari... patiently awaiting further updates with great interest.
#177
I got the engine compartment bigger top piece done. The piece is curved half of it´s lenght, and I was not sure how it´s going to bend cause it´s 5 mm thick.
I did mill grooves in the underside in the area that should curve to help it bend. Then I band saw a wood block to the same curvature and place the aluminium piece between them. Next I put it to a hydraulic press and press the wood blocks together (plate between), but as I release the pressure the plate returned straight Then I decided to heat the aluminium plate hot and did the pressing again. I left it under pressure to cool down, and this time it did stay in correct shape![]() ![]() ![]() ![]()
#178
You don't need to make two dies. All you need is one. Take a piece of soft rubber or urethane (you can get different hardiness) Place the part on the rubber then ram the die. The rubber will conform to the die pressing the metal. This may take some practice on what hardness rubber but the end result will leave no marks on the aluminum piece. I have a long urethane die I use on my press brake that I bend painted aluminum sheet on and the die leaves no marks.
Here's a picture I found on the web of what I was describing.
#179
great work on the grader Ari, bravo on the heat
#180
STUNING JUST STUNING you are a model enginering god we are not worthy
| Currently Active Users Viewing This Thread: 10 (0 members and 10 guests) | |
| Thread Tools | |
| Display Modes | |
