Old 07-24-2011, 01:41 AM
pigeonfarmboy's Avatar
Default Re: Wedico 966G Build
Was able to work most of the day on the loader.
One question:
Is this where I should route the lift cylinder lines/Ts?
All the lines are run now, nothing connected to the valves or pump yet. Only a few more connections to make though!
Old 07-24-2011, 01:44 PM
Despite all the weaknesses I hear about these Wedico 966Gs, I still think they are great looking models. Everytime I see a picture of one freshly assembled, I want one, but it's a lot of money to fork over for model. Hope it'll be a good machine for you.
Old 07-24-2011, 02:36 PM
SmallHaul's Avatar
Those lines are routed the same as Jimmy's loader that I have worked on and they seem to be ok routed that way.
Make sure you use a good amount of loctite on the little screws that hold the wheels on the axles because they can work themselves loose. After having I wheel come loose, I pulled all of the wheels off of Jimmy's loader and used blue locitite on all of the wheel axle screws.
Scott
"No load is too Small"
Old 07-25-2011, 02:18 AM
Yeah I read many negative reviews on the WDC 966 but ultimately I chose it because of the level of detail it has over the Stahl. It's probably a better idea if you're heavily using a model to go with Stahl but time will tell with this one.
Old 07-26-2011, 12:03 AM
Izzy has a wedico and I have put a few hrs on it myself as well as a few others at shows and it seams to be holding up quite well. If I had the extra cash I would buy one as I have been real impressed with the reliability and looks of the machine.
Travis
Old 08-06-2011, 06:56 AM
Nobody told me I was going to need a shoe horn to get everything in this **** thing!!
Should be able to finish up tomorrow. Built til 5am today....guess that's good enough.
Old 08-06-2011, 10:22 PM
CustomRCmodels's Avatar
Originally Posted by SonoranWraith View Post
The robbe/futaba FC tray radios aren't sold in the US. Futaba used to sell the Fx40 ($3K US) but I have only seen the 14mz and 18mz of late.
The Robbe F-14 Navy version in 75mhz was sold since years here in the US ,
( around $ 250,- if I remember it correctly ? )
And before that you had the option to by the Robbe or Graupner tray-radios in 27mhz FM
Now since the 2.4Ghz systems , you can buy any European Radio and use it over here . I am a big fan myself of the Graupner and Robbe tray-radio-systems.
Besides the different options now of converting almost any FM radio to 2.4Ghz there are no real limitations anymore for us to use these tray-type multi-channel radio-systems
(Wild)-Willy
CustomRCmodels
Old 08-06-2011, 10:25 PM
Are the Wedico instructions now also in English or just in German ?
If you need some translations , let me know
(Wild)-Willy
CustomRCmodels
Old 08-06-2011, 10:54 PM
Izzy's Avatar
Izzy Izzy is offline
Backyard enginier
PFB - isn't great using tweezers to get to those tiny nuts and screws. The main issue I had with routing lines was the splice for the steering - mine are just under the main body area but just above the rear pivoting axle
Izzy
Old 08-07-2011, 04:57 AM
Got all the crap crammed into the model.....now let's see if it works!
The railings are just a pain in the ***. They should be attached way earlier in the manual. Like Joe said earlier. I spent more time on this model disassembling to fit parts, drilling holes out, and countersinking than I did building it possibly.
Old 08-07-2011, 04:58 AM
The manual is two-sided English/German. It's just the build sequence that is poor.
Old 08-07-2011, 08:41 AM
mgb mgb is offline
mgb is on a distinguished road
Great looking build this loader is very nice, now, is there video in the future
Old 08-08-2011, 02:53 AM
Yep, I'll definitely make videos. Gotta get it all setup for Indy first.
Old 08-10-2011, 05:33 AM
titandigs's Avatar
Aussie Fabricator
garden trucking do some nice wheel hubs to cover the bolt in the middle of the rims if you are interested
Old 08-10-2011, 12:12 PM
Ahh, they always look so good, when they are brand new, and freshly built! Nice looking machine.
Old 08-10-2011, 09:22 PM
Got em thanks! Just wanted to wait until testing in case I f'ed up and have to rip this thing apart.....again.
Old 08-14-2011, 08:13 AM
titandigs's Avatar
Aussie Fabricator
If you use the tape supplied they possibly will fall off as mine did, I found the 3M tape that you get with picture hanging plastic hooks is much better as none of mine have fallen off since using it.
Paul
Old 08-14-2011, 05:17 PM
How's the programming going?
Old 08-21-2011, 06:40 PM
Got it all hooked up and filled the oil. All the cylinders were operating ok, everything functioning as it should. I installed the cab and then tried to take a short video of it operating but the hydraulic system did not work. I packed it up and headed to the Indy show. When I got there Scott (RC Guy Farms) and Izzy helped me troubleshoot the issue. There was a pinched line coming out of the filter and I had my vent line running per the instructions hanging open below the rear axle. We got the lines run correctly and plugged and she was good to go. Ran the thing **** near all weekend. Works awesome! Will post some photos or video of some new goodies I got for it from Izzy!
Old 08-22-2011, 04:06 PM
D8R D8R is offline
Nice model, is decal supplied in kit or is it the normal way that c a t is forbidds to put those on?
Very nice tires, hope someday someone is doing bigger tires like that,
Dan
