#101
It's looking good Steve. What size Styrene are you using?
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Mike "DREAMWEAVER" Johnson To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. RIP FreddyGearDrive 2-12-59/12-19-11 Rims and Tanks by ihbuilder / Grill and Visor by Brian in PA / Mirrors, Front and Rear Bumper, Back of Cab Lights, and Steering Arms by tc1cat / Fenders by Stylin n Profilin / Frame Rails by The Late Freddy Gear Drive |
#102
thanks guys
@ Mike I'm using .100 A few more Pics with the sunset ![]() ![]() OH Rob the green bottle is the empty 1 :P
#103
That's the first thing I checked. Well done!!!!
Rob |
#104
Looking better all of the time
LYNN |
#105
I'll be up awhile
I waited a long time to do this milling out new frame rails for this beast not the best vid ![]() ![]() http://www.youtube.com/watch?v=XLyOWczx1DQ
#106
Nice work on the cab looks good can't wait to see this one haulin
#107
me too Henry
gota get it ready for winter for loading the coal hopper ![]() well my butt is draggin today finished up about 4 AM 8 hrs of cutting but then I kept my feed down I hate breaking EM's mid way through I tried to flip it over and do the inside this morning but the stock is a lil out of square + being tired I was running the wrong program oh well enough B.S. pics ![]() ![]() ![]() back to work
#108
Steve. You knocked that one, right out of the park, and there must have been quite a pile of chips on the floor. The frame on this truck looks like it will be rock solid and heavy duty.
![]() Rob |
#109
thanks Rob
I got the back milled out just off the mill 30 min ago ( I'm gona get some sleep ) everything went well till the drill cycle for some azz reason my holes are out .125" I should have waited and bored the 2 together manually ![]() the "I" profile ![]() looks like the verizon strike is effecting my I-net
#110
Nice work Steve....your skills amaze me.
Troy To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#111
Any pictures of your set up on the machine? |
#112
I'm not sure you can see it in this vid http://www.youtube.com/watch?v=XLyOWczx1DQ if not I'll take a pic when I do the other side or a trailer frame I'm going to set up . It's basically a fence that I can bolt the stock to .This trailer frame set might take a few days + igot to get more plate for the othe side
#113
For drilling, I draw points to generate the code .
#114
Looking good!! And everyone thinks that running a CNC mill or lathe is just push the go button and everything comes out OK
![]() Slowing down the feedrate is not that bad of a thing to do. Recommended feeds and speeds are not all what they are cracked up to be!!!
LYNN |
#115
yea I just looked it over clicked the circle not the point
![]() ![]() Quote:
I tried to tell my wife that now she gets it , I just never spent so much time at the puter then the machine I cut the recomended feed down by 30% seems to work well I just worked up the next op for those trailer frames with the other frame in it 12 hrs I'm thinking I need to find a water jet guy for the basic profiles
#116
"Any pictures of your set up on the machine?"
Steve , as I promised also this time I decided to use a bigger EM and crank the feed up also the spindle much better time ![]() ![]() ![]() more tomorrow
#117
well the 2nd frame fell out of the plate this morning about 3 am
#118
walking beams
![]() ![]() ![]() now these get chucked up in the lathe to turn the ends where the arch stops . there's a pic of it I just got to figure how to get it on here thanks for looking
#119
Hey Steve, are you going to chuck the walking beam's in your 4 jaw chuck? or use a dead center and lathe dog? Center drilling for the tail stock(live center) look's like fun.
Later, Neil#2 aka doodlebug. |
#120
Neil , yep alredy done
did them last night while I had the mill working on a jig plate for wheels . the old hendy need soom work , the handle where getting rusty ![]()
| Currently Active Users Viewing This Thread: 22 (0 members and 22 guests) | |
| Thread Tools | |
| Display Modes | |
