Old 09-29-2011, 02:30 PM
johnboyee johnboyee is offline
johnboyee is on a distinguished road
Default Re: CAT 14M Motor Grader
Kinda off/on topic, as I'm sitting here in my cab with the radio and a/c on, it jus hit me, it would probably be cheaper(not including cost of machine) to turn this machine into remote control, everything except throttle, and on/off runs through joysticks, a 14 channel radio would cover it! But I think that would be pretty awesome, but nit sure if it would fit in my garage!
Old 10-02-2011, 04:39 AM
Originally Posted by johnboyee View Post
Awesome job, I operate this beast everyday, just amazing the detail you done so far! If you decided, or had it all on paper, I would buy a set of plans!!
If you ever have camera with you, I would be grateful if you are able to take some photos of the machine, mainly on the back wall of the cab.
Old 10-02-2011, 01:04 PM
I'll grab some shots tomorrow and try to get them uploaded or sent to you, I want tonsay most of the stuff back there is A/C stuff, but no problem!
Old 10-02-2011, 01:40 PM
This build is insane! I can't get enough of it. The level of detail is so incredible. A true matster piece in the making. I have to agree that it will almost be a shame to paint and decal this machine up, as it is a work of art!
Old 10-03-2011, 12:25 PM
Back of cab shots[IMG]http://i1190.photobucket.com/albums/z451/Johnboyee/54184271.jpg[/IMG
Steps on newer blades
Light bar on newer ones
Old 10-03-2011, 12:29 PM
Best one didn't post first time
Also CAT went back to an I-beam front frame piece instead of tubular due to cracking issues ..
Old 10-03-2011, 02:02 PM
johnboyee, great pictures. Many thanks
Old 10-03-2011, 02:05 PM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Ari,
Do you know of a source for the step material that you used? Hopefully, on this side of the "pond"! Need some no matter where you got it from
Thanks in advance.
LYNN
Old 10-09-2011, 10:33 AM
Originally Posted by tc1cat View Post
Ari,
Thanks in advance.
I got it from here: http://www.fechtner-modellbau.de/sho...2006s002_1.htm
it´s the number 2639 on that page. I have no idea is it available on your side of the pond, but I´m sure you can get something similar there.
Old 10-09-2011, 10:41 AM
I made some details to the back of the cab, I will add some more hoses there.
Many thanks to johnboyee from the detailed pictures of the real machine
Old 10-09-2011, 08:57 PM
pugs pugs is offline
Just amazing.
Jeff
Old 10-10-2011, 03:45 AM
This is one amazing build, respect!
Old 10-10-2011, 04:56 PM
D8R D8R is offline
nice details, Ari.
Did send you a pm
Dan
Old 10-10-2011, 09:01 PM
RCTech9's Avatar
RCTech9 RCTech9 is offline
Great details! Cant wait to see this in action!
Old 10-11-2011, 01:51 PM
That's just takes the cake, great detail, glad I could help...
Old 10-23-2011, 06:05 AM
I started to decorate the cab
Old 10-23-2011, 08:03 AM
JensR JensR is offline
You are a crazy man!
Old 10-30-2011, 09:31 AM
I test fit the valve block and the pump to the grader, and they seems to go in wihtout any problems. I will add second valve block in front of the other and they go so low I can add pump over them and there still over 2 inch clearance to the hood.
Old 10-30-2011, 02:27 PM
steamer's Avatar
steamer steamer is offline
Ari, just a quick suggestion. Loosen the set screw that holds the motor to the the pump and turn it 180 degrees to the bottom. That way if there is any pump leakage it will drain out the hole and not gum up the motor. Thanks for showing us that just about anyone can build this caliber of model with just a small shop. Well Done.
Rob
Old 10-30-2011, 07:18 PM
I found myself starting from the beginning of your thread once more, today. I just can't over how much talent you have, to create a machine like this. We can't even call it a model because it's not. It's a true, functional, working machine, but on a smaller scale. Unbelievable! What a masterpiece. I think even some the best model builders on this site can't help but be humbled, when they view your thread!
