Old 06-06-2011, 11:49 PM
pumptech's Avatar
pumptech pumptech is offline
pumptech is on a distinguished road
Default My Bruder excavator w/screwdrives
Video of my bruder excavator working at the logpile,just need a thumb.
http://www.youtube.com/watch?v=t5gw5...el_video_title
Old 06-07-2011, 12:17 AM
Car5858's Avatar
Car5858 Car5858 is offline
Default Re: My Bruder excavator w/screwdrives
I could have sworn that some cowboy was in the cab.
Old 06-07-2011, 03:04 AM
That looks amazing, a thumb would make moving that stuff alot easier. The boom looks very solid and i love the lights mounted on the sides like that , i may have to get a set from you.
Old 06-07-2011, 07:41 AM
pumptech's Avatar
Thanks Car5858
It was a local guy in the cab,hired him on from labor finders
Old 06-07-2011, 07:50 AM
pumptech's Avatar
Thanks bigpipespete
Yea,a thumb would sure work nice with the loose material.
will see how it fairs ditch digging next time.
I found those lights at walmart in the automotive accessory section.12 volt led,2 per pack.
Old 06-14-2011, 08:48 PM
pumptech's Avatar
Made a stiff arm thumb for the excavator,only running 6 channels had to go this route,it works good.
Video with the thumb attachment
http://www.youtube.com/watch?v=bc7mr...el_video_title
Old 10-20-2011, 09:32 PM
pumptech's Avatar
Well,decided to make another boom for the Bruder,,like the servo further in the boom,seems to work better.Yea,thats a bucket pin from a real excavator for the counterweight on the door on my grill,last pic,LOL
Also uped the battery from 7.2/1800 mah to 3500 mah , running a Hitech 755mg servo in the boom.
Old 10-30-2011, 04:54 PM
carp carp is offline
Hey pumptech any chance you can show some close up pics of how you attached the servo to the track gears?
cheers
Old 11-01-2011, 08:18 PM
pumptech's Avatar
cheers
Here's a pic of the servo mounted.
Here's the build thread link at scale 4x4
http://www.scale4x4rc.org/forums/showthread.php?t=58009
Old 05-09-2013, 06:25 PM
pumptech's Avatar
Well ,figured I would update this old thread ,made a few vids here lately of the excavator.
http://www.youtube.com/watch?v=ARl6f...DgbNaA&index=4
http://www.youtube.com/watch?v=j28gnuh01WA
http://www.youtube.com/watch?v=6pHdGKJJ2x0
Vid of my old Hobby engine excavator
http://www.youtube.com/watch?v=NJjc4WR3H5w
Old 05-14-2013, 08:13 AM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
I'm trying to figure out the time line on your Bruder conversion. Is it about two years old now? Is it working good? Any maintenance issues or things you like or dislike?
Thanks,
Jim
Old 05-14-2013, 01:55 PM
pumptech's Avatar
Thanks,
Jim
Hey Jim ,I started this conversion ,January 2011 , during the beginning of the build/conversion was finding the right high torque metal gear servos ,using different torque ratings on parts of the build. Highest torque needed for the boom and stick .One dislike I had was in the beginning ,needed more lifting power at the boom ,decided to redo the main boom ,using a 1/4 scale hitech755 mg there ,has good lifting power now ,changed to a 2.4 ghz transmitter from the 72 mhz no glitches now !! Have had good luck with the servos ,havn't fried one yet ..As of now and last year or so ,not much maintenance issues ,just charge up the battery and go
Old 05-14-2013, 02:02 PM
Rvjimd's Avatar
Cool, just the sort of response and info I was looking for. Can you tell I'm thinking about a bruder conversion?
Jim
Old 05-14-2013, 04:22 PM
pumptech's Avatar
Jim
Kinda thought that ,good luck if you decide to convert one , forgot to metion ,when I overhauled the boom ,since I had it back apart I added a 6 wire slip ring ,link to follow
http://www.ebay.com/sch/i.html?_odkw...at=0&_from=R40
Old 05-25-2013, 02:05 PM
igotit igotit is offline
igotit is on a distinguished road
cant wait to see her running on that slip ring.
Old 05-26-2013, 11:11 PM
pumptech's Avatar
Hey Igotit ,slip ring has been in it for awhile now ,guess I should have taken a couple of pics showing installing it ,its the same as yours ,fun part was heat shrinking all the wires lol !! really don't see the use in filming it doing 360's for 5 min.lol!!
Will get some more vids up soon
Old 05-27-2013, 12:29 AM
im assuming it works well then...I was afraid 2 amp draw per wire would be enough on long travel trips.
glad to see its working out.
Old 09-02-2014, 06:53 PM
pumptech's Avatar
Well decided to put the bruder excavator back on the workbench, nothing was wrong with it still running fine, wanted to experiment with a new style boom.In the process of building a new boom based off a pic I found of a demolition excavator .Also building a new arm with a thumb attachment , still have a lot of work to do on it, have a couple of pics so far , will get a test vid up soon
File Type: jpg boom14.jpg (157 Bytes, 325 views)
Old 09-09-2014, 04:38 AM
What screw drives are you using?
Old 09-09-2014, 08:29 AM
pumptech's Avatar
I am using 1/4" masonary auger bits ,found at any hardware store ,wood auger bits will work also ,incased in 3/8" SST tubing with two set screws to travel in the valleys of the bit.
Here's my build thread over at scale 4x4 ,have tweaked it a little since then ,but basically still the same method.
http://www.scale4x4rc.org/forums/showthread.php?t=56870
Been working on the excavator a little here and there ,will get a update soon.
