Old 09-30-2011, 04:54 PM
Grainfarmer Grainfarmer is offline
Grainfarmer is on a distinguished road
Thumbs up electric "cylinders" fron CTI/Germany
Hi together!
I just found the following 12-Volts spindles from a small german supplier:
http://www.cti-modellbau.de/index.ph...dde2ac0c7efb9f
These parts are specially made for BRUDER conversions, but I´m sure they fit into other models, too.
The prices are inclusive the speed controller. No end limit switches are necassery...
The speed controller is programmed in that way, that it shuts off the motor when the spindle reaches the end position and the courrant strength exceeds a limited value. Great idea in my opinion...
Here are some examples:
http://www.cti-aichtal.de/movies/PICT0308MOV.MPG
http://www.cti-aichtal.de/movies/Bag...ideo%20006.avi
Hope you enjoy it...
regards
Frank
regards,
Frank
Old 09-30-2011, 07:59 PM
chaseracer's Avatar
Default Re: electric "cylinders" fron CTI/Germany
looks interesting
Old 09-30-2011, 09:27 PM
td9clyde td9clyde is offline
Dozer Builder
looks good wonder if those would work on my scraper???? lol
Old 10-01-2011, 03:21 AM
Under "details" you find dimensions and power...
They push about 45 N.
regards,
Frank
Old 10-01-2011, 10:43 AM
Dozer Builder
donno what 45 n is compared to psi or bar
Old 10-01-2011, 02:21 PM
...45 Newton....that makes 4,5 kilogramm....about 9,5 punds.
regards,
Frank
Old 10-01-2011, 04:08 PM
Dozer Builder
thank you for clearin that up don't sound like it has enough umpf for what i need
Old 10-08-2011, 02:19 PM
hauler_10-4 hauler_10-4 is offline
hauler_10-4 is on a distinguished road
Would like to try a set on my folding disc implement.
Old 10-25-2011, 09:08 AM
crawler07 crawler07 is offline
crawler07 is on a distinguished road
Has anyone one ordered any of these? I was thinking about ordering one for a dump truck..I just hate to get it and it not do what im looking for it to do. I guess I will have to get the dump bed built and work out the weight it will have to lift fully loaded to see if it will do as I need??
Old 10-25-2011, 03:49 PM
What are the dimensions of the dump bed?
With the power of about 10 pounds per cylinder it won´t be easy I think...
I also thought about using them for a folding field cultivator.
regards,
Frank
Old 10-25-2011, 09:54 PM
the bed dimensions will be 7" inch wide, 6" inch tall, and 14"long...is that 588 cubic inches??
it would be somewhere around 2 1/2 gallons which in fluid weighs 20 lbs..So if by using 2 cylinders doubles the power then 2 should do me fine..I suck at anything math related Im more right brain LOL..
Old 10-26-2011, 04:18 PM
That would make about 30 pounds of dry (!!) dirt...
I Guess that won´t work.
regards,
Frank
Old 10-26-2011, 04:48 PM
The cylinders on a dump bed do not have to suspend the entire weight of what's in the bed - a portion is supported at the bed pins and load just pivots around them. Depends on attachment point of the cylinders relative to the bed pivot pins, bed overhang at the rear, center of mass of actual load, etc.
These cylinders might well do the job, but many variables have to be considered to make that determination.
Old 10-30-2011, 09:24 AM
jimkidmotorsports jimkidmotorsports is offline
jimkidmotorsports is on a distinguished road
im building a bull dozer do you think these would work for the blade im a newbie here first build thanks they look like they will
Old 10-31-2011, 05:12 PM
Stuff's Avatar
Stuff Stuff is offline
those prices scare me but still interesting!
my YouTube is -
Subscribe!!
My Facebook -
Old 11-01-2011, 04:18 AM
I Guess to lift a dozer blade they will work. Maybe the supplier can give you more details...
regards,
Frank
Old 11-05-2011, 12:31 AM
what if I were to build the dump bed adn then use a spring scale to tip the bed with a full load of dirt in it wouldnt that tell my the weight it is lifting? I would attach the spring scale where the cylinder would attach...It seems like a simple way to figure it or am I missing smething??thanks
Rick..
Old 11-05-2011, 05:07 AM
That might help, but as Ken alredy mentioned above it depends also on some other details.
regards,
Frank
Old 12-10-2011, 08:48 PM
hay the website doesnt bring them up any more
Old 12-11-2011, 08:09 AM
andi4x4 andi4x4 is offline
andi4x4 is on a distinguished road
Try these:-
http://www.cti-modellbau.de/index.php/cat/c32_.html
No details listed though when you click on the details link
Andi
As I get older I find myself thinking about the hereafter - I go into a room and then wonder "what am I here after ? " !.
Isle of man - 70,000 alcoholics clinging to a rock in the middle of the Irish Sea !
Copyright ©2000 - 2026, Jelsoft Enterprises Ltd.
