Old 12-14-2011, 01:23 PM
Vanisle Vanisle is offline
Default Loader Tires
I am re-building a Hanomag loader and wanted some new tires. At first I thought I would use the RC4WD Mil-spec tires but they were just a little small. I then ordered some Michelin 29.5-5R25 loader rims from Liebherrmodelle.de (apparently run by the same people as AFVmodel):
http://www.liebherrmodelle.de/shop/p...-5R25-XLD.html
They are slightly larger at 137mm in diameter (versus 131mm for the Mil-Spec tires) and have a more proto-typical tread, at least for me because it is like the tread I used to see on log loaders when I worked wielding a chainsaw in the bush.
Here are some photos comparing the two:
You can order them hollow or full tire but even the hollow ones are significantly heavier than the RC4WD tires which is good if you want some weight in the tires. Liebherrmodelle.de have two versions of this tire on their website - this is the larger version. AFV only shows the smaller version (128mm diameter) on its website.
It took about 3 weeks for them to be made (I assume by Barnhausen) and another 3 weeks for shipping (due to a hold up in customs).
Richard
Old 12-16-2011, 01:29 AM
RCLogger's Avatar
RCLogger RCLogger is offline
Default Re: Loader Tires
WOW Great looking tires, the detail is outstanding.... You going to spin up some rims this weekend ?
greg
Old 12-16-2011, 11:38 AM
No, I decided to buy the rims (to save time and because they are steel so will have more weight) and just make the hubs. Unfortunately, they forgot to ship the rims with the tires so they will be awhile to get here. In the meantime I have been (slowly) working on a pump. I have an UMS pump I am converting to belt drive and am going to try to make my own gear pump with slightly larger gears than the UMS pump. All in good time.
Old 12-16-2011, 03:22 PM
Those have to be the most scale tire I have ever seen. Wow, they look good!
Old 12-17-2011, 11:02 AM
dsm4g63punk's Avatar
dsm4g63punk dsm4g63punk is offline
dsm4g63punk is on a distinguished road
Those tires sure look great.. Cant wait to see the rest of your build!
Old 12-17-2011, 02:26 PM
Here is a mock up photo with the Mil-Spec tires:
Since then I have completely torn the loader apart and sold the electrics, loader arms, side panels and screwdrives. Time to sneak back into the garage to work some more on the hydraulic pump/s. I don't know yet if my design will work but I hope to be able to test one in the next week or two.
Richard
Old 12-17-2011, 03:03 PM
chaseracer's Avatar
I like those tires Richard they look great very scale looking what size rim do they fit? . it will be cool to see your loader build in progress looking forward to it.
Old 12-17-2011, 03:43 PM
The Mil-Spec are 2.2 rims. The ones in the photo are ones that I made - I may just sell the rims/hubs/axle tubes/34rpm gear motors (but not the tires) that I made for my ADT (no progress since )if my design for my loader works out. Here is a photo:
The Michelin tires have a much smaller rim, approx 40mm diameter. Here are the ones I bought:
http://www.liebherrmodelle.de/shop/p...s2-1-14-5.html
Richard
Old 12-17-2011, 04:53 PM
The loader will look really cool with the new tires and wheels... but are you gonna hurry up and finish something soon so that we can get together and play or what?
Reg
Old 12-19-2011, 12:08 AM
Reg
It's not looking good for anytime soon. I'm sloooooow.
Old 01-09-2012, 12:50 PM
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler is on a distinguished road
any updates yet?
Old 01-09-2012, 05:35 PM
Originally Posted by SuperDutyScaler View Post
any updates yet?
Unfortunately, no. I received the loader rims and have some pieces laid out on my work bench to start the axles ... but it's gonna be awhile. I will do a post in the construction section when I make some progress but that could be many months away.
