#61
Rear support bolted to one side of the frame
#62
#63
Cylinder bracket added
#64
Do you work around a 24m? How did you get all this detail figured out? It looks awesome!
Jeff |
#65
Wow! This grader is amazing. Still trying to get my head around the size of it. The molded-in tire markings make them look real, rather than just large rounds of rubber. What are the dimensions of the tires?
Waiting to see all the pieces come together as a machine. Keep up the great work! Ken
Big iron is awesome! |
#66
Hey Pugs... I had never been around a 24 or even anywhere close to one or any grader for that matter. All the details of my design came from what I found in pictures and videos from the internet. I did a lot of research on this model to get it as close a possible to full scale. I still have a lot left to do.
#67
As for the tires... The diameter is 130.5mm (~5-1/8") x 54mm (~2-1/8") wide. The weight with the aluminum wheel and rubber is 751g (~26.5oz). Once I get the frame together I will give you a scale reference of some sort. |
#68
Front brackets...
#69
Assemblied...
#70
Attached to the frame without the center bracket...
#71
Very impressive build you are very talented person I cant wait to see more..
#72
i'm overwhelming in this site by all the talent people, just amazing.
kenny. |
#73
MPE, If you were to set a model shop truck along side all your parts, ready to make a pick, I'd be fooled into thinking you were assembling a full size grader. This is going to be a great model, hope to see it completed and at one of the West Coast Toy shows in the future. Fred
#74
Guess I should scrap my grader
![]() Sensational build! Will you do a diff lock? |
#75
How are the two outer plates joined to the center (3/4''plates?) Not the raised area around the flanges. I can't see if you bolted or pinned because the surface was sanded.
. Last edited by 9W Monighan; 01-05-2012 at 08:05 PM. |
#76
Thanks JensR. I am not adding a diff lock at this time.
#77
Well not really from one chunk. Actually the entire assembly has 5 parts and a lot of M2 screws. I had designed these parts so the screws are on the bottom so they would not be visible. Take a look...
#78
With center bracket
#79
next part added
#80
The complete assembly viewed from the bottom
| Thread Tools | |
| Display Modes | |
