Old 01-12-2012, 04:42 AM
Rebekah_harper Rebekah_harper is offline
Rebekah_harper is on a distinguished road
Default Liebherr R954C
hiya,
just thought I'd start my build thread for the R954.
I am building it for a friend as a fully hydraulic 1/14 scale machine.
Most parts I will be making my self other than the Hyd Pump and Hyd Rams.
the rest such as the Hyd motors for tracks and slew ring, Control valves and the slew joint are amongst those I will making in my shed of wonder and mistery.
it's a bit of a beast at around 16 Kg and a full length at stretch being just over 1000mm.
I will add the first pictrues on sunday.
Old 01-12-2012, 11:01 AM
Default Re: Liebherr R954C
Here are some pictures
Old 01-12-2012, 11:14 AM
Nice, looking forward to this!
Old 01-12-2012, 11:22 AM
jtroyer06 jtroyer06 is offline
jtroyer06 is on a distinguished road
I can't wait to see more of this build!!!
Old 01-12-2012, 04:10 PM
Cool, more scratch built excavators! I like it!
Reg
Old 01-12-2012, 04:54 PM
pumptech's Avatar
pumptech pumptech is offline
pumptech is on a distinguished road
Nice start,looking forward to this !!
Old 01-23-2012, 03:36 PM
Just a little more done.
Time is spent more on angles and making sure they are spot in.
Old 01-23-2012, 03:41 PM
Pippoe Pippoe is offline
Pippoe is on a distinguished road
Thumbs up Re: Liebherr R954C
A huge project and challenge!
Good luck. There's somebody building a 954 in a German forum too.
Impressive. This is going to be a beast.
Cheers
Pip
Old 01-23-2012, 11:12 PM
Thank you. At 1/14 it's on the large side. But it's going to be fully hydraulic. I think I've seen the German build. Is it with electric tracks?
Old 01-24-2012, 10:06 PM
dirtpusher9's Avatar
Moderator
Wow, this is going to be a monster. I read that you were going to make the hydraulic motors and valves. I'd like to see that step by step as I would like to build my own. Great start on the build.
Old 01-26-2012, 02:10 PM
Hi there!
I think the German build has electric tracks, planetary drives with brushless outrunners. There's a picture on the last page of the thread.
How do you plan to get the hydraulic oil from the upper to the lower section of the excavator?
Cheers
Pip
Old 01-26-2012, 02:29 PM
The transfer from body to undercarriage is done via a slew joint.
Alot of the the new parts are going to be made as the original.
Its long to explain but it's the easiest part out of the 3 hyd components I'm making. I'll post pictures when I have completed it. But it's a barrel system.
Bex
Old 01-28-2012, 06:35 AM
Hiya,
Here you can see how the hydraulic components are being made.
Hyd motor, valve block and slew joint
Here is the barrel for the axial hyd motor.
Old 01-28-2012, 01:12 PM
HMM, Pistachio nuts, graph paper,pencils. This build is getting interesting.
Oh, I forgot to mention shop built cigarettes too.
Old 01-30-2012, 02:29 PM
All key components to successfully building a R954C lol
Old 01-30-2012, 05:10 PM
JensR JensR is offline
May I ask why you are going for an axial piston motor and not radial?
Axial machines typically have considerably higher RPMs than radial ones for a given power and hence lower torque on the shaft - are you using a gear between motor and chain wheel?
Old 01-30-2012, 07:03 PM
Yeah I'm using a reduction gear box like in the real final drive.
Old 01-31-2012, 10:36 PM
great work so far . I'll be watching the hyd. motor build my dad has a hydash pulled appart for 1 of our koerings 6605 excavators , I've been tempted to build some mini 1's . It'll be a few years yet till I get all the equipment aquired unless I get a brain storm
Old 02-22-2012, 03:32 PM
Just a little update:
The axial piston motor now has one piston.
It does look wonky but that's because it's right on the end of it.
Old 02-22-2012, 04:55 PM
Rebekah , you are a genius . I've been trying to figure out how to do the ball on the end of the piston . Thats a great idea
