Old 10-12-2011, 12:10 PM
Brel's Avatar
Brel Brel is offline
Default ServoNaut M220
Does any one know anything about the ServoNaut M220 and the ServoNaut MBA hydraulic pump controler and the ServoNaut SMT sound module
or will the ServoNaut SMT and ServoNaut MBA work with the ServoNaut M220
because I have a Stahl/leimbach hybrid loading shovel and am getting rather teed off with having to turn the hydraulic pump on and off and draining the battery if I dont turn the fifth channel off
Old 10-12-2011, 12:37 PM
Default Re: ServoNaut M220
What kind of radio are you using? Does it have atleast two mixes within its tx programming?
The "Master" is the valve & the "Slave" is the pump. And you need to have the pump on an esc too. Might work with a relay switch too, but the esc will have softer start/stops of the pump & you don't always need full power for every movement -> which will help conserve run time too.
I've done this with my adt & 850 hoe, works really well! I have a yt vid of the adt that shows how well it works.
Much less expense, as well as much less junk inside the model too.
Old 10-12-2011, 04:44 PM
Brel's Avatar
Lil Giants,
I am using a basic Planet T5 2.4 Gig radio with 5 channels, the pump is controlled from the fifth channel via a switch, the tracks are being driven via a Novak M2 Dig Dual Brush ESC that is set up to drive eack track independantly and uses the left stick forward and back for throttle and the right stick L/R for steering, i.e. the same set up as a Tamiya tank
is it possible to just use the servonaut BMA to run the pump and not bother with the SMT and M220 module
Old 10-12-2011, 06:10 PM
Brel's Avatar
Lil Giants Thanks for you help I have got it sorted via another site and have decided to buy the servonaut BMA and not the SMT or M220 module becase the Novak duel esc runs fine
Old 10-12-2011, 06:26 PM
JensR JensR is offline
Yes, the BMA can be used alone.
Check the wiring diagram:
http://www.servonaut.de/shop/product...naut-bma.html&
You can see that the connection between BMA and ESC is for communicating the sound (blue plug).
I assume you don't speak German, but here's the manual:
http://www.servonaut.de/shop/media/p...1295627987.pdf
Old 10-12-2011, 07:17 PM
Brel's Avatar
thanks JensR
you are correct I dont speak german but the wiring diagram is very helpfull
I have printed the manual and will ask one of the european guys at work if they can translate it for me
Old 10-18-2011, 02:08 PM
Brel's Avatar
I decide to just buy the ServoNaut BMA module and run the laoder with the novak Dig dual esc
the BMA module arrived about 3pm and an hour later was fitted to the dozer and tested and it is fab, no more turning the fifth channel on and off
Loader stripped down prior to fitting the Servonaut BMA module
fitting BMA module
Planet reciever
BMA module down the L/H side of the oil tank and the reciever above it
quick run outside
video of the tracked loader being tested on the kitchen floor
about half way I bring the TX into shot to show that the pump is being turnd off by the BMA module and not the fifth channel on the Planet TX, the Nine volt PP3 battery is for the lights fitted to the loaders cab, the rotating beacon is hard wired into the loaders main running batery to indicate that it is either switched on or off
Old 10-20-2011, 03:15 AM
I like how you lengthen the tracks, how much longer are they over stock? I bet it's much better balanced & improved traction too? Got a build thread somewhere showing your changes in detail?
Old 10-20-2011, 07:07 AM
Brel's Avatar
I hate to disappoint you Lil Giants, but I did not build the tracked loader, so there is no build thread from me.
I bought it ready built from a guy called Jo Smith in the UK via the http://www.rc-trucking.com/ forum, he sold it to me with an esc to control the pump via the fifth channel and a small German dual esc to run the tracks, that I burnt out in five minutes.
As far as I know the machine is a Stahl model with the bucket from their wheeled loader, the pump and Hydraulics are Leimbach. other than that I do not know any more about it
over the last few months I have been experimenting with several dual esc's and eventually settled on a Novak M2 Dig Dual Brushed ESC and this last week the pump esc with the Servonaut BMA pump controller, which I have now set to turn the pump off in 1.5 seconds after the sticks have been centred, I even tried a Tamiya DMD unit to try and drive the tracks but it was too big also tried a sabre tooth dual esc but the steering in reverse was reversed so went with the Novak
as far as I know the tracks are the stock length and I have had to do a temporary repair to one of the because a couple of E clips have come out and I am waiting for new ones ( put some m3 bolts in as a temporary measure).
here is a picture in as bought condition
Jens, Thanks for the translation on the Scal4x4 forum
Old 10-20-2011, 10:38 AM
It seems to be a hybrid:
- body from the tracked loader
- under carriage from the dozer
- arms/ bucket from the Cat 966
Pretty cool and unique.
Old 10-20-2011, 06:39 PM
Brel's Avatar
it would seem to be that way, but it has got better to run after installing the ServoNaut MBA pump module, with the leimbach pump and tank in the machine
Old 10-21-2011, 02:41 AM
Well darn the luck! I broke my golden rule to not ever sell anything & gave away my 966...
After it was gone, I was thinking I should have made a wheeled dozer from it... and then I would have had the loader arms & bucket for this conversion.
Your track loader looks similar to Scale Art's Cat with its long tracks. That's probably all I have to do to improve the perfromance of my ten yr old Stahl.
I'll have to call the new owner my 966 to have him fab me a duplicate set of arms.
I was thinking thru the summer about getting a Scale Art Cat 963, but now I think I will just improve the Stahl model I have. Thank you for the pics Brel.
Old 10-21-2011, 03:09 PM
Brel's Avatar
Lil Giants there are some more pictures here http://s231.photobucket.com/albums/e...ding%20shovel/ that I took as I was replacing one of the drive motors and one of the servos because they had gone up in the blue smoke of electrical failure
Old 03-20-2012, 06:11 AM
Brel's Avatar
I have replace the Dual novak M2 dig esc with a Servonaut M220
Old 03-26-2012, 06:34 PM
Mitch Mitch is offline
Mitch is on a distinguished road
To change SMX settings, follow this procedure:
- power off
- remove the jumper on SMX A-B-C (remember the correct setting)
- power on radio and SMX, and wait for a short "air pressure" sound
There are now 5 settings, each with 4 options. Use the "truck horn" switch of your radio to change options, and the "engine start" switch of your radio to move on to the next setting. You just have to listen to the SMX, it plays each sound option, the current setting and every change. You can change the options as often as you like.
Just play with it.
Settings and options are:
1. Volume of the "air pressure" sounds, 4 options - lowest volume means off, no sound at all (For example, wheel loaders don't have a air pressure brake, so you might want to turn this off)
2. Volume of the "back up" sound, 4 options - lowest volume means off, no sound at all
3. Type and volume of the "switch gear" sounds, 4 options (S20 don't support this. But M20+ does)
4. Volume of the "turbo charger" sound, 4 options - lowest volume means off, no sound at all
5. Truck horns, 4 options - choose the horn you like best
After step 5 choosing the horn, use the "engine start" switch again. The SMX will now play the german firefighter sound and save your settings. If you remove power before that, changes will not be saved. So when you are confused - switch power off and start again.
When everything is OK and saved, remove power and re-insert the jumper on A-B or B-C.
Mitch
Old 03-26-2012, 06:36 PM
M220 :
> Battery and motor should be no problem.
> Connect the yellow wires to the right motor.
> Connect the blue wires to the left motor.
> Look at the option table and find the correct jumper setting for
> your battery (A B C).
> Turn you M220 around and set (X) or remove ( ) the small black
> option jumpers A B C accordingly.
> Connect the upper cable "Driving" with blue servo plug into the up/
> down receiver channel you want to use for driving.
> Connect the lower cable "Steering" with black servo plug into the
> left/right receiver channel of the same stick, important!
> (you might change this after setup/programming)
> Connect the brake and rev. lights, you need them later on for
> programming.
> M220 programming :
> Turn off the M220.
> Turn on the radio.
> Hold the stick in the lower left position.
> Now turn on the M220. It will blink 3 times.
> Move the stick to the upper right position and wait. The M220 will
> blink 1x.
> Release the stick to the middle and wait. The M220 will blink 1x.
> Move the stick up. The M220 will blink and is ready.
> You only need to do this once. You might repeat it if necessary.
> Now move the stick carefully forward. The model should drive
> forward, otherwise swap the connections at the motor.
Mitch
Old 03-27-2012, 12:28 AM
Brel's Avatar
thanks for the information mitch
Old 05-21-2017, 09:16 PM
TonyB TonyB is offline
TonyB is on a distinguished road
Guys can some one show me the correct wiring diagram for the reverse lights and brake lights to program the m220. I can only fluke getting either steering 100% or forward 100% one at a time. I need both not just one.
Old 05-22-2017, 01:49 AM
Rakthi's Avatar
Rakthi Rakthi is offline
Here link to PDF of the manual, wiring diagram page 8 & 9
German/English version.
http://www.servonaut.de/shop/media/p...kfd9orlha53i95
