Old 04-13-2012, 07:05 AM
Default Re: 990 cat loader
Originally Posted by pugs View Post
Looking good Steve.
Research parametric programming (subroutines and loop calls) could probably do all them holes in a program a dozen lines of code long assuming your control can do subs, loops, and variables.
Looks like should be a fun toy soon.
I haven't got there yet it's not that old according to my age it's a cent 6 control prob. 1st gen there's so much to learn yet . I hope so (soon ) I've been trying to get some construction equip going for awhile now . life just gets in the way more times then not
Old 04-13-2012, 08:09 AM
steamer's Avatar
steamer steamer is offline
Loaders looking real good Steve. Just think if you had to drill all those holes by hand it would have taken three weeks.
Rob
Old 04-13-2012, 08:34 AM
Vanisle Vanisle is offline
Wow, that's pretty impressive. When I see how much work goes into a project, I feel less bad about not making time on my own stuff. I like those holes but I would hate to do them manually with a DRO.
Old 04-13-2012, 11:36 AM
RCLogger's Avatar
RCLogger RCLogger is offline
Keep up the grreat work Steve, it is going to be able to move some serious material. Alot of pump in there...
greg
Old 04-13-2012, 01:50 PM
td9clyde td9clyde is offline
Dozer Builder
awsome job on ur loader keep up the great work
Old 04-13-2012, 05:55 PM
thanks guys I just checked the specs on my motor 2HP at 24v @94.5 in/lbs of torque with out the planetary gear box which brings it to 550 in/lbs of torque . It draws 2.6 amp no load , 68 amp nominal , and 190 amp stall . But I'm only running 12v on it . Soo , now how to figure the esc just get the 1 rated for the motor specs @24v to be safe ? Or could I get away with a lower rating / 12v is all I'll ever need in power on this thing It can fill the bucket going straight into a pile of pea coal like nothing on 12v. Pea coal is about the size of scale R8 and up rock which is more then expected for this machine to handle . I was told I'd be fine with a 1/10 cc sidewinder sv2 but I just want to make sure . I'm still green when it comes too electric motors . I might do my cab in brass as I got some of that laying around .
I'm gettin antsy , I'll actually have a piece of equipment running via RC
Old 04-13-2012, 06:11 PM
Higher voltage means lower amperage.
Old 04-13-2012, 06:13 PM
Hey Steve, do you have any way to measure motor amp's? Maybe an inline fuse on the drive motor lead's? Car stereo one's should be big enough (battery cable version)
Can't wait to see video!
Cheer's, Neil.
Old 04-14-2012, 09:02 AM
bigTdozer bigTdozer is offline
bigTdozer is on a distinguished road
What ring and pinion gears are you using?
Old 04-14-2012, 10:48 AM
Digital multi-meters work good for current draw readings. You just put them into the circuit, in series, with whatever you want to get a measurement on. Or you get a clamp on meter that can do DC amps.
http://www3.towerhobbies.com/cgi-bin...&I=LXLMV0&P=ML
I also bought a Watt's Up meter. It also goes in series with your load. Pretty cool little device, but I haven't used it much. Kind of a neat little toy to play with. Just to see what kind of load your motors are drawing. It also monitors battery voltage too at the same time.
Old 04-14-2012, 03:00 PM
Interesting! Look's like "big bang for the buck!" thank's for sharing that.
Cheer's, Neil.
Old 04-14-2012, 03:44 PM
cabrover's Avatar
cabrover cabrover is offline
cabrover is on a distinguished road
Looking great Steve!!I will be watching this project!!!
Tim
Old 04-14-2012, 07:57 PM
RCTech9's Avatar
RCTech9 RCTech9 is offline
Cant wait to see it moving dirt! The front of the Cab looks spot on!
RIP FGD 12-19-11
Old 04-15-2012, 06:24 AM
D8R D8R is offline
Always nice to see those big loaders. This one is coming together very nice, looking forward to the rest of it.
Dan
Old 04-20-2012, 06:46 PM
well I'm going to sping for the big esc for this and run it on 24v I got the room for the batteries yet meanwhile , I got some robbe valves from Richard with the pumps . Of course I didn't like the why they go together + It seems you need end pieces also for the ein /aus ( supply and return ) Well , I made a new base ( now lets see how long it sits till I get taps ) arhh , must have a bur on the vice now I gotta plane the 1 side again we'll see how these hold up :confussed: I may find some ci bar to remake the alumminum parts . I'm not to keen on steel on aluminum
Robbe valve
new base block
well thats it for now , vice comes off , set up for next parts run
Old 04-20-2012, 06:55 PM
That block looks great.
Old 04-20-2012, 07:56 PM
pugs pugs is offline
Nice looking work. You got cnc, get a couple threadmills
Jeff
Old 04-20-2012, 07:59 PM
Hey didn't I just assemble that yesterday? Looks good!
Reg
Old 04-20-2012, 08:00 PM
can you get them for 2mm ? I know you can for 5mm
" Hey didn't I just assemble that yesterday? Looks good! "
LOL
Old 04-20-2012, 08:33 PM
Oh yeah, that small might be tough to find. I pretty much only use them for over 1/2", all pipe threads and specials. Makes the best sealing pipe threads
Jeff
