#41
Kent, you did a great job on the sanding! Barely any filler, which is very good. The less you use, the better, and more stable the body work will be. What's next?
Nathan |
#42
Kent the roof came up well its got a nice shape to it, cant wait to see more now the hard part is done...
RIP FreddyGearDrive 2-12-59/12-19-11 Love my Kenworths To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#43
The hard work looks to be paying off, nice profile!
#44
I still have to fabricate the driveline and then paint every thing. We'll get there a little at a time.Thanks for the support Michael!
#45
Nice build this is a different type log truck can't really say I have seen one quite like it before great job on the cab work look great so far can't wait to see the final truck when done.
#46
Well I worked on getting the truck presentable for this months Build of the Month, Build in Progress, posted the pictures and then realized I was entry #11 ![]() . So I'll post them here and keep working on it.![]() ![]() ![]() Thanks for looking! |
#47
Wow your build is fantastic! Your headache racks looks perfect!! did you use a dremel to file down any excess solder or did you sand it? Can turned out good! cant with to see more!
#48
Thanks dabears, yes and yes, I used both dremel and sanding. One thing I learned was using very small diameter solder for electrical wiring and a water soluable flux is great with virtually no clean up needed. It holds fine for something like this.
#49
Holy cow, Kent, your truck looks really sweet. I like the headache rack too! Did you get it chromed or something? Or is it just reflecting the chrome plating from the deck plates? The cab roof turned out super nice. This is one of the nicest Knight Hauler builds I've seen on the forum.
Nathan |
#50
Your right that combo works perfect! I got my stack rack built yesterday! Thanks fir the tip
#51
The racks got 2 coats of Dupi-Color metal etching primer, 2-3 coats automotive primer and about 4 coats of Dupli-Color chrome paint. I still have some work to do on the roof before final paint.![]() ![]() Quote:
#52
Its on my thread of my truck "Stretched Globeliner"
#53
Chrome in a can? Wow. That's a really good finish, for being a spray paint! Thanks for sharing Kent.
Nathan |
#54
God this thing has really turned into a work of art. I'm surprised how well rattle can paint can look so much like real chrome!
Never judge a man until you have walked a mile in his shoes. Then, when you judge him, you are a mile away and you have his shoes! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#55
Thanks Swagger, I was actually surprised how far chrome in a can has come!
#56
Just like the can says perfect match ,awesome build on this rig ,look forward to seeing how you do the cab detail.
#57
Awsome rattle can finish. Looks realalistic without too much shine.
#58
Yes its the best I've found to date! |
#59
Decided to go to PFB'S House meet Memorial weekend to meet everybody and didn't want to go without something to drive so Friday morning I started with the chassis and axles. The cab had one color, light blue. I taped and sprayed the dark blue then went to work taking the radio gear and motor out of my Axial Scorpion. Built the chassis up, installed the electronics, untaped and dressed the cab. About 10:30 pm I decided it was as far as it was going to get and packed up to head off at 5 am. Had a great time! Now I get to reverse the process and actually finish the project (after I get my daughter through graduation).
Picked up and HPI 1:7 GRU and a 55T motor/crawler esc combo which should be here Monday. Still haven't got a radio but I'll run the Axial pistol grip for a while. ![]() ![]() The truck hooked to Dabears 53' flat bed, can you say L O N G! ![]() ![]() I've got to thank Dabears and YoungGunz for the pictures of my truck on the forum I took pictures of everything else but mine! ![]() ![]() ![]()
#60
I can send you the others I have later if you want?
| Currently Active Users Viewing This Thread: 15 (0 members and 15 guests) | |
| Thread Tools | |
| Display Modes | |
