#141
.I have the top center-center right but the bottom is too short . Looks like a new to be made the 1 I have is too short . It was the only part that was distorted from what I had to go by .
#142
thou shalt not jest I doo know where to get that size tire BUT I have a few projects to finish 1st + a few in line ![]() took a little break before pulling the vise(make shift indexer ) off the mill . milled up the steering cylinder bosses . I used the step block and clamp to hold my 0 position .![]() ![]() ![]() Oh thanks again Mario new 1scaled to your measurements ![]() old on new
#143
Doesn't take you long to carve out parts anymore Steve.. must be a great level of satisfaction to do things quickly & correctly, eh?
#144
I love learning new things before 3 years ago I never touched a mill in my life except for looking at them at the salvage yard / liquidater . I can't wait to get this going I also got 1 of my micro pumps figured out . to put in the pan the Jung is just to big for it (very little space ) So If my cylinders work out I'll be making up the 1's for the pan and dozer sometime after indy .
#145
My pleasure Steve. Glad I could help with the Z arm. Looks good! Can't wait to see her running!
#146
Gidday Steve.
Hey Mate, can't offer any advise though I can add to the list of many readers who have praised you on your efforts. What a fantastic looking model and to see it comming together is a trip in itself. Totally impressed of what can be made with the "Can Do Attitude" Can imagine what the guys that work on or operate this machine would be thinking. Awsome craftmanship Steve. Shane. |
#147
Seeing as I can't , I like to try and help people like him get the info he needs to continue his work of art....and thats what this machine is.... a work of art! Mario |
#148
Thanks Mario
, Shane well we made it to Z bar #4 and what a !@#$ it was al the way Guess thats what I get for staying up till 4 in the AM a week ago gettin it right turns out the loader arms where too small too So remade them too and thanks too having a tig the whole loader arm assmb. got welded together I still want to clean up the weld a lil better in the mill . I couldn't resist a lil paint on it either . made my Y's the old way drill press hand mill (file) and vise doo too both mills being setup for other ops . nuff BS here's some pics ![]() ![]() ![]() ![]() ![]() ![]() I want to clean up my bucket a little more with the tig so gotta sand blast it . Pool noodle did the trick on the tires
#149
Wow, Steve, that looks great!
#150
thanks Rob
![]() ALMOST ![]() ![]() gotta figgure the mixing on the radidio and change out a leaky robbie valve head the tolorences on these things are pathetic , must be +/- .01 with a little tinkering you can get them to work right , except for the 1 where it leaked right out the rotor stem . they should be a running fit with no sidw to side play . I got bucket and steering werkin just waitin on the slow lathe guy to get my new rams for the lift cylinders done
#151
werking!!!
![]() ![]() ![]() figured out the mixing just alittle reading of the manual pump is on my aux1(flaps)chl . I got the steering so that when you activate the steer servo the pump runs about 50% to werk the boom/bucket put the pump switch in mid position for about 50% for guts , switch in 3rd pos. As for the valves , they're like a HD gotta tweek them when they're new and after so many mi /hrs ![]()
#152
Way to go Steve, it can be quite frustrating I know. It makes it all worth it when it comes alive though. WOOHOO Now video please!!!!
You are an inspiration to many To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , you will not be forgotten. R.I.P. FGD Work Hard, Play Hard! Never Forget- 343 |
#153
will do Ben In the pea gravel too
#154
Man Steve that looks great!!! youve done an awesome job with it so far!
#155
thanks Aaron
to answer Mario's ? from the trailer build . I was digging pea gravel well except for the mixing thing with the radio . the pump would always go down to the steering settings and wouldn't have the hair to pick up a full bucket . So I just put the pump full on or full off then moved the coal pile twice till I blew the clipard cylinder I used for steering well It was leaking right off the bat but desided to leak alot more no vid will get 1 soon I hope right now I'm trying to make new steer cylinders and my own spool type valve . I hate these robbies it's not the style I hate just the tolerances are piss poor . you tighten them to eliminate the bypassing then you can't turn them . I had brass bushings (not oil lite )that I made for my axle shafts while waiting for bearings , well they started to sieze up so in went the bearings . easiest set of axles I worked on to date not to mention tough as carbide , so to speak
#156
Thanks for the update Steve, very nice of you..........oooops, have I struck a cord of frustration? Hydraulics causing grief ?... Welcome to my world of fixing....not building
there is no doubt you will figure it out. Can't wait to see more!....... Mario |
#157
Wow that model is built like a tank! Great build keep it up!!!
#158
. I'll get a vid up someday I gotta figure out how to take 1 on the new cam I'm may start painting it soon .Quote:
#159
it is cool when the equipment starts moving and twitching makes it fun and frusterating but it is worth it nice work steve........Izzy and Travis helped me on the D 7 but it is in peices right now ......a later story.... Can't wait to see a video and have fun digging and loading trucks
#160
thanks henry I tinkered on after I ran it last night made a few small things that I could do while waiting to change parts on the mill . I got another 30 mins in tonight . 1st night with no leaks
![]() and 20 bar . I still got little odds and ends like better linkages for the valves to see If I can get better control . vid is uploading verrrryyyyy ssssssllllllllloooooowwwwwwwlllllllllllllllyyyyyyy
| Currently Active Users Viewing This Thread: 25 (0 members and 25 guests) | |
| Thread Tools | |
| Display Modes | |
