| Farm Tractors and Implements Discussion of farm equipment |
#41
Here are a few detailed pic up close too to show what is where.
![]() ![]() ![]() ![]() ![]() And to show the full interior still in tact. ![]() ![]() ![]() Hope you guys enjoy the pics to hold you over for a bit. I sure know it's a big relief to finally say it's mechanically complete. I can't wait to get it out and dirty soon and hopefully have a few attachments for the rear. Tyler
~Tyler~
RockSolidCustoms |
#42
Wow. It sure cleaned up nicely! The chassis is all powder coated now? Looks like a perfect match. I see you upgraded the axles too. Nice. Do you put the battery behind the grille? That looks like the only place it could go. Great to see a complete engine and cab interior yet!
Nathan |
#43
Hey Nathan the chassis is actually a new model chassis as I couldn't get the origional one powdercoated to match very well so I went back Ertl. Axles are now aluminum and mount up great with only two new holes drilled in the tubes to fit. The battery does sit in front of the radiator and I'm trying to find a better place to hide it so there will be nothing to see whenver it is on display. Space is a major concern now as to fit the rest of the lighting system in there and to stash the battery. If anyone knows where I could find a smaller lipo that would be great.
Tyler
~Tyler~
RockSolidCustoms |
#44
Tyler, What Batt pack are ya using now?
sdjb |
#45
Video Time!!! Got a few mins while it was nice out this evening to take the tractor out on its maiden voyage. It has a small radio glitch which I'm not sure whats causing it but here is a short clip of what it runs like.
![]() Thanks for looking and watching and hope you enjoy. Tyler
~Tyler~
RockSolidCustoms |
#46
Spent a little time this evening working on the tractor. I've started to add some small details that the standard model fell short of. So far I have added step grip strips and soldered up some grab rails and handles. I'll let the pics do the talking of what I have completed thus far.
Before pics: ![]() ![]() ![]() ![]() ![]() And here are some of the after shots. ![]() ![]() ![]() ![]() ![]() I have some more finishing touches to do on the bars to clean them up but I'm getting closer to a finished product. Next on the to do list besides adding the rest of the lights and redoing the rears are as follows. Add hydraulic connections to the rear Add extra details to the engine and compartment Have moving steering wheel Movable wipers? Make new intakes out of aluminum for realistic look Build new exhaust stack and muffler out of metal Add auxiliary air tanks to the right front frame rail And eventually hook up electronics and mounts for a front blade. Hope you guys like the progress and lemme know what you think. Tyler
~Tyler~
RockSolidCustoms |
#47
Nice work on the detail touches. The hand rails looks great, as do the anti-skid steps.
Nathan |
#48
Well it's time for another update for the weekend. I finally got my new led's in the mail and started to wire this big guy up. It took several hours last night and a few today but it is currently all wired and running. Here are some pics of the process and what it looks like now with all the new lights.
Here is my starting point. ![]() Now for the start of the wiring harnesses for the separate lights. ![]() ![]() ![]() ![]() Here's the process I started for making the headlights in the grill. ![]() ![]() Thats all I took of the process of making them for the night.
~Tyler~
RockSolidCustoms |
#49
Here are some shots from today with the lights switched on. I have the run directly from the battery and can simply switch them on and off from inside the cab under the seat if I wan't to run them at night or leave them off during the day.
A few shots from inside the garage. ![]() ![]() And now for the lights!!! ![]() ![]() And lastly here are a few shots from its first outside debut with some of the details added to it. ![]() ![]() Hope you guys enjoy the new pics and I also hope to have some more progress done on it soon. Tyler
~Tyler~
RockSolidCustoms |
#50
P.S. I almost forgot to add a few teasers of what I took a little time on last night.
Hope you enjoy. ![]() ![]() ![]() Thanks for looking and hope to hear feedback on it. Tyler
~Tyler~
RockSolidCustoms |
#51
Great conversion! Nice details...
regards, Frank |
#52
Gotta luv those led light's!
Cheer's, Neil. |
#53
that is spectacular awesome job on build and the detail work is perfect. The rims and tires are sick as well as the lighting. i only wish i could be this good at building so for now i gotta just buy when and if there available. that goes in one of the best tractor builds book for me!! the ford is a great pick. the wireing job looks perfect just a great job!!!
Grabbin gears and Rollin wheels ! LETS BLOW SMOKE!! Member of the Central Plains Mini Truckers,and a Minnesota road hammer. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Flat bedders do it with chains and straps,but now im yanking 53's To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Diesel Demond; 04-22-2012 at 09:04 AM. Reason: wrong word correction |
#54
Thanks for the compliment. There are still more to come.
Thanks Neil, it took me a bit to find the right color to match what a halogen light looks like but I think these lights do the job. Quote:
Hope to have some more updates or you guys soon. Tyler
~Tyler~
RockSolidCustoms |
#55
That's awesome. I'm a huge fan of the working lights. I like that you used warm white LEDs instead of the cool whites. Yeah, cool whites are brighter, but warm white is more accurate for a tractor of this era. Nice work with the wiring. I'm the same way. I try to make things as clean as possible! Pretty fancy air cleaner!
Nathan |
#56
the grab rails, lights and air cleaner add a great amount of detail - great work!
#57
Your tractor looks great, I had my doubts early on, just not much room for all the stuff that needs to go in there. You did a very nice job for sure!
#58
Hi Tyler
Looks good was thinking of doing a similar thing for my first non kit build so to speak. What make is the model as in the UK i can only find plastic toys form Bruder and would perfere the meatl chasis that you have. many thanks Mark |
#59
Tyler
~Tyler~
RockSolidCustoms |
#60
Time for a little bit of new progress from this evening. I finally got time again to fiddle with the tractor and so far I've got the rear hydraulic hook ups on the tractor almost buttoned up and got the valve box on the scraper built and the lines to attach to the tractor.
![]() ![]() ![]() ![]() All that is left on the scraper is cleaning up the styrene work on the front and shooting it with some matching blue paint. I hope to be able to get the rest of the back hydraulic hook up finished tomorrow and possibly get a video showing the tractor and scraper doing a little work before paint. A few small things left like mounting the hood for easy battery access and finishing up the air cleaner and making new intake hoses to the turbo on the engine and this little guy will be a roller once again hopefully. Thanks for looking and plan to have some more shots and details for you guys tomorrow afternoon. Tyler
~Tyler~
RockSolidCustoms |
| Tags |
| conversion, ertl, ford, progress, tractor |
| Currently Active Users Viewing This Thread: 13 (0 members and 13 guests) | |
| Thread Tools | |
| Display Modes | |
