Old 06-01-2012, 04:52 PM
Default Re: PFB's Vario JD 850D
I forgot all about this idea.. as much trouble as I am having with the track drives & getting it around, I gotta make myself set too!
Looking forward to seeing how your's turn out.
Old 06-01-2012, 11:08 PM
doodlebug's Avatar
Way to go Nathan, I'd forgotten all about them.
Cheer's, Neil.
Old 06-02-2012, 06:50 AM
Madda Madda is offline
Madda is an unknown quantity at this point
Oh that's great machine! Put some more videos now, I could watch these for hours. These builds here make me want to build one for myself altough I got to finish my last build.
How wide are these tracks?
Old 06-03-2012, 12:38 AM
pigeonfarmboy's Avatar
2.5" wide
Old 06-11-2012, 02:13 AM
Both cradles welded up. Just waiting on wheels/tires now. Believe this will be my first project to make use of the lathe!
Old 07-01-2012, 04:10 PM
Braved the heat last night/this morning to some work on the dollies.
After some brain-storming with Izzy and Trav I used the RCP Crawlers TLT Straight Axle Adapters and cut off the ears. Cut down they offer the perfect spacing for the tire/wheel from the side plate of the dolly.
Cut up a washer for work holding and space for the drill
Had to turn the taper for the inside of the washer. (Zinc machines like sh*t) Here it is all mounted up to the dolly. A TLT axle fits inside and I'm using the tamiya brass bushings.
The 2.2 ZXLs I ordered are way too big. Might go with the 1.9s. (the 2.2s are just going to have to be used on a future build..... )
Spacing. I may take a bit more off the TLT adapter so it sits closer to the plate.
This has been a good project to learn the ways around my new Taig machines. That machining class definitely helped me troubleshoot obstacles in clamping and indicating parts for better precision. I've never used a rotary table or 4-jaw chuck before. It's time consuming to setup, but it's a great sense of accomplishment for me knowing how to quickly and easily set them up now. Time to let my ideas and drawings become real objects! Very excited.
Old 07-01-2012, 04:31 PM
Good job Nate.
Old 07-02-2012, 09:34 AM
dabears's Avatar
dabears dabears is offline
Looks good Nate!
Old 07-03-2012, 12:56 AM
I could use a seet of them too, if you're game to make another?
Looking good so far.
Are the tires solid rubber? Or are you packing them solid?
Old 07-06-2012, 01:33 AM
Not sure on the tires, hopefully they'll hold some weight stock. Otherwise I'll stuff more foam or plastic bbs in them.
I can make you a set, it'll be after Indy though.
Old 07-11-2012, 08:11 PM
Went with studs into the plate (When a full-scale CAT engineer says so, you do it )
Capture washer and hub installed
Fast forward they are just about done. Just waiting on one TG10 axle to arrive to finish the second. Cables are installed and I ended up having to stuff the tires with really dense strips of foam until full.
Old 07-11-2012, 08:38 PM
woodhog's Avatar
woodhog woodhog is offline
If you made those wheels i need a set for my 544j ive been working on converting
Old 07-11-2012, 08:40 PM
woodhog's Avatar
also you have a lot of shavings next to those nice bikes
Old 07-11-2012, 11:27 PM
Nope, those are RC4WD they make them in 2.2 and 1.9
Whole garage is dirty. The bikes don't have a chance at keeping clean between sparks flying from the rally car or rc builds.
Old 07-12-2012, 10:06 PM
The track dollies look good, your a mad man Nate.
Old 07-12-2012, 10:26 PM
Izzy's Avatar
Izzy Izzy is offline
Backyard enginier
Awesome work PFB - they are looking great!
Old 07-13-2012, 01:33 AM
Great success! Just a few tweaks and these are good to go!
http://www.youtube.com/watch?v=p84DrfttK4g
Old 07-13-2012, 03:33 AM
Grainfarmer Grainfarmer is offline
Grainfarmer is on a distinguished road
Looks great!
regards,
Frank
Old 07-13-2012, 04:03 AM
RCTech9's Avatar
RCTech9 RCTech9 is offline
RCTech9 is on a distinguished road
Good job PFB! Now you need to build a truck to use to move it with.
RIP FGD 12-19-11
Old 07-13-2012, 12:26 PM
doodlebug's Avatar
A little bit of Aerosmith & Walk this way!
Look's great, nice job
Cheer's, Neil.
Copyright ©2000 - 2026, Jelsoft Enterprises Ltd.
