#161
first vid will not up load
but here's 1 to show the speed ranges . you can tell which front tire has BB's in it and which does not need to get another 8500 BB's I need to retake a vid of it moving pea gravel . might put the Mack in it too ![]() http://youtu.be/PgxZjzE0MRQ
#162
Well Steve it is coming along nicely glad to see it moving it looks real good. Ed
#163
Wow, Very nice work. Lots of hours at the mill im sure.
#164
thanks much Ed ![]() thanks Kaf well a little set back need to remake the front I had issues with the z link then once I got the right dimensions for that I also got the right boom , cylinder dimensions . I thought I could get away with just remaking the boom but now I can't get the bucket flat on the ground I could add extensions to the boom frame work to bring the boom pivot point up , BUT that'll look like poo . Soooooooooo , re-cut time but in steel not to worried about weight
#165
Oakydoaky finally goy a vid of this baby diggin
![]() ![]() ![]() now I'm not use to usin a raidio to operate . Also the valves are going to take some gettin use to . But I'm slowly getting the bugs werked out of er ![]() I'm going through battery quick on the pump . but thats because the radio not set up right yet . I gotta go through a 100+ pages to figure what I'm doin wrong http://www.youtube.com/watch?v=v4OKB...ature=youtu.be some pics of the new front from plate to assembly ![]() ![]() ![]() since these are in the pics I'll show them I just couldn't resist with the mill being idle for a couple days been gettin antsy seeing a 374 and the start of a 390 soooo here's the in betweeners ![]() ![]() ![]() ![]() ![]() been planning for almost a year on them . ![]() ![]() ![]() ![]() 1 will have a mass stick and the other will have no stick but something in it's place ![]() thanks for looking
#166
F in A Cotton... F in A....
Nice job Steve! All these excavators being built right now is making me want to build another one myself! I only wish I could build with that level of quality. Reg |
#167
Thanks Reg , you do a fine job your self . I got that VMC to help with the parts I make for ppl , if it wasn't for that , I'd be building the same way you are with manual machines . I spent some stick time today with the loader . A lot of the probs I have is the transition from real machine control to the radio . I'm gettin it though . no vids though
I gotta fig. why the h3!! it takes so long to upload anything anymore
#168
) it would probably help a fair bit.Keep up the good work! Reg |
#169
As you all know , I haven't been happy with the tires available to us
. Sooo I've been doodling in Acad for a bit this is what I came up with . ![]() I already got the mold halves drawn but vismill will not load them up for some reason might be way to complex for a cheap cam program Or I got to upgrade to pro ![]() ![]() I'm going to make some kind of home made injection molder still trying to werk it out in my head werse case I'll just pour them like Tom did with his triple 7 ![]() Back to werk
#170
I cant wait to see how those turn out!!
#171
I just emailed you regarding the moldings!
"If you build it, they will come" East Coast Mini Truckers To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#172
#173
green and red tires!!!!!!!!!!!!!!! only you would have that lmfao!!!!!!!!!!!!!
Specializing in VW beetle water pumps! RIP FREDDYGEARDRIVE |
#174
#175
then thay would match your bra and panties!!!!!!!!!!!!
#176
I didn't think Steve wore those. Commando!
#177
YA GET MY STUFF SHIPPED YET ??????????
BESIDE you really shouldn't talk about what you like to ware on the open INTERNET ![]() ![]() ![]()
#178
didn't make indy or nat. pike shows so I spent a few hrs movin packed sand and #57 gravel mix . the remnants from pouring my shop floor a couple years ago . no vids
I attached all the teeth 1st , boy this thing can dig . 1st pic shows the reason for the 12 lbs counter weight has at least that in the bucket . I hope to get some primer this week when I go out for appointments . I'm just reluctant to tear it down to paint like the mack they work ![]() ![]()
#179
Looking good working Steve.
![]() It's going to be a beast.![]() ![]() ![]() Big John
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. YOU WANTED THE BEST AND YOU GOT THE BEST THE HOTTEST BAND IN THE WORLD...KISS!!!! |
#180
Steve the loaders lookin great. The tires however are looking just a little on the squishy side of the spectrum with that 24lb load on them.
Tyler
~Tyler~
RockSolidCustoms |
| Currently Active Users Viewing This Thread: 11 (0 members and 11 guests) | |
| Thread Tools | |
| Display Modes | |
