Old 10-14-2012, 01:30 PM
Tamiya Cowboy's Avatar
Talking Tracy Reiks 1978 A Model KW. "GETTING THERE"
Well for those of you that like to play spot the project in my pictures here is one that I have been slowly working on the last 2 years and now it has my full attention. Good friend of mines 78 A Model going to try to copy it as much as I can I always have to change some minor things but that is it..
Here is a pick of the truck I am copying..
Not going to bore everyone with a step by step of how to do a frame so here it is..
Ok rolling chassis.
Parts List:
Russ's 4 bag air ride
Russ's Cross Members
Russ's Hanger Bearing Cross Member
My Custom Rear Bumpers By Russ
Russ's Tank Hangers
Custom Profile Fuel Tanks By Russ
Steves Sweet Rims and Air Clears and Texas Blank
Travis's KWhopper Gril
Jon's Big 8's..
The rest I am making my self..So here is a good starting point. Got my .80 plastic on the roof so I can round the roofs more.
Air Ride.
Cross members
Rear Bumper and Taper
Steve's wheels and Texas Blank
Ok roofs rounded and stacks mounted. Notice how the stacks sit up to the sleeper like they should and not over hang the door.
This is why I make this plate that bolts to the stock mount holes and pushes the stack back to where it should be. This has also been done on the snow truck and the black and red Pete.
Ok many have ask about my 5th wheel plates and the little bar sticking out the side well this is how I do it instead of the set up tamiya uses that is not scale looking by any means
Now here is something I would change normally is the tread plate I would go polished stainless but went with the PMD plate and rolled the edge of it to match the frame.
Then tranny mounted and I made my custom drive shafts like I do..
If you Notice in the picks I have used the new scale bolts from RC4WD every where you can see a screw I wish I could put these on all my finished trucks but that would mean alot of repainting but they are great looking..
Ok poser shots as I am waiting on a few parts plus I am building some and I have some still to mount that will take some body work so check back..
Paul W. "Tamiya Cowboy"
Old 10-14-2012, 01:38 PM
dabears's Avatar
dabears dabears is offline
Default Re: Tracy Reiks 1978 A Model KW.
Man Paul another sweet looking build!!! Loving it already!!! Looks awesome!
Old 10-14-2012, 02:41 PM
rockNmayhem's Avatar
Paul the truck is looking great. Keep it up. Can't wait to see some paint on it.
Tyler
~Tyler~
RockSolidCustoms
Old 10-14-2012, 04:39 PM
Claus's Avatar
Claus Claus is offline
And it's the right color to boot!
Old 10-14-2012, 05:43 PM
sandfarmer's Avatar
sandfarmer sandfarmer is offline
sandfarmer is on a distinguished road
This looks really nice! The wheels set if off for me and it really has a clean look.
Had a low battery glitch (I think) pop a yoke on a driveshaft today, I have the u-joints like yours so where's the best place to get those? May need some spares looks like...
Old 10-14-2012, 07:38 PM
1985 kenworth's Avatar
yes man keep the pics coming.that is clever how you did the fifth wheel pull on the fifth wheel i like that looks more realistic and the rounded bunk top is the way it should look for the a-model kw's
dwayne
Old 10-14-2012, 07:44 PM
dmess62's Avatar
dmess62 dmess62 is offline
dmess62 is on a distinguished road
Looking good Paul. How do you lower the sleeper to match upn with the of the cab? I like how you moved the stacks back, I noticed that on your other truck.
Keep up the good work, and pics
Thanks for looking. All comments, suggestions, and constructive criticism are appreciated.
Dave
Old 10-14-2012, 08:57 PM
plow jockey's Avatar
Paul you nailed it!!Thats a great idea with the stacks and 5th wheel.Great work on the styrene.Cant wait to see some paint on it.Great job!!!
One is too many and a million is not enough. Fred.
Old 10-14-2012, 09:14 PM
Diesel Demond's Avatar
that red is gonna make that truck just pop. great selection for doing a copy of a 1:1 truck. another one were it cant be built fast enough for me
Old 10-14-2012, 10:40 PM
Thanks much Aaron.
Tyler
Thanks Tyler
Thanks Claus Red is my favorite color too..
These are RC4WD heavy plastic shafts I have not heard of them breaking but there is always a first they are on there web-sight and then I mod them with the stainless tubing and make them longer.
Thanks much I fireguard for sure you would notice the little changes that make a big difference in the look.. on that 5th wheel mod I forgot to say that the brass rod is bent in a loop with a brass washer braised on to it then it is screwed to the 5th. Keep a eye out I have some more detail you will like..
Originally Posted by dmess62 View Post
Looking good Paul. How do you lower the sleeper to match up with the of the cab? I like how you moved the stacks back, I noticed that on your other truck.
Thanks much dmess.. on the sleeper I cut 3/8 of a inch out above the rain channel around the sleeper just above the rivets then I glue it all back together.
Thanks much Fred..
Thanks Cory..
Originally Posted by oztruck View Post
Looking good Paul. Nice to see a Kenny build. Keep the photos coming.
Thanks much Chris..
Thanks for all the great comments guys I have been working on it more today so maybe some picks Monday night..
Old 10-14-2012, 10:48 PM
Goose19's Avatar
Goose19 Goose19 is offline
Goose19 is on a distinguished road
love the ol' kw TC!!!
where do you get the scale bolts? might need those for my next one!
Old 10-14-2012, 10:55 PM
Thanks much Goose the bolts are at RC4WD.com is where you can get them.
Old 10-15-2012, 01:16 AM
russisloud's Avatar
Very nice Mr.Paul
Old 10-15-2012, 10:14 PM
gun's Avatar
gun gun is offline
HillBilly Home Boyeee. WAZZZUP!
gun is on a distinguished road
The truck is looking good and with the color your going with it should look right at home with my 70 Wilson cow taxi !!!! Now get back to work and post us some pics.
SHANE... Member of the Central Plains Mini Truckers..
Old 10-16-2012, 08:29 AM
Kaf343's Avatar
Kaf343 Kaf343 is offline
Very nice looking Paul, I love the stack mounts and rolled edge plates. Very nice. Can't wait to see more.
Old 10-16-2012, 11:50 AM
MACK Daddy's Avatar
what size rc4wd bolts did ya use Paul? 3mm?
Alfy
Old 10-16-2012, 09:07 PM
Originally Posted by russisloud View Post
Very nice Mr.Paul
Thanks much Russ
LoL you are right it will good thing I got one too..
Thanks much Keith..
Alfy
They are 3mm just like all the stock screws and I bought all the lengths they make so i am not wasting a long screw where i don't need it.
Old 10-16-2012, 10:53 PM
Ok been working on the tuff stuff last few days.. Cutting these door handles in is no fun it all but I got 2 in the sleeper done but have to sink them in a bit more but they are close..
And I got the passenger side mirror built and mounted using the stock holes in the cab screwed in from the back side..
what do you think??
Old 10-16-2012, 11:00 PM
dabears's Avatar
I really like those mirror mounts!!! The door handles look great! Cant wait to see whats next!
Old 10-17-2012, 12:21 AM
BRICKNICK's Avatar
I'm wondering where u got the door handles from? And those mirrors are awesome. Nice work tc.
