Go Back   RC Truck and Construction > RC Truck's Kings of the Road > Australian Rigs & Roadtrains
Australian Rigs & Roadtrains A place for aussies to show off their unique truck configurations.
Old 09-30-2012, 07:27 AM
Marcel74 Marcel74 is offline
Marcel74 is on a distinguished road
Default Re: Scania W.A. Prime Mover 1/14.5
Thank you
Next, i need 22 Mudguards . am making this probably made ​​of cast resin.
Old 09-30-2012, 09:05 AM
Great detail and it looks just like the real thing!! Well done, I hope I can get my two scanias to this level.
Old 09-30-2012, 11:08 AM
dabears's Avatar
dabears dabears is offline
Those trailers are prob the best ones ive seen yet!
Old 09-30-2012, 10:16 PM
Claus's Avatar
Claus Claus is offline
Beautiful build! Great attention to details.
Old 09-30-2012, 11:33 PM
This build is really nice. Not many Wedicos around this forum, but yours is one of the best. I like the details and effort you put into making this truck turn out so great. The lights are awesome, and the trailers look really nice, even if they aren't finished yet. Keep it up.
Old 10-01-2012, 05:16 PM
crawler07 crawler07 is offline
crawler07 is on a distinguished road
wow all your details are so clean. i will take notes on those tire carriers for sure, as im about to build one for my dump truck..
Old 10-01-2012, 06:31 PM
rappy's Avatar
rappy rappy is offline
rappy is on a distinguished road
love the trailers very nice indeed
Old 10-02-2012, 01:16 AM
Still amazed with your modelling. Have you got any more information on the fabrication of those trailers? There an amazing example of modelling.
Old 10-02-2012, 01:20 AM
Claus's Avatar
Are you happy with the Veroma transmission and it's ratios? I'm currently building a Wedico Peterbilt with the aluminum 3 speed, dual Buhler motors and a PMD 4:1 reduction. I'm very happy with the speeds but not very happy with the transmission or the combination box, both have weaknesses.
Old 10-06-2012, 12:36 AM
JoseFL10-4's Avatar
JoseFL10-4 JoseFL10-4 is offline
JoseFL10-4 is on a distinguished road
VERY NICE AND CLEAN JOB, AWESOME
Old 10-06-2012, 09:41 AM
Thank you
The Trailers Cargoarea lenght are 525mm and 945mm and the Wide is 172mm.
I built the Chassie from a 2mm L-Profil with 5mm brass holder. At the Trailers front i built a 6mm aluminum plate for the Kingpin. The Wheels are from Leimbach and the landing legs are from Schulztec.
Im happy with it, the ratio is good. Some have problems with the Second Speed but my transmission is ok. I don't need a combination box, because the Motor have enough power .
Old 10-06-2012, 03:06 PM
Claus's Avatar
I wasn't very clear, it's the Wedico transmission I had problems with. Was thinking about using the Veroma but went with the RC Channel transmission for now. Thank you for your reply.
Keep up the build, looks great!
Old 10-20-2012, 05:40 AM
for the Mudguards I turned myself a suitable aluminum tube that this is in compliance with the original "plastic Mudguards". After the pipe was cut in half, there were still glued aluminum statements.
Comparison blank and Cast Resin.
I need 22 pieces for the trailer.
On the trailer it looks like.
Old 10-20-2012, 06:02 AM
Claus's Avatar
Great work on the fenders, they look fantastic.
Old 10-20-2012, 10:06 PM
VERY NICE!!!! I need some of those too. What was the other website that you posted this build? It had some great photos and information but I lost the web link. Thanks Andrew. BTW Im building a van road train using the tamiya kit. Starting to look good thanks to your good ideas.
Old 10-22-2012, 01:36 AM
Thanks
Originally Posted by oztruck View Post
Can you tell me about the landing gear? Is it powered?
Is from schulztec and is powered by Faulhaber motor. I order not the normaly lenght, is a little bit shorter. Is very expensiv, but they have a lot of power.
http://schulztec.de/shop/catalog/pro...products_id=28
Sorry, is in 1:14,5 Scale . It is on the Modelltruck website (is in german), here is the link to the post.
http://www.modelltruck.net/showthrea...der-Road-Train
Old 10-23-2012, 01:11 AM
well my german is very rusty so google translate to my rescue.
Thanks for the link, again its a amazing model
Old 06-10-2013, 01:04 AM
Straywolf's Avatar
Originally Posted by Marcel74 View Post
Hello Mini Truckers
Danke you for the Messages.
I buy a normaly Wedico Kit in 2007
After 3 Yaers construction, is this the result.
Frame is from Wedico and my self, with Osswald and Wedico Spring also tuned (original to high). The Power Train is with a 82 Watt Faulhaber Engine and a 3-Shift Gearbox from Veroma.
The Fuel tank i make with 1mm Alu, inside is a 5 pack Battery from Orion with 5100mAh on each side.
Behind is the charing socket for the Battery
Inside the Toolbox is the Electrical rearpanel from Wedico
The Fender are from Wedico and is modifed by me. The Holders i made of Brass
This is the 1. Part, next Part will follow soon
Thank's Marcel
In the third picture where did you find your hex bolts and nut's at, if i may ask? Your build look's really great!!
Mike
Old 07-16-2013, 10:28 AM
Hi Mike
Thanks, the hex bolts and nut's are from Knupfer (Germany)
http://www.knupfershop.de/shop/
Old 10-10-2013, 10:47 PM
Burnt Rubber Burnt Rubber is offline
Burnt Rubber is on a distinguished road
Nice
