Old 10-22-2012, 10:01 PM
Default Re: 990 cat loader (Earl Shiebbed)
thanks Dan , No it'll get a more rigorous test sit right here It would've made it through the STL weekend if some dummy had put a filter on it
I had the elements sittin on the bench for weeks just never got around to making the canister After gettin settled back in today I spent an hour or 2 making it up tonight .
Old 10-22-2012, 11:13 PM
Supermario's Avatar
Really Steve? Running without a filtration system? the 990 is a tough machine but, not that tough
How long did it run before big trouble? Scale it up and probably as long as the real thing would last with no filters
Thanks for posting pics from the meet...by the way....looks like I need to send ya a new CAT hat for Xmas.
Mario
Old 10-22-2012, 11:17 PM
actually it ran 40 hrs before the break down Yea I forgot to pick 1 up when I was at the dealer for a battery for the 247B and my paint always in a hurry
Old 10-23-2012, 08:48 PM
Supermario's Avatar
So 40 hrs X 14th scale = 560 hrs? . nahhhhh, the old girl would last longer than that!
Bet ya can't get one at the dealer with a Canadian maple leaf on it!
I'll get ya one. You are now on my Xmas list
Mario
Old 10-23-2012, 08:59 PM
well it turns out the valves are the culprit I knew it would happen steel wearing on aluminum with piss poor tolerances . at least the filter will catch the particles till I get my valves finished . I also turned the pump around so the belt is at the back of the machine as opposed to between the main motor and pump motor . should be easier to change the belt now . No , no maple leaf on our hats here .
Old 10-24-2012, 05:09 PM
o-rings came in after lunch for the filter . so I took a few min and put oil in an gave er a go back in bizz now will not get a vid till this wknd in the rubber pit I'll have to tie up 75% of it's HP just to make it look like I'm workin it hard
Old 10-24-2012, 07:08 PM
Supermario's Avatar
Glad to hear she's back up and running. You must have brought it to a CAT dealer to get such a quick repair time
Mario
Old 11-18-2012, 10:34 PM
lil bit of me time today
got the front fenders and light post fabed up . they came out much better in brass then aluminium welded I may mill out my own lights . these look like poo
Old 11-19-2012, 09:49 AM
Snochaser's Avatar
Aww look at those cute Lil' mudflaps, precious. lol
, you will not be forgotten.
R.I.P. FGD
Work Hard, Play Hard!
Never Forget- 343
Old 01-27-2013, 04:29 PM
I was in the possible future 1300 SQ ft quarry cleaning up broken block this morning . I'm getting ready to build a rather large dbl fireplace with bread oven base . When we built the house in 97 we went with a craw space doo to not quite enough green and were not gonna live with in-laws what-so-ever . So the shop was added later with a small basement area for a furnuas room to have some real heat (coal) nuff history got some pics no vid batts dead on cam
lookin through the 2nd opening
not sure I'm going to do it but it would be a nice place for a few hrs of after hr operating time
Old 01-27-2013, 04:47 PM
woodhog's Avatar
woodhog woodhog is offline
Fenders and lights look good now just get her finished
Old 01-27-2013, 05:03 PM
Is it cement floor there already?
Old 01-27-2013, 06:15 PM
yea but very rough , when we poured it had to be 1 of the hottest days the load came hot to begin with coupled with dry hot stones at 2 " rat slab it was all my dad and I could do to get it raked out . the ledge in the pic is half the base for the fireplace + a cap on the buttress wall. the ground here is tight close to your clays but put sand stone rocks in it . in the dry spell , it takes some time to scratch through with the 307 cat excavator I had . We hit ledge in the north east corner (straight back under the pumbing ) I'm just not sure I want to knowing whats under there . It'll sure be some model engineering fun
Old 01-27-2013, 06:39 PM
Supermario's Avatar
A heated playground for the winter!........lucky dog!
Mario
Old 02-01-2013, 03:47 PM
catmack catmack is offline
catmack is on a distinguished road
I'm gonna have to build low pro mining equipment for my crawl space. At best, 18" is all I have at the high end. It would be a great project though. How heavy is the loader IHBuilder?
Old 02-01-2013, 05:29 PM
OK official weight 46.6 lbs without the cab finished . I guessed about 40-50 lbs awhile back not to far off ( I think I pulled somethin ) I used to throw 50 lb seed, fertilizer, and lime bags up on a hydro seeder for years so I guess I got a feel for it
I decided to go through with the basement dig can't think of any logical place to store my coal unless I start another building I can just see the township beside , I got some new machines coming on line this year I need a good proving ground .
Old 05-27-2013, 10:45 PM
started fixing another weak link today . I kept having issues with my valves sticking open and leaking The culprit p---- poor tolerances in the valve heads . The leaking was coming from a 6mm ID oring on a 5.8mm OD shaft So Made new 1's out of brass . 3-4 hours setup and tweaking and 1hr run time tops between the lathe and mill .
old
new
thanks for lookin
Old 06-16-2013, 11:25 PM
whew a little time in the shop with the cad off and the mill off Did some rearranging with the hydros and electrics . now I can use 2 bats and keep them under the hood . Also no more leaky valves the operator got a bench seat though
all nice and tucked under the hood
Old 06-16-2013, 11:31 PM
What a beast! Are those standard sized servos in the cab, running the valves? Gives a really good feel for the size of this loader!
Old 06-16-2013, 11:42 PM
HS 85 MG
thanks Nate , she'll do what a man and shovel will do well almost till the guy gets tired of waiting for batteries to charge
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests)
