Old 09-08-2012, 10:37 AM
Izzy's Avatar
Izzy Izzy is offline
Backyard enginier
Default Izzy's new day cab - ???????
It's been a good while since I started a thread, so be kind
I put ???????? since it seems that everybody has a name for their ride, but as of right now I got nothin.....so ?????? it is.
Many have seen it's current look - I had it at Indy, but the CAB was a last minute donor from Fhhhhstix - he was kind enough to see to it that my ride would make it to Indy.
This truck started as a swap for parts - Stylins fenders. From there I ordered up a King Hauler - no brainer right. So I started with the fender mods. Learned about having to "forward the axel" and rounded up some other parts form other swap purchases and so it started taking shape.
So here are some pics from earlier this year - yep it's been a long build - got thte fenders this past March and been working on it on and off since May.
Stock truck except for off road tires
first MOD - donor parts
Fender Hack
mock up placement
fender after cleaning up the rough parts - pretty minor clean up. But I like things as symetrical as I can stand to get it....
some other donor parts .... RICS tanks...... some swapped rims and some SS fronts, I was thinking of a working day cab. I'm not one for show trucks so I thought the black rims added a nice work truck look. With the spoked fronts as a "Working Mans gift to himself" look
more later ....
Old 09-08-2012, 11:45 AM
plow jockey's Avatar
Default Re: Izzy's new day cab - ???????
Off to a great start. I'm sure it's gonna be an amazing build.
Old 09-08-2012, 04:58 PM
I love that you are hacking up that King Hauler body and putting the right fenders on it! Since those goodies became available, I have been wanting to build a Tamiya again. John's fenders and Brian's grille really make a huge difference. I'm sure this will be a great build. Take your time and get it right. It's worth it.
Old 09-08-2012, 05:42 PM
woodhog's Avatar
woodhog woodhog is offline
Looks good so far!!Im sure it will be a great build. If it goin to be a working truck you sure got a lot of different wiring to be ablr to pull all the trailers you have,Dump,live bottom,detach,etc
Old 09-08-2012, 06:09 PM
Kaf343's Avatar
Kaf343 Kaf343 is offline
Looks good Izzy, love the rim choice. Can't wait to see more.
Old 09-09-2012, 01:31 AM
Bigrigger's Avatar
Don't worry Izzy, with tires and rims like those, there is no possibility of this becoming a show truck. As for names, I thought up a few suggestions:
"Workhorse"
"Midnight Oil"
"On the Job"
"Long Hours"
"Hardly Working"
and here's a good one...
"Bizzy Izzy"!
Loving the build so far, keep it up!
-Chris
Old 09-09-2012, 01:42 PM
dabears's Avatar
dabears dabears is offline
Looks great Izzy!!
Old 09-09-2012, 08:28 PM
Izzy, I love this, it will be different, and one of a kind. Keep up the good work buddy, and keep on truckin'. "BIZZY IZZY", I like that one.
Old 11-11-2012, 06:44 PM
Izzy's Avatar
Backyard enginier
Thought I would post a little today.....
So I had this truck at Indy this year - with a loner cab from Fhhstix (thanks a bunch!) but after the truck pulling event I found that it had a bit of funny luck running about. Well I found that it had stripped the teath off the gears in the Tamiya Trans. SO soon after Indy I went online and ordered a new set of gear.....what ya think?
Izzy
Old 11-11-2012, 07:03 PM
Izzy, i've never used those gears, but I have heard nothing but GOOD things about them. And glad to hear you could fix the problem.
Old 11-11-2012, 08:00 PM
TRUCKMAKER's Avatar
Trucks coming along nicely Izzy, definitely like the work truck thing! Those gears gears should take take of the issue.
Old 11-11-2012, 09:03 PM
woodhog's Avatar
I luv those gears!!! Let us know what ya think of them with all that power.if I strip some gears thats what I will put back in .
Old 11-12-2012, 09:27 PM
So what bl motor & reduction is that? And you're using it with an Integy 2.8 reduction?
What gear(s) did you strip specifically?
Old 11-12-2012, 09:48 PM
Izzy's Avatar
Backyard enginier
Joe good eye.
AXI brushless at 1130 / V
Direct 4:1
Integy as 2.8:1
Brass helical gear set
Running 10C 3s lipo 11.1 volt
. No need for an MFU - she already sounds like a turbo....
Old 11-12-2012, 10:21 PM
Got a link to the motor - gearhead combo?
No, I was wondering what gear did you destroy in the stock transmission?
Old 11-13-2012, 12:56 PM
Izzy's Avatar
Backyard enginier
Pinion and spurt in 3rd
Old 11-13-2012, 01:26 PM
dabears's Avatar
That's a killer motor combo! I've been looking at those metal gears for awhile how solid are they?
Old 11-13-2012, 09:57 PM
Izzy's Avatar
Backyard enginier
Very nice - they have press fit internals so the hex to spline fittings are not reused. The bearings tap in nicely. And with the helical cut there is little noise and the gear mesh I thought was spot on. I will definetly by again when the truck demands it.
Old 11-14-2012, 09:18 PM
Izzy's Avatar
Backyard enginier
www.stellamodels.com.hk
Tractor-truck parts
50 plus shipping - be patient it takes a little while.
