Old 01-06-2013, 12:48 PM
Scottyboy436 Scottyboy436 is offline
Scottyboy436 is on a distinguished road
Default Lead
Does anyone know where to get the lead balls thats some modellers put into there wheels?
Old 01-06-2013, 01:09 PM
dabears's Avatar
dabears dabears is offline
Default Re: Lead
You can use regular bb's
Old 01-06-2013, 02:57 PM
Default Re: Lead
Thanks i was watching a youtube video and thetyre has really small lead balls in the tyre
Old 01-06-2013, 03:02 PM
Default Re: Lead
They are most likely using lead shot for reloading shot gun shells. Lead shot is getting harder and more expensive to get. I just use regular BB's.
Travis
Old 01-06-2013, 03:32 PM
kdz76's Avatar
kdz76 kdz76 is offline
kdz76 is on a distinguished road
Default Re: Lead
heres a spot to buy some http://www.cabelas.com/product/Horna...h-All+Products
Another option could be steel BB's
http://www.airgunstyle.com/copperhea...ct-p-2438.html
Old 01-06-2013, 03:47 PM
Default Re: Lead
Originally Posted by kdz76 View Post
The BB's will work but the link to the lead is buck shot which is going to be a bit large to put in a wheel. Cabals does sell #4 Nickel-Plated Lead Shot but it is $5 a pound. You can get a 6000 count bottle of BB's for $15 and have enough for a stock Tamiya truck
Old 01-06-2013, 07:18 PM
elephants14 elephants14 is offline
elephants14 is on a distinguished road
Default Re: Lead
I guess you just fill them all the way, so they don't rattle. Interesting way to add weight..
Old 01-06-2013, 08:14 PM
Cammo Cammo is offline
Cammo is on a distinguished road
Default Re: Lead
When I have weighted my KH and R620 rear tyres, I got a roll of Lead roof flashing, sliced it while on the roll into 12-15mm thick strips and then just rolled it into the wheel. No noise of the balls moving around and easy to get the trye on without them falling off, and if you dont wrap up hard you can still have get a little bit of give out of the side walls of the tyres. Different concepot, hope it helps.
Also have used fishing sinkers in the past, if I remember correctly #3 Round first and then infill with #5, but now it will be lead flashing all the way!
Australian Heavy Haulage
"Keep on Truckin"
Old 01-07-2013, 01:20 PM
Default Re: Lead
Thanks for the help i might try the lead rolled up in the wheel but would it not stiffen the tyre up?
Old 01-07-2013, 02:10 PM
Default Re: Lead
LEad rolled up - Dont start the first loop tight against the outer rubber, give it a couple of mm and this will leave some space for the tyre to deform. Works a treat, also when using lead shot or round sinkers you reqlly have to fill them up to stop them moving around and making noice, meaning you also lose the give in the side walls. Good luck.
"Keep on Truckin"
Old 01-08-2013, 05:37 PM
cdm cdm is offline
Default Re: Lead
http://www.ebay.com/itm/Lead-Craftin...item27cae7da63
thats what i used. these are very small so not many air pockets.
or you can also get lead solder if you want to melt it to shape easier
