Old 02-19-2013, 02:59 PM
MoRockN's Avatar
MoRockN MoRockN is offline
Default Tamiya 8x8 half pipe
Well since I've always wanted an 8x8 but the scaleArt was just a little on the small size for the money, so I decided to build my own. Not starting on the build just yet cause I'm still waiting on some parts, fuel tank style hydro pump and telescopic cylinder and a Veroma 3 speed tranny. Gonna have, pendulum style suspension, locking diffs front and back, servonaut electronics, Meiller half pipe, Fulda crossfires, euro style rims, Man TGS style front bumper, all brass scale hardware. The tamiya kit will only donate parts of the body and fenders. Then the rest will go on another project.
Old 02-19-2013, 04:35 PM
dabears's Avatar
dabears dabears is offline
Default Re: Tamiya 8x8 half pipe
That floor looks like christmas with all those goodies!!
Old 02-19-2013, 06:31 PM
upbnsfrrfan's Avatar
upbnsfrrfan upbnsfrrfan is offline
upbnsfrrfan is on a distinguished road
You have some nice parts there. Specially those pricey AFV axles Is the dump body by Servonaut?
Thanks,
Larry
Old 02-19-2013, 09:55 PM
MoRockN's Avatar
Thanks guys! Larry, yes that is the servonaut dump body. It's really nice and it looks a lot like the scale art one. I just could not find anything that is as cool as the AFV axles.
Old 02-20-2013, 09:27 AM
Alex Alex is offline
Alex is on a distinguished road
I am interested in building a tamiya 8x8 too any chance of a parts list?
What rails did you use?
Old 02-22-2013, 07:47 AM
MoRockN's Avatar
The dump box and screw drive are from servonaut, I got it a while back now they show out of stock but just email them and they can get it for you. Electronics are also Servonaut SMX and S20. Axles, drive shafts and wheels are from AFV, if you look at the drop down for tamiya trucks you'll see the whole 8x8 setup, the suspension and chassis is from ebay germany. Then getting a Veroma 3 speed tranny, also from AFV. The tires are Fulda Crossfire from Ric at PMD.
I hope this helps.
Ayoub
Old 02-23-2013, 06:20 AM
Thanks I might get in contact with servonaut. How much did the dump bin and screw drive cost?
Old 02-23-2013, 09:51 AM
MoRockN's Avatar
$725 after they take off the 19% VAT.
Old 02-26-2013, 02:31 AM
tman1986 tman1986 is offline
tman1986 is on a distinguished road
Hey you say the suspension and chassis are from ebay Germany
I was just wondering what seller did you get them off??
Thanks
Trevor
Old 02-26-2013, 08:23 PM
MoRockN's Avatar
I just got them from a private seller .
Old 02-28-2013, 07:47 PM
MoRockN's Avatar
Thanks
Trevor
found them for ya
http://www.doc-gear.de/artikeldetail...1925&sprache=2
just look around and you'll find the rails also.
Old 03-10-2013, 09:17 PM
rc13's Avatar
rc13 rc13 is offline
Thumbs up Re: Tamiya 8x8 half pipe
Can't wait to see that paint job. That will be real sweet with your Doosan loader.
Old 03-12-2013, 09:27 PM
MoRockN's Avatar
Well here is where I'm at so far, got tired of tripping over the parts so I decided to put them together, I know the tranny looks low but it will not be in the same position as I will have a transfer case instead and I will move the tranny closer to the front. I had the suspension all built then realized it was backwards as the fronts were not spaced correctly. Still need to paint the cab and rims, install all the drive shafts and install all the electronics. I hope the pictures work since they were very small.
This tranny is sooo tiny, I really like it.
Here is how it's supposed to look now that I got it fixed. That's what happens when you build stuff at 3:00am .
Thanks for looking. More to come later.
Old 03-24-2013, 09:30 AM
Claus's Avatar
Claus Claus is offline
Do I understand you right?, you are changing out the Veroma trans mission with transfer case to the Veroma with separate transfer case?
Like to see that version too!
Old 03-24-2013, 11:58 AM
Great start! I'm partial to twin steer and half pipes.
Cheers, Neil.
Old 03-24-2013, 01:04 PM
MoRockN's Avatar
I will be mixing and matching things to see what works better, I will be moving the Veroma to the RC4wd truck and maybe the Rigidrc setup to this one. Still playing with ideas.
Old 03-25-2013, 02:00 AM
A friend of mine used the Veroma gearbox on a 6x6 with a dump trailer. It didn´t handle the weight when fully loaded. There are some springs inside the gearbox that give in.
Old 03-25-2013, 07:26 AM
Claus's Avatar
Seen this photo floating around, the Veroma looks pretty good inside.
Old 03-25-2013, 09:25 AM
MoRockN's Avatar
Man that does look sweet. Thanks for sharing ! Veroma does make two options, I have the heavy duty guy.
Old 03-25-2013, 09:41 AM
Claus's Avatar
I didn't know they made two different strength transmissions, I knew they made a trans with a transfer case built in, a trans without a transfer case, and a separate transfer case with two or three different ratio options, but that is all I'm aware of. How do I know if I'm looking at the heavy duty version?
