Old 10-05-2010, 10:14 AM
kerst's Avatar
kerst kerst is offline
Default Liebherr LTM1800 scale 1/24
Dear all,
I have built 3 working scale models of cranes, a Manitowoc 4100W with Ringer (1/25), a 4600 S-5 (1/25) and a Krupp 180GMT (1/20) with counterweight truck.
In 2006 I started on a scale model of the Liebherr LTM1800 expecting about 10 years to complete it. I chose this crane because it has so many possibilities, both telescopic as lattice boom, derrick mast, etc.
The axles; it has 16x8 drive and I wanted to do this for the model as well. Steering is on 6 axles. I bought the differentials (Traxass) and built the axles around them. This saved me a lot of time and they turned out pretty good. The only disadvantage was that these differentials are a bit bulky for this scale.
I put a lot of strength (and thought) in the central part of the carrier frame, because all the forces are going through this part. It also needed to accommodate 2 drive axles and the slewing ring and the electrical controls need to go through the slewing ring to the upper.
The slewing ring is almost an exact copy of the real one, same principal with the motor located in the rear of the carrier. It has an optional quick disconnect which raises the upper a bit, but makes it very easy to take the upper off. There are only a handful of real ones with this feature.
I made the outriggers of steel, brazed together for strength. The outriggers have small geared motors inside and work with a spindle.
Here is a video of the outriggers:
http://www.youtube.com/watch?v=i1kol40B3ow
Most of the drive line is finished. It has 16x8 drive, a transfer box with 2 speeds and a central differential. I still have to make the main gearbox. The steering is done with a servo in the front. I am not sure if this servo is strong enough. It might need a stronger one.
This picture shows the working outriggers and the upper almost finished. The upper is made entirely from AL and the winches have individual motors. The winches can be lifted out easily, like the real one. I choose to leave the second winch out and use the space for electrical stuff. I managed to make a device that pushes the A frame up till it is in a working position.
And this one shows the A frame being raised:
http://www.youtube.com/watch?v=mLI-NwKSGx4
Kerst
Old 10-05-2010, 10:26 AM
kerst's Avatar
Default Re: Liebherr LTM1800 scale 1/24
A few more images:
Kerst
Old 10-05-2010, 11:41 AM
pugs pugs is offline
Very impressive work. Looks like alot of thought went into it.
Jeff
Old 10-05-2010, 12:59 PM
SonoranWraith's Avatar
It's a dry 115 degrees.
Looks amazing. So how many years in are you?
Old 10-06-2010, 04:17 PM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
All I can say is WOW!!! And everyone says I am detail crazy! Your drivetrain looks incredible.
Old 10-06-2010, 08:34 PM
kerst's Avatar
More pictures:
Kerst
Old 10-06-2010, 08:38 PM
kerst's Avatar
outrigger motor:
Kerst
Old 10-06-2010, 09:40 PM
Roadmasters's Avatar
Moderator
absolutly amazing
Arioch
Old 10-06-2010, 09:50 PM
Amazing workarounds for the size limitations and still make it look and function like real thing!
Jeff
Old 10-06-2010, 10:02 PM
I'm ssoo glad you got the clearance to come aboard this forum now. Your work is jaw dropping. I've been waiting for your post. Can you show everybody the other cranes?
Old 10-06-2010, 11:18 PM
Finster's Avatar
Finster Finster is offline
I love the outrigger solution. Very clever! Outstanding job overall on this model.
In some of the pictures I I see what looks like a homemade transmission but I'm a little confused. Does it contain a differential? If so why, I'm not sure I understand it's purpose. Thanks.
Brian
Old 10-07-2010, 08:04 AM
kerst's Avatar
It is a differential and the purpose is to divide the power between the rear 2 axles and the front 2 axles. This way it will have permanent 8 wheel drive.
Kerst
Old 10-07-2010, 08:50 AM
SmallHaul's Avatar
Very nice work. The 2 speeds trans is a nice touch, you are not cuttings corners anywhere!
Scott
"No load is too Small"
Old 10-07-2010, 10:22 AM
kerst's Avatar
Thanks everybody for the compliments and the encouraging words!
I will keep you updated, but have patience, it will take time, it is a slow process and i don't have a lot of time to build. Luckily i have a corner of my workplace for building my cranes and that gives me the opportunity to often spend 20 minutes after work working on the LTM1800.
Kerst
Old 10-07-2010, 11:22 AM
kerst's Avatar
Here is a link to a photo album with pictures of my (more or less) finished scale models.
    • In 1/25 Manitowoc 4100W also with Ringer,
    • In 1/20 Krupp 180GMT,
    • In 1/20 mercedes truck 2644 with 5 axle Goldhofer trailer for the counterweights.
    • In 1/25 Liebherr LTM1800
    • In 1/35 Demag TC 600 (non motorized)
http://picasaweb.google.com/kerstdejong3/ScaleModels#
Kerst
Old 10-07-2010, 07:02 PM
dirtpusher9's Avatar
Moderator
Kerst, I'm glad you made it over here. I really like the 4100 ringer, that is something. Do you have a video of it working, I didn't see it? Your work is incredible, look forward to more.
Old 10-07-2010, 11:37 PM
CorbettTrailers's Avatar
CorbettTrailers CorbettTrailers is offline
CorbettTrailers is on a distinguished road
Originally Posted by Roadmasters View Post
absolutly amazing
I second that!
ECMT Members: Join your Group. Go to your username in the top right corner of the page and click on it. When your profile opens go down to group memberships, Click on East Coast Mini Truckers, The social group will open and scroll down And in the middle it you will see "Join Group" Click on it and then confirm that you REALLY wanna join.
[SIZE="2"]
Old 10-08-2010, 12:43 AM
bigford's Avatar
bigford bigford is offline
the WOW factor is really up there
Old 10-08-2010, 01:51 AM
Wow. Most impressive! I can't over the fact that it's only 1/24 scale, which seems so small, but that has to present enough challanges by itself. I would think a crane like this would be easier to built in 1/16 or 1/14 scale, but then it would be a monster! The drivetrain is incredible, considering the size. I'm amazed that you are able to pull it off because of the size. Awesome.
Old 10-09-2010, 10:38 PM
BigZracingRC BigZracingRC is offline
BigZracingRC is on a distinguished road
THAT IS SO AMAZING! what tools are you using to make this?
thanks
zach
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
