Go Back   RC Truck and Construction > RC Truck's Kings of the Road > Australian Rigs & Roadtrains
Australian Rigs & Roadtrains A place for aussies to show off their unique truck configurations.
Old 05-12-2011, 12:28 PM
Cossett's Avatar
Cossett Cossett is offline
On Leave
Exclamation My Carson Goldhofer low loader/drop deck
Hi all, look what turned up Monday morning on the doorstep the new Carson Goldhofer low loader/drop deck more pics to come as this will be a very long build instead of slap it together in a couple of hours like other trailers..
There are alot of pro's and cons about this trailer,
The length of this trailer is 880mm from front to rear without the ramps mounted to it.
I comes with sealed bearings not bushing like standard trailers.
The body is laser cut steel spot welded together and the chassis rail and skid plate are also spot welded to the deck, there are side support that need to be cut from a sheet (similar to photo etch part) this is a solid looking trailer with aloottt of raw steel/alu parts and **** loads of small bolts/screws ect,
Part of the lower decking is ply wood with plastic chequered plate that they say to use with thin double sided tape, the travel arms, some brackets, U bolts are also hard plastic, the air bags a soft rubber and the axle are mounted over the top of the travel arms where as a normal trailer they are mounted under, the tyres are hard Carson Fulda's about 58mm in height and the other parts that aren't metal there hard plastic.
The lights that come with the trailer you need to use the Carson 7-chamber light set for trailer as the light lenses that come with it are different from the normal Tamiya trailer lights.
The biggest let down for this kit apart from not being what was promised, wrong size tyres ect is the raw steel and alu as nothing is painted/anodised/powder coated as when I got the steel one piece deck out of the plastic bag my hands were dark after from handling the raw metal so after forking out the 399,00 ish EURO's you have handed Carson's you still needs to painted/powder coated it yourself.
More pic's to come as I build it and I will be bringing it to the Sydney 14 Scale Modelers meet that RCRoadtrain (Richard) is doing this Sunday so people can see it as it comes out of the box..
Cheers Tracy
Love my Kenworths
Old 05-12-2011, 04:19 PM
sneaky-pete's Avatar
Master A-Modeler
Default Re: My Carson Goldhofer low loader/drop deck
Good luck,and keep us posted!
Troy
Old 05-17-2011, 04:54 PM
Quad-Dog Quad-Dog is offline
Quad-Dog is on a distinguished road
I've only seen a finished one yet.
399 for such a solid trailer made of steel and spot welded is pretty reasonably compared to the other Tamiya trailers. But you really can't expect getting an already painted trailer for so little money. At least not one beeing made in Germany. It's quite labour intensive as you'll find out soon and it would only result in a price no one wants to pay.
Put it this way: Pretty good deal with the current exchange rate
Old 05-21-2011, 09:29 AM
Cossett's Avatar
On Leave
Hi all, Here are more pic's that I took when I took it to Richards meet next to andrews carson drop deck trailer..
Cheers Tracy
Love my Kenworths
Old 05-30-2011, 07:33 AM
Izzy's Avatar
Izzy Izzy is offline
Backyard enginier
Looks pretty good from way over here. LOL. I bet the price would double inthe small bits were machined instead of plastic.
Are you going to try and alter for the correct size wheel or build as is? Is the deck height correct? Maybe they did it on purpose to compromise?
Old 06-08-2011, 12:43 AM
BigZracingRC BigZracingRC is offline
BigZracingRC is on a distinguished road
WOW!!! I wish all companies made products that nice!!! Looking Awesome!
Old 06-19-2011, 11:13 AM
Cossett's Avatar
On Leave
Hi all, there is no build progress but I took these pic's for a friend and thought I'd post them here with some of the measurement I took of them compared to a tamiya truck wheel
59mm high Carson Goldhofer tyre, 32mm wide on both rims
83MM hight Tamiya truck tyre, 46.5mm wide on both rims
Carson Goldhofer axle diameter 5mm
Tamiya truck axle diameter 4mm
Cheers Tracy
Love my Kenworths
Old 06-19-2011, 12:40 PM
Car5858's Avatar
Car5858 Car5858 is offline
Thumbs up Re: My Carson Goldhofer low loader/drop deck
Tracy, thanks for the tire size compairson. This helps out with tire size slection for other builds.
Carl
Old 06-19-2011, 01:16 PM
Cossett's Avatar
On Leave
I also forgot to add you can but the Goldhofer tyres & rims separately from http://translate.google.com.au/trans...%26prmd%3Divns (when you go to the site look in NEWS for details) if you require a slightly larger tyre than the normal Carson low loader one, also you can get the air bag suspension /axle from this site if you want to scratch build a trailer to suit your own purposes, one other thing to note with the new suspension it give you the option to mount the axle over or under the travel arm..
Cheers Tracy
Love my Kenworths
Old 06-19-2011, 03:21 PM
Car5858's Avatar
Thanks for the link Tracy, to get the tires I need would cost $269.70 US or 189 Euros
Old 07-17-2011, 11:33 PM
Bsorenson79's Avatar
Cheers Tracy
I went to this web site and tried to order a couple things. But I couldn't get it to translate into English
Old 11-07-2011, 07:37 PM
Cossett's Avatar
On Leave
Hi all, I got a little board last night and decided to start on this Carson Pig of a trailer, the next few pic's are of the landing legs (front/rear) and the air bag suspendtion (witch carson class as hard )
Cheers Tracy
Love my Kenworths
Old 11-07-2011, 07:55 PM
Cossett's Avatar
On Leave
And the majority of the trailer is built only cause I was board and wanted to see what what the PIG looked like built....
Cheers Tracy
Love my Kenworths
Old 11-07-2011, 08:33 PM
Peter Peter is offline
Peter is on a distinguished road
Is this gonna be finished for the meet on the 19th....
Old 11-08-2011, 07:37 AM
Brian in PA's Avatar
I'd rather be truckin'
Looks Great Tracy! The airbags re super looking. Are they the ones that come with the kit?
Brian
Old 11-10-2011, 08:12 AM
Cossett's Avatar
On Leave
Hi brian yes the airbags are the kit ones for this trailer and www.veroma-modellbau.eu/ is the only place I've come across that you can get then separately...
Cheers Tracy
Love my Kenworths
Old 11-12-2011, 02:10 AM
I don't know, Tracy, I think it's a nice looking trailer. Besides the tires and paint concerns, what else really bugs you about it? Lacking detail? It looks pretty nice, well designed, and strong.
Old 11-12-2011, 11:57 AM
SWAGGER's Avatar
SWAGGER SWAGGER is offline
I think that is a first class trailer. It is a lot of hard earned cash, no doubt, but if you tried to scratch build one to even close to that quality, I reckon it would cost a lot more. Having to buy axles, suspension, wheels, tyres, bumpers, legs, and all of the rest, you would still have to have metal fabricated (and the cost of the raw metal), not to mention tools, workshop and time. I don't think you would get the detail and strength, I mean look at all of the ribbing underneath and it's not even cheap leaf springs, it's airbags.
I can see you are unhappy, but believe me, I would LOVE LOVE LOVE that trailer but just couldn't spare 400 euro at the moment. I think it's a real shame that for the money spent, you are not enjoying it, so for your own sake Tracy, get it painted or powder coated nice, to match your truck, swap the tires and whatnot and who knows, it may grow on you and you could come to love it.
It really is a seriously high quality piece of kit. Best of luck, I really hope it works out for you!
Old 04-15-2013, 05:40 PM
Straywolf's Avatar
I was just wondering how this trailer turned out?
Old 04-16-2013, 12:02 AM
Claus's Avatar
Claus Claus is offline
I think it's a nice trailer just wish it were longer and Wedico width.
