| Big Boys of the road 4x4/6x6/8x8/10x10 Trucks This forum is for those multiple axle trucks and other vehicles on and off road. |
WOW! How did I miss this build.. I am at a loss of words by your ability's you have for building..Cant wait to see more progress.[/I]
wow your doing a really nice job on it keep up the good work.
This is too much! At least I can rest assured now that i'm not the only one nuts enough to tackle an operating crane in 1/24-1/25. I didn't know there were cranes posted in this section of the forum. I assumed they'd be in the "Construction Equipt", so I posted mine there. You should post a link to this crane there too, I know some of us tend to stay close to a given section of the forum, and can miss something great like this. It's amazing the differing approaches to achieve the same results on something. That differential transmission is unbelievable.
I'll definately be checking out your other work, but it's late now, I gotta hit the hay. Here'm mine if you want to take a look: http://www.rctruckandconstruction.co...read.php?t=203 I didn't know forums like this existed, as i was looking in the wrong places, I guess! I have to say, your crane is inspirational! Dan |
This is an amazing build, I'm feel like I'm way outclassed here. Like I went to the corvett rally at bowling green plant in a pacer.
Progress has been slow, too many other things to do.
But i managed to make the cab for the upper. ![]() here is a link: http://picasaweb.google.com/lh/photo...eat=directlink Kerst Last edited by kerst; 11-10-2010 at 12:59 PM. |
#26
#28
Hey, Kerst, I took a look at a couple of the videos. I'm a little puzzled as to how your upper unit is going to operate, but obviously you have it down. Watching the outriggers lift the whole thing is awesome! What are you using for the cable in your rigging? Dan
#29
Hi Dan,
Each drum has its own motor(s) and the swing motor is located in the carrier, like the real crane. i will lead all the electrics through he slewing ring and have a socket in the carrier to connect to a remote control box, so it will be remote, but not radio control. i am not sure yet where to put this socket in the carrier. For the steering of the wheels I use a servo and a servo tester. There just is no space for all the gear needed for RC control and I mostly operate it on a table, so it is not going so far. I am using 1 mm nylon cable. I use it on all my cranes and it is both strong and flexible. The controls for the outriggers are on the right side behind the carrier cab. just fitted! Kerst |
#30
this really is killer! i need to get back on my crane.....
#31
Where do you get this nylon cable? Sounds exactly like what I need. I've been using silk fishing line, probably made in the '60s. Strong and round, but MAN is it hard to find. Does the nylon cable come in larger sizes that you know of?
#32
Kerst |
#33
Nathan |
#34
Slow, bur a lot of fun for me! Thanks for your comments, kerst |
#35
That is nice
Member of the Central Plains Mini Truckers and The Spawn Of Cowboy. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#36
I haven’t had much time during December, too busy, but I found bits of time and I worked on the electrical system. At the heart of this is the rotary connector, which I built from scratch.
I will use the same control console as I use for my Krupp 180GMT and I put the connectors underneath one of the outriggers, not very elegant, but it was the only option. On the picture one can also see the swing motor tucked in above the rear bogie. The rotary connector has 4 sockets, so I can simply plug in the motors in the upper. ![]() ![]() kerst Last edited by kerst; 01-03-2011 at 05:02 PM. |
#37
I originally was going to make my own collector rings but found one that suited.
Looking at your picture; Is the brass soldered to the aluminum? I've never tried to do that before. |
#38
Kerst |
#39
Hey Kerst, thank's for posting the picture's! Back in 1987 at the Conexpo Conag show, somebody brought a large layout with working crane's in your scale. Can't remember his name, but alway's incredible! I missed every time, he operated them. Found out through one of the trade rag's, what I really missed at the show. Any other contractor's remember this? Later, Neil#2 aka doodlebug.
#40
Oh, did you mean the frame? I glued the Al and brass together, but for strength a 1/4' bolt connects the brass with the center ring, a similar setup like pre-stressed concrete. I like to use AL, because it is light and easy to work with and i found very good glue. But i don't rely completely on the glue; I mostly add bolts. i made the outrigger beams from steel, because I wanted a lot of strength there. I plan to make the telescopic boom from AL too. it should work and it will flex a lot more than steel. And i would like to achieve that effect. Kerst |
| Currently Active Users Viewing This Thread: 14 (0 members and 14 guests) | |
| Thread Tools | |
| Display Modes | |
