Old 05-20-2013, 10:17 PM
Dieselchopper's Avatar
Default Aeromax Overhaul
I have decided to rebuild my Aeromax. Making it into a winch tractor. Started with suspension changes to get better travel and traction.
Old 05-20-2013, 10:21 PM
Default Re: Aeromax Overhaul
Got time in on winch deck and housing as it was raining today. Here is a mock up as is. Also decided to lower sleeper some for a pop up wide load sign.
Old 05-20-2013, 10:24 PM
Lots to do yet. Went with steel as I want some weight to stabilize truck for winch work. Have lazer cut parts on order for a tail roll and several other small parts. Going to add a manual sliding 5th wheel plate.
Old 05-22-2013, 02:06 AM
Diesel Demond's Avatar
looks tough !! can waite to see the sliding 5th wheel and make a extra one if ya know what i mean!!!
Old 05-22-2013, 05:51 PM
pumptech's Avatar
pumptech pumptech is offline
pumptech is on a distinguished road
Like the headache rack ,looking good ,look forward to seeing more of this build
Are you using 1/4 keystock ,what I used on my oilfileld king hauler worked good .keep up the good work
Old 05-22-2013, 11:52 PM
Working at a welding shop I brought in a few 20' lengths of square bar. Pricing power I paid pennies a foot for 1/4", 3/8" & 1/2" material. Far cheaper than the ey stock.
Old 06-17-2013, 02:56 PM
got my laser cut parts for my tail roll assembly. here is what they look like fresh from the package. Will post pics as assembly happens.
Old 06-17-2013, 06:32 PM
sassgrunt sassgrunt is offline
sassgrunt is on a distinguished road
That's a beautiful job on your rear axles setup. It looks like you are going to have a lot of articulation, and I would think that the stock dogbones are going to want to fall out. Are you looking at aftermarket replacements for this?
Also, if you want to update it to a Sterling, there are now replacement stickers that fit the kit body:
http://www.ebay.com/itm/TAMIYA-1-14-...ht_1250wt_1156
-Mike
Old 06-17-2013, 08:04 PM
I will be changing out the drive shafts. However I owned a fleet of 5 ford's very similar to this hauling cattle and hogs. I will likely not update to sterling. Thanks for the info though.
Old 07-15-2013, 01:09 AM
Got the frames drilled, tail roll working, and enough assembly done to order in drive shafts. Here us how she looks. Want to make sure all is functioning correctly before I worry about paint and polish.
Old 07-15-2013, 02:47 AM
Trucker_Jo's Avatar
Pretty strong looking setup, looks like double frame rails.
Old 07-16-2013, 10:13 PM
elephants14 elephants14 is offline
elephants14 is on a distinguished road
That is epic. I like it. I also like the double frame rails. Make it look really clean, and different. Bet ya don't bend it.
Thanks
Cody
Old 07-17-2013, 12:55 AM
Stuff's Avatar
Stuff Stuff is offline
she looking good!
my YouTube is -
Subscribe!!
My Facebook -
Old 07-22-2013, 09:43 PM
Got done to the point of some paint before assembles. Here is what's done.......
Old 07-23-2013, 12:24 AM
Stuff's Avatar
not bad!
my YouTube is -
Subscribe!!
My Facebook -
Old 07-28-2013, 09:11 PM
ptebbe ptebbe is offline
ptebbe is on a distinguished road
Nice job on the air suspension upgrade.
Can you give us an idea of what the final product is going to look like?
Paul
Old 08-03-2013, 11:17 PM
Got drive shafts and enought other parts finally all assembled. Went out to play and in the end blew my steering servo horn. Was running a stock tamiya kit horn on steering servo. Might have had something to do with the 75 lbs rock on the trailer. Got to hand in to Garden Trucking and the 4:1 gear reduction unit amazing pull power increase. Was just about to add another 75 lbs or so rock onto the second trailer of my supper b set when the steering went. Here is a pictur of the rock I got slammed in the duals with the first bolder on deck.
Also shows the new drive shafts.
Here are some other pics of the winch deck. Still making tool boxes, alum headach rack plates, alum fenders, and working on cab yet.
Still lots to do but getting closer all of the time. Hope ya all like.
Old 08-04-2013, 01:02 AM
That looks nice. Those tires definitely have some knobs on them. I think your cab protector/winch mount and platform turned out really nice. With black paint on them, those parts look great! Did you paint the cab yet?
Old 08-04-2013, 02:23 AM
If all goes good I will be getting to paint on the cab tomorrow. Was still adding a little filler to some of the custom changes. Mabey gona go into work where I have good toys and make the tool boxes tomorrow too. Polishing the alum will take a while I am still playing around with my tumbler to find good results in using it to do base polish.
Old 08-05-2013, 11:03 PM
Got some of the aluminum work done. Still have to make the 2 tool boxes and polish it all.
