Old 08-13-2013, 09:47 PM
Bigrigger's Avatar
Default Re: KW Daycab "Pipe Dream"
Originally Posted by RodneyO View Post
Man this is gonna be a nice truck when it's done.Nice work
Thanks Rodney! That's the plan. We'll see how it goes.
Originally Posted by Radio Control Trucker View Post
Thanks for posting the progress. I hope you get finished in time...
- RCT
Thanks RCT! I'm not very quick with body-work, but it's coming along!
I hope to have some time tomorrow to work, and then I can finally get it all together!
-Chris
Old 08-15-2013, 05:03 PM
RodneyO's Avatar
RodneyO RodneyO is offline
RodneyO is on a distinguished road
May have to get you to make me a set of those fenders for my build.
Old 08-18-2013, 01:26 AM
Bigrigger's Avatar
Arrow Re: KW Daycab "Pipe Dream"
I'll see how sick of body work I am when I'm done. It might be an 8-month wait, though! Thanks for the compliment!
I wanted to show that I am still working on this build, in bursts.
First I hit the fenders with some putty and primer:
I also started working with some brass! I'm planning on a dump system similar to Lostinoz's Scania dump truck: http://www.rctruckandconstruction.co...ead.php?t=6152
I will try a different hinge, and mounting system, but his build inspired this brass structure.
Not the finest, but the fact that it fit on the frame perfectly at both ends blew me away. Measured 64 mm, soldered, and measured 62 mm. Magic!
I have another shipment of brass coming soon, and only a few scars!
I also relocated that On/Off switch plate, because of all the empty screw-holes! I hope it can fit with the brass structure at the end.
I'm thinking a screw-drive for this one, but that will be a whole other matter entirely.
I'm going to go slap some mud flaps on this thing! Get it up to code.
Let me know what you think, and any brass-working tips are appreciated!
-Chris
Old 08-18-2013, 10:25 PM
RodneyO's Avatar
That's cool.You fab them up I'll finish them off.I'm a painter/bodyman.I can make anything look good.lol.
Old 08-19-2013, 02:00 AM
Your brass work looks really nice! So no dump trailer, huh? Just a dump truck? Maybe a transfer dump, with a pup trailer at least? Ha ha. Any kind of trailer...?
Old 08-19-2013, 03:19 AM
Bigrigger's Avatar
I'll have to send these off to you, then! As you can probably tell, I'm no painter/body-man. As a pro, you might want to look away when I try to paint this thing! Thanks.
Thanks! I'm happy with the result, and only burned a few fingers!
Man, you and that dump trailer... Just kidding. I'm planning on making the dump-kit easily removable, so that I can swap back to a tractor.
I was debating one or the other, and if this dump box turns out nicely, then I may attempt a similar dump trailer. Transfer dump would be cool too, but I'd need to build two of these brass thingies!
How about: I'll look into making a dump trailer, as well. You can hold me to that!
No real progress, although I picked up some brass tube for the hinge. I'm not entirely sure about my plan for that.
I did put the mudflaps on, and they actually add a lot to a chassis this empty.
If my brass order doesn't arrive tomorrow, it'll be pipe-cutting and body work, if it does, then I will hold off on the filler.
I also have a few concerns I'd like to share with you guys:
Power options for the screw-drive?
Lifting arm positioning? (Whether the arm will be pushed towards the rear to lift the box, or pulled towards the front to lift the box.)
I'm thinking about mounting the motor between the frame rails, but attaching it to the brass frame, so that it can be easily removed.
Thanks for looking! Let me know your thoughts on those things.
-Chris
Old 08-19-2013, 04:02 PM
RodneyO's Avatar
If you need my help don't hesitate to ask.
Old 08-25-2013, 01:01 AM
Bigrigger's Avatar
Thanks Rodney! If you see me do something strange, feel free to point it out!
Well, I finally put the two pieces together! I just need to see how it fits on the chassis, in case I need to adjust it. I think it looks pretty good, if it fits!
Here are the pics:
I drew up a grille, got it printed, and it is on the way! Only it's coming from Belgium! The first grille will be plastic, but if it fits perfectly, and looks good, I'll be able to order one in stainless steel!
The grille should arrive in a month or so, but I have plenty of work to do before then. I hope to start chopping the pipe up tomorrow! I also need to braze up a hinge!
Let me know what you think!
-Chris
Old 08-25-2013, 12:37 PM
RodneyO's Avatar
Looking good.
Old 08-25-2013, 07:07 PM
Thumbs up Re: KW Daycab "Pipe Dream"
It looks great. It's lines up well & is well proportioned.
Your dedication is paying off. Take your time and don't rush now.
- RCT
WCMT Director -
Old 09-12-2013, 07:47 PM
john john is offline
john is on a distinguished road
hope i not too late to comment but great job, inspired me alot, i like all the ideas on here hope to see more wonderfull pics, and the trailer to dont forget lol
Old 09-14-2013, 12:19 AM
Bigrigger's Avatar
Never too late for a compliment! Thanks a lot! We'll see about the trailer!
-Chris
Old 09-14-2013, 02:28 AM
Bigrigger's Avatar
My 3D-printed grille just came in, although it is a little small:
So, while I work out a new one with the company, I will be trying to finish up the rest of the body. The fenders are not straight enough, and coming off. The headlight boxes need sanded and puttied, and then a new coat of primer, and it should be paint time!
That is very hopeful; I'll see what I can pull off.
Let me know how the mini-grille looks!
-Chris
Old 10-31-2013, 09:28 PM
Roadmasters's Avatar
Moderator
Mini grill is pretty sweet! 3d printing is an incredible thing
Arioch
Old 11-01-2013, 12:37 AM
Bigrigger's Avatar
Nice to have you back, Arioch.
I've since printed another but it was in the wrong material, and was a little short. Third round will be coming down the pipes soon, and tomorrow I'll get to some bodywork and maybe even the final coat of primer!
-Chris
Old 11-01-2013, 08:53 PM
Tamiya Cowboy's Avatar
Very nice work Chris..
Paul W. "Tamiya Cowboy"
