Go Back   RC Truck and Construction > RC Truck's Odds and Ends. > Non Rc Model Trucks and Equipment
Non Rc Model Trucks and Equipment This area is for the custom builders of the "MODEL" world to show there NON RC metal and plastic creations and builds.
Old 09-07-2013, 02:28 PM
J Hall J Hall is offline
J Hall is on a distinguished road
Default Cat 966
Just got done with a 966 loader in 1/16 scale..It is made mostly out of wood..
Enjoy
Old 09-07-2013, 03:16 PM
Default Re: Cat 966
Another home run!
Cheers, Neil.
Old 09-07-2013, 03:44 PM
Finster's Avatar
Finster Finster is offline
Default Re: Cat 966
Wow that's really nice. Great job! How did you do the pattern on the tires?
Brian
Old 09-07-2013, 04:18 PM
Brel's Avatar
Brel Brel is offline
Default Re: Cat 966
nice work
Old 09-07-2013, 07:27 PM
Default Re: Cat 966
Thanks for the kind words guys...
Finster,
Here are a couple of photos that might help on the tire detail
I make pattern out of poster board and divide it into the desired number of cuts to be made..
Mark the spacings on the tire..
Cut a 2X4 at 30 degrees and drill a 1/4 inch hole to take the bolt ( axel shaft)
Note the red arrow..Each mark should allign on the arrow..Run the wheel throught the saw and advance to the next mark..
Set the table saw sled at 30 degrees and set the fence so that the wheel stops at a point where the center of the cut is at the center of the wheel..Always bump the wheel up to the fence on each pass to assure proper spacing..
Set the depth of the blade by making passes through scrap until the desired depth is attained..
I hope this helps..
Old 09-08-2013, 04:08 PM
tracksntreadslou's Avatar
Default Re: Cat 966
Awsome Jerry ..Great to see you pumping out those beautiful models again ..nice work
Have you been tinkering with the Dozers as well...On of my foavorite builds by Far
Old 09-08-2013, 06:20 PM
Default Re: Cat 966
Hi Lou
Good to hear from you.. It has been pretty quiet lately in my shop...I retired from the commercial building and have been playing around with other things..
I have a Joal Cat 375 excavator and have kept in around for a pattern if the need ever comes to make a larger version of it..I did a little investigation into doing a 1/16 scale version, but a bit intimidated by the size...That thing would be huge, over 3 feet long..The real one weighs over 160,000 pounds..
Old 09-08-2013, 10:11 PM
Default Re: Cat 966
Just think of all the extra room you would have to work with, LOL! I've found a furnace oil pump(hydraulic pump), that would be great in a large excavator. And they are cheap!
Cheer's, Neil.
Old 09-08-2013, 10:34 PM
Default Re: Cat 966
furnace oil pump..?? Sounds interesting...Where did you find it..
Old 09-09-2013, 12:16 AM
Default Re: Cat 966
Problems with my steam cleaner, always trying to repurpose stuff.
Suntec A2VA7116, They are cheap on e bay. 2-3 gph at 150 psi.
http://www.ebay.com/sch/i.html?_nkw=...mi=eBay+Motors
The German pumps are 4.72 gph.
Cheer's, Neil.
Old 09-09-2013, 01:00 AM
Finster's Avatar
Default Re: Cat 966
Thanks for the explaining how you did the tire patterns, I appreciate it.
Brian
Old 09-09-2013, 01:03 AM
Finster's Avatar
Default Re: Cat 966
Neil,
I'd liked to know more about those pumps too as I'm sure others would as well. Maybe you should start a thread about them, so we can discuss them in detail, I don't want to hijack this thread anymore.
Brian
Old 09-09-2013, 02:11 AM
Default Re: Cat 966
Originally Posted by Finster View Post
Neil,
I'll start a new thread tomorrow, they are big in size, but that's the trade off!
Cheers, Neil.
Old 09-09-2013, 08:36 PM
Default Re: Cat 966
Neil
Are the pumps AC or DC...?? I am guessing DC
Old 09-09-2013, 09:15 PM
Default Re: Cat 966
Jerry, no motor included, a few details to be figured out!
Cheers, Neil.
Old 09-09-2013, 10:01 PM
Default Re: Cat 966
My bad Neil...I just assumed the motor was incorporated with the pump..
Old 09-10-2013, 12:27 AM
Default Re: Cat 966
No bad! just more options for vroooom vroooom
I'm working on a new thread tonight.
Cheer's, Neil.
Old 12-21-2013, 01:24 AM
RCLogger's Avatar
RCLogger RCLogger is offline
Default Re: Cat 966
Great looking machine Jerry. What's next ?
Greg
Old 05-19-2014, 02:20 AM
Cat966c Cat966c is offline
Default Re: Cat 966
I'm working on a 966c (prototype) from cardboard. Dad won't let me weld.
