Old 10-10-2013, 06:31 PM
jd*rccustoms's Avatar
jd*rccustoms jd*rccustoms is offline
jd*rccustoms is on a distinguished road
Default Need help with ertl rc tractor from the late 70s-early 80s
The tractor runs by itself unless i pull the trigger backwards and then it stops. The weird part is sometimes it does this and sometimes it runs completely normal. Any ideas of what it could be? Its a early 1970s- 1980s ertl john deere 1/16 scale tractor with pistol grip radio.
Dustin Woodrum
Old 10-11-2013, 01:46 AM
Stuff's Avatar
Stuff Stuff is offline
Default Re: Need help with ertl rc tractor from the late 70s-early 80s
my guess is tarnish or something on the remote's contacts??
my YouTube is -
Subscribe!!
My Facebook -
Old 10-11-2013, 12:57 PM
rc_farmer's Avatar
Master Builder
It sounds like the 4640 running on 27 or 49mHz.....those boards go bad, everything in there is analog. There arnt any contacts in the tractor and prolly not any in the radio either. Its all pots and diodes. Unless one is an electrical engineer........
Giving up is not an option!!!
Rob
Old 10-12-2013, 11:39 AM
So is there any way to fix it?
Dustin Woodrum
Old 10-13-2013, 01:08 PM
rc_farmer's Avatar
Master Builder
Rip out the existing wiring and install a 2-channel radio, using the existing motor for drive and installing a small servo for the steering (taking out that existing analog servo)
Rob
Old 10-13-2013, 10:23 PM
How do i split the tractor. Ive taken all the screws out that i can see but it still will not come apart. Do i have to take the wheel off? And if so how do i do it? Thanks f
Dustin Woodrum
Old 10-13-2013, 11:17 PM
rc_farmer's Avatar
Master Builder
Post up a pic....i suspect it has pressed-on wheel retainers and you will need to use vise grips to pull those off. Check behind decals for hidden screw as well too.
Rob
Old 10-14-2013, 06:52 PM
Finally got the tractor apart. Now which radio esc and servo do you recommend using?
Dustin Woodrum
Old 10-16-2013, 09:24 PM
rc_farmer's Avatar
Master Builder
post up some pics its been a minute since i have had one apart, but i can refere to the other one by ertl that i have done
Rob
