Old 07-13-2013, 01:20 AM
steamer's Avatar
steamer steamer is offline
Default Re: Logging & Construction Equipment
Thanks Lou for posting the pictures. Sure had a great time moving dirt with you two. The FWD is a tough truck and it survived the roll over, never even broke the mirror off. I'm pretty sure we moved about 42 loads until Greg put that big one on by packing it down. Those screw drives are tough tho, as it still lifted the box crammed like that. Go FWD!!!
Old 07-30-2013, 12:01 AM
tracksntreadslou's Avatar
Got together with rob and greg yesterday and did some more work in Gregs big construction park Project ..greg had some radio problems with the excavator so we ended up double teaming with the two Dozers ..we backfilled the N/W wall for a while and I ended up getting stuck a few times ..The D8 can pull good too ..thanks greg
Old 07-30-2013, 12:06 AM
took a few videos as well
https://www.youtube.com/watch?v=eT0Rl25pgGI
https://www.youtube.com/watch?v=uNNF5-HwiaA
https://www.youtube.com/watch?v=qYuarT9beQA
Old 07-30-2013, 12:45 AM
Looks like a good time! Maybe I should come up on the long weekend hey Lou.
Old 07-30-2013, 01:47 AM
I think that pile of dirt would take a while with that big machine of yours ..I think Gregs away for the long weekend ..Be fun to have you come up though
Old 07-30-2013, 07:18 AM
Seems to me there is something else that I'm supposed to do this weekend...Oh yeah that's right, I'm getting married... I'll get up there sometime though....
Old 07-30-2013, 01:36 PM
Cool videos, Lou. Your IH TD25 is a really nice model. I've always liked it. Something different then Caterpillar yellow machines, but Greg's dozer is a great model too. I'd be glad to own either! Looks like you had a good time.
Old 07-31-2013, 04:25 PM
Fierce Hitachi Fierce Hitachi is offline
Fierce Hitachi is on a distinguished road
Excellent stuff, makes me really really want a vario!!
Old 08-17-2013, 09:22 PM
Thanks guys ..I can easily kill 4 hours hanging out and moving dirt or logs with greg and rob ..As you can see i have been getting the dozer back into the operating mode ..i used to have planatarys in the sprokets and they wernt sealed enough ..They would get plugged up so I got rid of them ..some of the photos you can see the new hubs ..works much better but a little fast ..may order a couple sprokets and gear it down a bit more .I was also not quite happy with the blade up/down travel and finaly got around to swapping out the cycinders from 2" to 3" travel. much better
Old 08-17-2013, 09:29 PM
I also started on a ripper ..nice having a cnc to cut parts
Old 11-12-2013, 12:10 AM
decided to drag out and dust off this old prject I started a few years ago ..sure helps with cnc ..I gave it a try a making a circle inside gear and it turned out ok ..the pitch is a bit big but i was using a 1/8 toolbit so the was the radius I could use .
Old 11-12-2013, 12:48 AM
Looks good Lou! I like how you have incorporated an old road sign into the frame. You better get busy though. Don't you have a gravel truck to build?
Old 11-12-2013, 02:24 AM
Kingcam2's Avatar
Kingcam2 Kingcam2 is offline
Hi Tracksntreadslou
Your International TD 25 dozer did you make it your self or did you buy it as a kit off some one?
I like how it looks as is has a old school look to it.
Regards from Cameron.
Old 11-12-2013, 07:57 PM
The parts look pretty crisp!
So how many hrs do you have logged learning your cnc to get this far Lou?
Old 11-12-2013, 10:14 PM
Thanks
Its important these days to recycle ..too bad that guy drove right though where he was supposed to stop where the sign used to be ..lol
Originally Posted by Kingcam2 View Post
Hi Tracksntreadslou
Thanks Cameron ..It pretty much all scratch built..the tracks were source From Fetchner ..Im pretty much old school ..Mabe a D9 G a few years down the road
Thanks Joe ..The little tag Has very little backlash..Im getting much more cofortable on the CAD program..Learning a few 3D parts as well..The main thing with these things you have to remember is the it makes mistakes if you tell it to..I broke about a half dozen tool bits learning ..I have about 200 hours on it now ..the first 100 took in setting up and installing limit switches ..Sure glad they are there ..Now with the way its set up when I first start the gcode program if there is some thing not correct in travel the machine wont start traveling ..Very cool ..im realy ejoying this ..I do want to have a bit bigger manual milling machine at my disposal one day ..
Old 11-16-2013, 11:41 PM
dirtpusher9's Avatar
Moderator
Very nice, Lou. I thought you scraped this project many years ago. Glad to see you back on it I look forward to your progress.
Old 11-27-2013, 11:59 PM
Good to see you following this build .I think you mentioned that you ran grader quite abit as well...wont be quite as detailed as Rob or Ari but i am hoping it will do the job heres a bit of progress
As you can see I machined the slides in one complete peice so that everything would stay true when i bolted this to the blade ..i then cut the small tab off that hold the two slides together
Found a chunk of 3/4 and got the taig hogging out
Big 1/4 scales mounted for the articulation
http://s181.photobucket.com/user/tra...1b5f6.jpg.html
Thats all for now
Old 11-28-2013, 12:59 AM
Trucker_Jo's Avatar
Lookin good!
Jarrett
Old 11-28-2013, 01:07 AM
RCLogger's Avatar
RCLogger RCLogger is offline
Coming alone very well Lou. How many functions are you going to have ? And how many are going to be spools?
Greg
Old 11-28-2013, 03:14 AM
Awesome! I love the CNC machined parts! Maybe someday I'll be able to make something as cool as your grader. Looking forward to the updates, Lou.
Currently Active Users Viewing This Thread: 139 (0 members and 139 guests)
