Old 12-29-2013, 01:05 AM
blitzk's Avatar
blitzk blitzk is offline
blitzk is on a distinguished road
Default Re: King hauler Dump Truck
New box looks killer 22, this rig is lookin very good!!!
Old 12-29-2013, 09:29 AM
22fatcat's Avatar
22fatcat 22fatcat is offline
22fatcat is on a distinguished road
Thank you, yea sometimes it's just easier to start over.
Old 12-29-2013, 03:01 PM
dabears's Avatar
dabears dabears is offline
Wish I could bend metal like that! Box is looking good!
Old 12-29-2013, 05:33 PM
22fatcat's Avatar
Thanks, I am lucky to work in a shop with lots of good tools.
Old 12-29-2013, 05:42 PM
22fatcat's Avatar
Now I need to make a bumper and tail light assembly and finish off the box. Not sure if I should paint the box or just leave it raw. [IMG][/IMG]
Old 12-29-2013, 09:15 PM
That looks awesome. Nice work on the new dump box! It's quite a bit nicer than your first attempt. Absolutely nothing wrong with giving things a second or third shot, when you don't get the results you want the first time.
Old 12-29-2013, 10:43 PM
22fatcat's Avatar
Thanks Espeefan, I usually end up making things twice especially when bending is involved.
They are the same parts, but I was more careful when I bent them and i welded the bottom up higher.
Old 12-30-2013, 12:25 PM
BRICKNICK's Avatar
I say leave the body raw and polish it. And just my two cents I would add cross memebers to the side of the dump box to add to the realism. That's just me being a stickler, either way it still looks great as it sits.
Old 12-30-2013, 02:13 PM
dabears's Avatar
I saw leave it raw or polish it
Old 12-30-2013, 02:39 PM
22fatcat's Avatar
Hey Bricknick, the box that was my inspiration has the sides smooth like this one, Ox truck bodies makes one that has the flat sides, I went back and forth on the cross members or smooth sides. Thanks for the input its nice to get other opinions.
Old 01-03-2014, 10:00 AM
ptebbe ptebbe is offline
ptebbe is on a distinguished road
Do you think the screw drive works better than the Frigelli? More powerful?
PT
Old 01-03-2014, 06:09 PM
22fatcat's Avatar
PT
I was using the L12 and it would lift the box nicely but if you added any weight it would not lift it. I could have relocated it to get more leverage but then it would not go all the way up. So yes the screw drive works better but its kind of slow but will lift more weight, I have not tried to see how much it will lift yet.
Old 01-04-2014, 11:20 PM
22fatcat's Avatar
Well here are some more photos of the king hauler dump truck. I am very happy with the way this is turning out. This was a pretty fast build, now I can slow down and add things along the way like bumpers and lights and things like that. Now I just have to keep at it, it's only been about five years since I started the excavator that sits behind it. I now have all the parts to finish it just need to do it.
[IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG]
Old 01-25-2014, 02:24 PM
22fatcat's Avatar
Hey guys, I have a question about antennas. What are most of you using for the antenna? In most of the pics I do not see any just wondering any input is welcome Thanks
Old 01-25-2014, 03:16 PM
Supermario's Avatar
I got my antennas from garden trucking. He offers 2 styles.
http://www.gardentrucking.com/produc...=10&startAt=11
Truck is lookin great btw. Keeping my eye on this build.
Mario
Old 01-25-2014, 03:27 PM
22fatcat's Avatar
Mario
Thanks Mario, but I actually meant the the antenna for the RC receiver
Old 01-25-2014, 03:47 PM
22fatcat's Avatar
I have decided to try my hand at styrene and make a new front bumper I also added a ladder to the side of the dump body [IMG][/IMG][IMG][/IMG]
Old 01-25-2014, 04:19 PM
Supermario's Avatar
sorry, my mistake. I've seen radio antenna on ebay for cheap.
Mario
Old 01-25-2014, 05:04 PM
The dump truck is looking great. That's a nice lowboy trailer too. From PMD?
For radio antennas, if you have a 2.4 giga-hertz receiver, the antenna should be short enough to hide underneath the cab, without any issue. If you are using an older style 75 mega-hertz radio, you can still fit that antenna under the cab as well. Get a piece of lexan sheet, plastic sheet, styrene sheet, or anything else that is similar and not made of metal. Drill a bunch of little holes into the material of your choice and weave the antenna in and out of the holes, taking care to keep the antenna from being bundled against itself. Or you could also take a regular plastic antenna tube, run the antenna up the tube, out the end, then leave a little slack at the top, and wrap the extra down the length of tube, tightly, and make the wraps close together, but again, not over the top of itself. A piece of heat shrink tube over the wraps will keep it all tidy and in place. If you make enough wraps, your antenna tube should still be short enough to fit inside the cab or hood. Mount it horizontally, if you have to. You might notice a slight decrease in the radio reception range doing it this way, but in my past experience it's barely perceptible. Most of the time we run trucks and equipment close to ourselves so we can see the action! Decreased range, if any, shouldn't be an issue.
Old 01-25-2014, 05:23 PM
22fatcat's Avatar
Thanks for the info I like that idea.
Tags
dump truck, firgelli, king hauler, tamiya
Currently Active Users Viewing This Thread: 50 (0 members and 50 guests)
