Old 07-14-2014, 11:01 AM
BRICKNICK's Avatar
Default lowering your stock tamiya suspension?
Now I've dropped my king hauler in the front which looks great but it rides a little high in the back, how do you guys get a bit of drop out of the rear suspension? I've been looking for a thread because I know I'm not the first guy to ask this but I cannot find a previous thread.. A little help or input from you guys would be greatly appreciated. Thanks......Nick
Old 07-14-2014, 01:18 PM
TRUCKMAKER's Avatar
Default Re: lowering your stock tamiya suspension?
You might try adding F350 spring leaves, TamiyaUSA has them in various lengths 4 to a package for about $6 pkg. depending on length ordered.
Old 07-14-2014, 07:46 PM
TRUCKMAKER's Avatar
Sorry Nick I posted this in the wrong thread, but I was thinking about your issue. I guess I would mount the suspension higher on the frame which would actually lower the over all stance.
Old 07-14-2014, 09:44 PM
bigford's Avatar
bigford bigford is offline
you really cant with the stock set up
the center pivot plate is almost at the top of the rails.
I would try to remove a few springs or try to bend the leaf flatter
Old 07-14-2014, 10:03 PM
TRUCKMAKER's Avatar
That is true bigford but the suspension plate is very easy to modify to lower it and if you remove spring leaves you won't be able to carry much of any weight at all.
Old 07-14-2014, 10:34 PM
Lmackattack's Avatar
It's hard to lower the rear of the truck as the axels are bulky and they will hit the bottom of the frame rails with any sort of adjustment.
The only way I could see to get the rear lower would be to flatten out the rear springs and let the axels bottom out on the frame. This should give you about a 5mm drop?
Both my dump trucks with a load on will bottom out completely. They get around just fine
Old 07-14-2014, 11:19 PM
Tamiya Cowboy's Avatar
you an flatten the springs or go to Russ's air ride make sure either way you cut off the little stopping tabs on the tops of the axles so you get more travel..
Paul W. "Tamiya Cowboy"
Old 07-15-2014, 07:39 PM
Just a heads up
I cut those tabs off on my dump trucks axels and yes it allows the springs to flatten out and more travel is there but then I had to put the 4 shocks back on to limit its articulation. I found that when I cut those tabs off that the inter axel driveshaft would sometimes pop out of the drive cup when the truck was off roading. I tried a RC4WD scale truck driveshaft and it would slip out as well.
Old 07-15-2014, 08:01 PM
mavrick0 mavrick0 is offline
mavrick0 is on a distinguished road
Depending on the how much you dropped the front end how about just going with a shorter tire in the rear?
Old 07-15-2014, 10:49 PM
Originally Posted by Lmackattack View Post
Just a heads up
You are correct and the same thing happens when you add more leafs to the rear spring pack as well. It raises the frame from the axles allowing more travel and the center shaft falls out.
Old 07-15-2014, 11:21 PM
BRICKNICK's Avatar
Well guys thank you for all the tips, I'm gonna try to shave the tabs off the diffs n flatten the leaf springs a bit.
Old 07-16-2014, 12:41 AM
Stuff's Avatar
Stuff Stuff is offline
lol my globe has flattened springs. but thats from hauling a few hundred lbs of steel on the back.
my YouTube is -
Subscribe!!
My Facebook -
