Old 11-23-2010, 10:31 PM
td9clyde td9clyde is offline
Dozer Builder
Default Re: Moxy articulated dump truck
this is going to be one awsome build i can't wait to see the building and the pics to come
Old 11-24-2010, 01:08 AM
Originally Posted by tracksntreadslou View Post
Hey jordy heres a few pics of when i was building
Lou, that looks very clean and is an excellent idea! I'm curious where the large gear came from. If you can't have hydraulic steering, this looks like the next best thing, for sure!
Old 11-24-2010, 09:52 AM
kerst's Avatar
kerst kerst is offline
Wow! Nice construction!
kerst
Old 11-24-2010, 01:38 PM
steamer's Avatar
steamer steamer is offline
Back on post #16, Lou put up a link for the servo.
http://www.servocity.com/html/spg755..._rotation.html.
The unit comes as one piece including the gear and just plugs into your receiver. They use these as the house swing on their excavators too as they support 200 lb laterally. The one Logger uses is 6 rpm.
Rob
Old 11-25-2010, 03:08 AM
Thanks Rob. I didn't actually visit the link. I thought the link was to the servo alone, and that Lou built the rest of the steering mechansim. That is a nice unit.
Old 12-05-2010, 09:30 PM
TheMachinist's Avatar
Just an update.
No I haven't dropped off the face of the earth. I'm busy waiting for parts to arrive before I start the build.
I will update as soon as I have something picture worthy.
Thanks for the great input though I got lots of great ideas.
Old 02-17-2011, 10:33 PM
Finally. I have my Mil spec tires and motors for the ADT. Now I just have to reorder the Aluminium for the rims as I used it all up on a customers job.
In the mean time I have been busy.
I built a Bruder loader following Smallhauls build thread. I have a new appreciation for the engineering that goes into a project like that. It's not all cut and dried.
Old 02-18-2011, 02:38 AM
Video?
Old 02-18-2011, 09:30 AM
SmallHaul's Avatar
Attachment 533
Your loader looks good. Aren't they a blast to run.
Scott
"No load is too Small"
Old 02-18-2011, 10:53 AM
Small haul
They absolutely are. I,m going to follow in your footsteps again and build a Tonka dump truck, I just picked up a 1960 Tonka with a red cab and green box from a friend. He had it in his office in a shelf. It even has the origional packaging.
Old 03-05-2011, 10:30 PM
Finally some progress on my ADT. I got the rims roughed out and started on the drive hubs. Also gathered the material for the rear frame.
Old 03-05-2011, 11:59 PM
steamer's Avatar
Jordy. Your rims look very real. did you copy them from the full size machine.
rob
Old 03-06-2011, 12:08 AM
rob
Yes I did copy them but the bolt flange is a little off of scale because of the electric drives. Once the "planetary" housings are in place they will look pretty close to real.
Old 03-06-2011, 02:14 PM
tracksntreadslou's Avatar
Nice machine work Jordy..Great to see you get back on the moxy build..Do you plan on using scale bolts to fasten things together?
Old 03-10-2011, 06:04 AM
I wonder if the Castle Mamba Monster ESC will power 6 gear motors running a 6S lipo?
Jordy
Hi Jordy,
Nice start on the wheels and the tyres look good as well. One thing, you mention a 6S battery., i assume this is similar to what you use in your heli's. 22volts is very high for ground based vehicle.. it'll be speed demon!
Elliot
Elliot.
Old 03-10-2011, 11:15 AM
Originally Posted by elliot330 View Post
Hi Jordy,
Elliot
Yeah 6s would be over kill. I have a Sabertooth dual motor ESC for the drives and will run a 3s pack at 11.1 volts. Now that I see the thread on Robbe hydraulics I might have to rethink the dump mechanism.
Jordy
Old 03-10-2011, 11:23 AM
That's similar to me, I'm going to use a 3S lipo with a standard Esc, connected to all 6 drive motors, forgot to add, I only went with standard Esc as I want it to control the lights etc.
Elliot.
Old 03-13-2011, 09:16 PM
More progress: the hubs and rims are done as is the front axle tube.
Old 03-13-2011, 09:32 PM
Nice production work.
Old 03-13-2011, 09:57 PM
Our shop has an old lathe that nobody uses anymore so I can set up before and after work with out interfering with anybody and leave stuff set up during the day.
The lathe is a 1946 Dean Smith and Grace that is all worn out and really clumsy to operate but it handles the small stuff easily.
