Old 07-14-2015, 09:06 PM
TRUCKMAKER's Avatar
Default Re: LilGiantsConstrCO
Is there crop insurance for something like that?
Old 07-14-2015, 09:34 PM
There is... but the premiums are ridiculously expensive & I rarely get such weather, so I have no insurance for immediate compensation.
I'm involved with a different gov't program that I can seek compensation from, 2 or 3 yrs from now... so I'm not totally screwed.
Old 07-14-2015, 11:53 PM
On a brighter note, I got a goody box from my buddy Frank today, several little mini projects to get cracking at.
Old 07-15-2015, 12:08 PM
Niceee! !! Looks.like you got your work cut out for you.
Old 07-25-2015, 09:44 PM
Yes indeed Shawn, got a few little projects to get after, for sure.
This past week I loaded the deck trl a couple more times to get the last dirt cleaned up in front of house... round about 10cy was there by the end of April & started moving it right after spring planting May 22nd.
The last couple of cubes at the back of shop (north end), still needs more dirt to elevate the grade, probably won't happen this yr.
Anyways... moving back inside, out of the elements & the bugs!!! YAY!!!
Here's the official start of the Lil Big Dig tunnel project.
For now, the dug dirt will be dumped & levelled into the north end of lean-to to level the grade, as it drops a little over a foot at the north end... short haul!
If I recall my calculations from last yr correctly, this other back room needs just over 20cy to bring it up to level with the cement of the middle room. Pretty much all the dirt from the tunnel will fill these two rooms, won't be much to haul out, if any.
Old 07-25-2015, 10:18 PM
Supermario's Avatar
Great to see the new project has begun! it's been an exciting year for the rc construction site forum and great to see so many getting into it
The first tunnel build.... Only seems appropriate that you would be the pioneer and spearhead this new RC endeavour Joe.
I got my popcorn ready and looking forward to the next couple months / years ? might be a short haul but it's still gonna be RC epic!
Old 07-26-2015, 05:30 PM
I was measuring outside between house & lean-to this morning, tunnel will be about 11ft in length x 5ft width x 7ft height = 14.26cy + elevated grade to ground level inside lean-to, maybe another 10cy.
I hope I can it make it last 2-3 yrs Mario, cause after this I don't know what I'll do for another dirt work project, not indoors anyway.
Old 07-26-2015, 07:48 PM
calum_scania's Avatar
calum_scania calum_scania is offline
calum_scania is on a distinguished road
Joe this is brilliant! I can not wait to see your progress keep up the good work
Calum
Old 07-27-2015, 12:58 PM
modelman modelman is offline
Hi joe-another great project. This should be fun to watch!! I'm not real clear on how the direction and lay-out of the tunnel will be but I am sure it will become clear as you get into it. You said all the dirt will stay inside. That should be some short trips for dumping and save on batteries. I will be watching.
Old 08-04-2015, 09:44 PM
I had my 1st ever visitor from the forum at my farm last week, tracks&treadslou stopped by while visiting his son a few hrs away.
Lou showed me this great photo trick using the camera on my IPhone for a panoramic shot.
Basically Tom I'm going straight south 11ft to where I come out in the basement just behind the water heater, numerous vids in the past, "Digging out under West Porch" & others.
This is what I've gotten done in the last week, hole is 14" deep x 5ft wide & approx. 4ft long.
The pile in the back smoothed out with the dozer...
Over the weekend I was trying to fit these packer wheels to the 4206... I got these from IHSteve about a yr ago.
...I was originally going to mount them on the Fumotec WA 500 loader, that I haven't built yet, the axle profile is a wee bit different, so I have to machine 12mm width collar so I can position the cleaner bar exactly so... got one wheel mounted so far, hopefully get some time this week to get the other three buttoned up & get busy packing.
I got this drawbar packer from Dieselchopper last October while attending the Model Engineering show in Estevan. I tried to pull it with the 4206 with just rubber tires & it just sat & spun, the packer is that heavy to pull. Now with 10# packer wheel on each corner, should be no problem!
Anyways, about a month away from harvest, lots of hail from mid June to mid July creating delays, but lots to do to get ready. Plus I don't want dirt piles in the electrician's way while he installs lights & plugins, hopefully he shows up in the next week to get that done.
Old 08-05-2015, 02:26 PM
Joe-I like that panoramic picture. Your north & south etc. directions is what gets me confused but that's okay. I will just watch your progress and I am sure you have it planned out perfectly. Could you explain a little about how the digging will proceed. I don't think excavators do too well on a flat wall (do they) or will you dig down and then move and dig down again. I like the packer wheels and the pull packer. Those should do a good job.
Old 08-05-2015, 03:37 PM
steamer's Avatar
steamer steamer is offline
JOE, what's going on!! You didn't put him to work for his room and board!! LOL!! Looks like your making a great start and I will be watching for more progress
Rob
Old 08-05-2015, 03:40 PM
Dieselchopper's Avatar
Packer should work good now. Lol
Old 08-05-2015, 06:14 PM
You seem to have a lot of nice surprises waiting for us
Old 08-05-2015, 07:21 PM
TRUCKMAKER's Avatar
Talk about my table being full!
Old 08-05-2015, 08:56 PM
Cooper's Avatar
Cooper Cooper is offline
Looks like two guys up to no good!! Lol!! Shop has come a long way, should be making them Canadian winters a lot more enjoyable!! And glad you were able to secure that tunnel contract. Should be a good job for the company, and keep those Union guys running your equipment happy!! keep the pics of the new build coming.
Looks good joe!!
Old 08-07-2015, 12:34 AM
Tom, the length of the house is east/west & the length of the shop is north/south, exiting the SE corner of the shop into the NW corner of the house.
I'll dig down about 16 inches below the cement & then all the way across till I get to the basement, then dig down to the 7ft level in layers. On the to do list will be a water tanker body on the back of the green GL with a remotely operated water cannon to keep the face of the wall moist as I dig across. I think the ripper tooth & dig bucket of JD850 will do fine.
Rob, Lou's visit wasn't 24hrs even, had just barely enough time to give him a quick tour.
Got a few projects in the works Emil & a good area now to get 'em done.
No kidding Kent, didn't take long to use up 48ft! Gotta do some more shelving & organizing.
It was quite enjoyable to be in there last winter Cooper, and now with a dig project in there too, perfect!
The width of the packer is surprisingly just right Shawn, it fills the gap between the packer drives, almost like it was planned!
The electrician came today to put in the lights... oh so sweetly bright in there now!
Hole is 5ft x 5ft x 1.15ft deep = 28.75 cu ft... just over a cy done already! ...about another 30 some to go.
Old 08-07-2015, 07:38 AM
They should pack your lifts nicely ,Joe I'm planing a long road trip west in the next two years
Old 08-07-2015, 02:41 PM
Dam that does look pre planned. Hope it's working well now.
Old 08-09-2015, 05:18 PM
RCLogger's Avatar
RCLogger RCLogger is offline
Hey Joe
Looks to me the two fellows in the photo should be behind BARS ! Looks like they are up to no good...lol
Greg
Currently Active Users Viewing This Thread: 73 (0 members and 73 guests)
