#241
Very nice tires
Is there any information online, how they were produced?
#242
At least there used to be such information. However, it was written in German and, the last time I saw it, the picture links were dead. I'll try to find the article again.
Stefan |
#243
Sorry, I´ve only been able to locate this German posting on the tire making (see post #8). And you have to be registred
#244
Thank you Stefan, i will check it!
Edit: for some reason, the link is not working for me. Last edited by AbelVincze; 06-12-2016 at 04:24 PM. |
#246
Thanks, it works (just have to wait an admin for registration approval...)
#247
Here is the continuation of post 218.
Setup for drilling and inside turning of the eyes: Setup for making parallel the side faces: Tapping M1.6: Making the "covers": Inserting igus iglidur bearings (flush cut after bottoming out): Assembly: It remains to shorten the necessary screws. Thanks for looking, Stefan Last edited by Stefan; 11-11-2017 at 10:41 AM. Reason: Link repair |
#248
Sure you're not building a 1:1 grader? I'm not sure what I appreciate the most; your patience or handcrafting skills
#249
it is very very nice work good on you a master at work
#250
Stefan, you'r setting the bar very high now. Those details will make this grader stand out. As mentioned above, is this 1:1??
/Dan |
#251
Thank you Emil, Jack and Dan! Yeah, trying to keep it scale. 3D printing takes you a long way, but you still see the layers. Suppose some careful grinding could take care of that.
Now, machining of the lift cylinder arms has been almost completed. Just need to fill out some shrink holes (and grind out the layered structure ).Drilled and reamed to 14 mm. Bushing with a 12° conical hole for an indexing lock pin. The indexing lock pin mechanism (still to be made) will be attached on the rear side of the plate with the "key hole". Cheers! Stefan Last edited by Stefan; 11-11-2017 at 10:46 AM. Reason: Link repair |
#252
Amazing!
#253
Some serious fabricating skills you have my friend!
#254
Piece of art!
#255
so i hope you have been makeing atleast 10 of each part because i am sure 9 other people besides myself would realy like to be your new best friends lol
#256
Wow, this is amazing work, keep it up it looks fabulous, mail I but one of those friends that gets a completed version grader PLEASE
#257
I have always wanted to make a model as close to scale as possible. I'm more oriented towards the mechanical workings and trying to relate that to our scale versions. I know you have a tremendous amount of hidden work, set up, jigs, precision measurements, ect,,,,, but this is really paying off!! Very nice!! An inspiration for me when I think it can't be scaled down.
Looks really really good Stefan !!
#258
Nice work
#259
Outstanding work!!! What are the extra 2 holes in the covers that you just made for? Could they be for jack bolts to remove the covers with? Just a guess!!!
LYNN |
#260
Thanks very much guys. Yes, Lynn, you are right. Those covers sits quite tightly. The specification says "blade down force capability 11 058 kg (24,457 lb). Don´t think the screws alone would cope with that for a long time (guess the real screws are 1/2 inch dia.). I use M1.6 (about 1/16 ") in the model.
Stefan |
| Tags |
| 1:8, grader, volvo |
| Currently Active Users Viewing This Thread: 74 (0 members and 74 guests) | |
