Old 07-07-2016, 03:09 PM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Default Dozer Upgrade
I want to upgrade my die cast dozer conversion and thought I might try replacing the track drive servos with right angle gear motors or maybe some DIY worm gear arraignment.
Anyone have a source for small right angle gear motors or worm and matching spur gears? I'm dealing with a small machine, so the typical windshield wiper style is going to be way too big. My two standard size servos just BARELY fit between the side frame rails.
I have seen this on servo city but it looks a bit to weak for my application.
https://www.servocity.com/html/140_r...l#.V36akPA8KrU
Jim
Old 07-07-2016, 03:14 PM
Bo Wallen's Avatar
Lightbulb Re: Dozer Upgrade
This got e few interesting parts. http://www.robotshop.com/en/motors-actuators.html
Old 07-07-2016, 03:16 PM
Bo Wallen's Avatar
This one got it all.http://www.sdp-si.com/#slide-two
Old 07-07-2016, 03:27 PM
Rvjimd's Avatar
Default Re: Dozer Upgrade
Thanks Bo, lots of stuff to look at both places! Might be fun to try and build a gear box with right angle or worm gears.
I see on the second site they list the worm gears as right or left. Does that mean I should NOT try to turn them backwards for reverse gear motion of the dozer? I don't understand exactly how they work? I could probably use right angle gears. Is there a reason to use one vs the other is a setup like I'm planning?
Jim
Old 07-07-2016, 03:33 PM
Bo Wallen's Avatar
You turn motor clockwise / right : if you want the result to be opposite use left turn and so on. If you use worm gears you got brake for free.
Old 07-07-2016, 09:12 PM
You'll get additional reduction with a worm drive vs straight cut bevel gears in a right angle gearbox. But (maybe it goes without saying) precise centering of worm gear backlash over main gear can be difficult to achieve too.
Old 07-08-2016, 11:24 AM
Rvjimd's Avatar
Has anyone ever tried to build/run a track machine with a single motor driving a differential and brakes for steering? That's how the full scale stuff works correct? Or at least the old time stuff I think?
Jim
Old 07-08-2016, 12:24 PM
bigford's Avatar
bigford bigford is offline
my old tamiya sherman tank is like that. its real jerky
like jam on the brake ans swing left...
Old 07-10-2016, 12:52 PM
Jack3M Jack3M is offline
Jack3M is on a distinguished road
Jim
Actually I think it is slipping clutches over braking
Old 07-10-2016, 01:28 PM
bigford's Avatar
