Old 08-31-2016, 03:05 PM
t-meggs t-meggs is offline
t-meggs is on a distinguished road
Unhappy Transmitter control options
Ok so i got the dump working great.
I have a 6 channel tx/rx and want to control the up/down from it. When I attach the dump motor to any channel it only works in one direction and then have to swap black for red for it to work in opposite direction. I tried using white from rx but does nothing.
Tried various combos and doesn't work.
dump motor is standard 2 wire red/black. rx standard red/black/white.
I know it's something simple, but I am losing it.
Definitely due to the nut house.
T-meggs
Old 08-31-2016, 03:39 PM
bigford's Avatar
bigford bigford is offline
Default Re: Transmitter control options
What esc are you using??
You do know you need a second esc to control the
Dump motor
Old 08-31-2016, 07:53 PM
Nope that was the part that was missing. I had no instructions with this. I have been reading and Reg just emailed me.
Just not sure how to set up with second esc?
off of same transmitter?
Old 08-31-2016, 09:20 PM
bigford's Avatar
Unplug the red wire off the dump motor esc then plug the esc into a spare channel on the rx. Then you need to splice the power leads together. My dump trailer set up runs 3 esc this way. 1truck) 2dump) 3tarp)
Old 08-31-2016, 09:22 PM
bigford's Avatar
I use a dx9 with a right dial knob that I use to raise and
Lower the box and a 3 way toggle for the tarp
Old 08-31-2016, 09:49 PM
ok will try. thanks as i am new to the big rigs. thanks for being patient.
Old 08-31-2016, 10:18 PM
bigford's Avatar
It's all good we were all new at first..
Old 09-01-2016, 09:51 AM
uggh. ok so i did the following.
1. connected esc lead to ch6. removed red wire. leaving white/black in correct alignment.
2. cut of tamiya battery plug and spliced the red/black together.
3. made sure switch is in on position.
4. attached esc out leads orange/blue to dump motor.
result: nothing. yes turned tx on and truck on. Second ESC shows red power light on but when i move dial it dims and brightens. no dump motor power at all.
Old 09-01-2016, 10:07 AM
bigford's Avatar
Both esc are on?
Old 09-01-2016, 10:09 AM
yes sir
Old 09-01-2016, 10:22 AM
bigford's Avatar
Will the truck drive like normal and just not dump?
Try swapping the esc around dump on the drive
And drive on the dump esc
Old 09-01-2016, 10:37 AM
Could you post some pictures of the wiring? What esc are you using on the dump? It is for a brushed motor right?
Old 09-01-2016, 10:40 AM
have to run out for a bit.
yes brushed motor esc tamiya TEU-302bk
will post pics and further when i return.
gotta go earn some $ to pay for my toys.
lol.
Old 09-01-2016, 10:52 AM
bigford's Avatar
Doing that right now in traffic
Old 09-01-2016, 11:18 AM
TRUCKMAKER's Avatar
Hopefully you spliced red to red and black to black not red to black.
Old 09-01-2016, 11:27 AM
X2!
Old 09-01-2016, 05:23 PM
Ok good news!
wiring completed, body mounted, test run a success!
even a car with two ladies stopped to watch.
Hmmmm, ice, cold drinks, all i need is a pool and i have a new use for my truck.
Thank you for the assistance.
File Type: jpg 20160901_161609.jpg (157 Bytes, 62 views)
File Type: jpg 20160901_161625.jpg (157 Bytes, 62 views)
File Type: jpg 20160901_161641.jpg (157 Bytes, 60 views)
Old 09-01-2016, 05:25 PM
pics not showing.
