Old 09-23-2016, 06:07 PM
DougH DougH is offline
DougH is on a distinguished road
Default Smoke systems?
Does anyone have suggestions for adding a smoke system to one of my trucks? I found this one for drift cars called the burnout demon and it looks like it might be adapted to route the smoke up thru the stacks. Any thoughts?
http://driftmission.com/burnout-demo...oke-generator/
Old 09-23-2016, 08:12 PM
Trucker Al's Avatar
Trucker Al Trucker Al is offline
Trucker Al is on a distinguished road
Default Re: Smoke systems?
This one looks pretty good. On ebay
http://www.ebay.com/itm/112036055150...%3AMEBIDX%3AIT
Alan
Old 09-24-2016, 02:09 AM
Us tank guys have had good results with the Tarr units. If wired through an ESC the fan is proportional to your throttle. You have 2 inputs, one for element power and one for fan power (which you'd tap into your ESC or off the motor.)
http://www.rctankelectronics.com/sto...moke_Unit.html
Old 09-26-2016, 07:15 PM
Nikaem Nikaem is offline
Nikaem is on a distinguished road
build your own
http://www.scale4x4rc.org/forums/showthread.php?t=25024
Old 09-26-2016, 07:33 PM
bigford's Avatar
bigford bigford is offline
I don't need oil residue on my rigs or anyone else's pass
Old 09-27-2016, 11:11 AM
Mech_Eng's Avatar
Mech_Eng Mech_Eng is offline
Mech_Eng is on a distinguished road
I have thought of experimenting with an electronic cigarette and some kind of a fan. They have some called "drippers", very simple and put out a lot of vapor. The liquid for the ecig can be purchased without nicotine and almost any flavor imaginable..... plus when you get an itch you can just take a drag off of your stacks! lol
Old 09-27-2016, 12:52 PM
bigford's Avatar
The boat guys use a water vapor system but there
Kinda large. Our problem is the tranny lines up with the stacks.
Old 09-27-2016, 08:16 PM
Hey mister, Why does your truck smell like candy? With the glycol foggers like the vape people use, would the a plain glycol base make your smoke smell like a coolant system leak?
You might be able to run one of the small fountain 'ultrasonic foggers' that just use water. Stick it in a small sealed water box that you plumb to the stacks. Not sure it they make lower voltage that 24dc, this was the first i found
. https://www.amazon.com/Etree-Ultraso.../dp/B0067XS2IG
Old 09-27-2016, 08:32 PM
bigford's Avatar
The boat ones look like the driftmission one but use water not oils. I always say black power white water
I run a factory c15 625hp cat and don't blow any smoke....
Old 09-27-2016, 08:50 PM
RexRacer19's Avatar
RexRacer19 RexRacer19 is offline
RexRacer19 is on a distinguished road
The smoke systems that the drift guys use are essentially e-cigs. You just need a coil, wick, reservoir, and a fan to move air. The most "smoke" is made using vegetable glycerin. It can be had cheaply in bulk and does not have much of an odor.
-Jeff
