| Construction News New kits & accessories offered in the world wide marketplace |
#81
So the majority of the model is now steel?
#82
Not sure, but it's very heavy. I think the counterweight alone is close to the Stahl. My friend says it's very nice to use.
#83
https://www.youtube.com/watch?v=brW1pwY4oUo
Install transmitter https://www.youtube.com/watch?v=pXODWKR7znc https://www.youtube.com/watch?v=AHM7pcPTUtw :-) Last edited by fabi; 01-01-2017 at 05:49 PM. |
#85
RC4WD now offering Volvo decals for the new excavator
![]() http://store.rc4wd.com/Volvo-Decal-S...0L_p_5271.html |
#86
Eagle now selling a light kit for the excavator.
https://www.aliexpress.com/store/pro...612.0.0.ETmZfO |
#87
Noticed CSMI is selling metal stone guard for the new excavator, looks good
![]() http://www.csmi.com.au/index.php?rou...d=313&mfp=path[73] |
#88
#89
What size are the clear hydraulic lines?
#90
Pretty sure it's 4mm ID. The smaller hydraulic tubing is 2.5mm ID
http://store.rc4wd.com/4mm-Heavy-Dut...ng_p_3598.html Specifications: Alloy Zinc and Alloy Aluminum Casting (except Track and Hydraulic Pump) Custom 8 Channel 2.4Ghz Radio Preinstalled High Intensity Light Sockets (Wire and bulbs are not included) Optimized Steel Hydraulic System Scale Driving Figure Ready (Not included) Steel Molded Tracks (50mm Width, 45 Grade Carbon Steel) Efficient Undercarriage Reliable Hydraulic Valve and Adjustable Pump Heavy Duty Hoses (OD 4.5mm Nylon, ID 2.5mm) Undercarriage May Rotate 360 Degrees (Endless) Powder-coated in Yellow and Grey Massive Brushless System (Including driving and turning) Hydraulic System 60A Brushless ESC, Driving and Turning System 30A Brushless ESC 270Kv Brushless Monster Torque Motor, Shaft dia. 3.0mm XT60 Power Plug Female Run Time: 20 Minutes based on 4200mAh, 11.1V Battery Steel Machined Oil Pump (60mm x 60mm x 93mm) Digging Force: 15kg / 33lbs Max Lifting Force: 70Kg / 154lbs Driving Speed: 360 Meter per hour Scale: 1:14 Length: 823mm / 32.4in Width: 234mm / 9.21in Height: 260mm / 10.2in 30 Days Limited Warranty Operating Oil Pressure: 2.5Mpa Inside Cab Length: 4.72in / 120mm Inside Cab Width: 2.55in / 65mm Inside Cab Height: 4.21in / 107mm Deadweight: 26Kg / 57lbs |
#91
Thanks for the reply. I thought the hose their selling on RC4WD was the smaller black line running to the cylinders on the 360L. I couldn't find the clear lines for sale anywhere.
#92
4mm ID http://store.rc4wd.com/4mm-Heavy-Dut...ng_p_3598.html 2.5/ 2mm ID http://store.rc4wd.com/2mm-Heavy-Dut...ng_p_3113.html |
#93
This is the smaller 2.5mm hydraulic line for comparison.
http://www.rcbrmin.com/index.php?mai...roducts_id=668
#94
Thanks for the help man.
#95
Does anyone know how i slow the pump speed down? what setting would that be on the radio?
#96
EPA (end point adjustment), that might be listed as servo adjustment in your radio menu. What % is the motor running at now? Lower it too much & the motor will behave a bit erratic & heat up esc... for lower hyd speed movement you could lower the EPA on your valve chs so it takes more stick throw to open the valve or use 2s lipo, but a lower voltage will slow down your track speed too.
#97
Try contacting Mario or DiggingwithMartin on youtube they will help you tune your machine right. Channel 5 is for the pump.
#98
Yea on the fly sky TH9X that comes with the 4200XL it's in the endpoint adjustment. Ch 5
and on mine list as the first FLP channel. I have 026% on and of course 000% off. |
#99
look up to my video for setting , pump and sticks |
#100
Whats the best way to change the fluid in the 360l? I see there is a screw underneath the tank but how do you make sure you get it out of all the cylinders?
| Currently Active Users Viewing This Thread: 6 (0 members and 6 guests) | |
