#681
Steve,
You got it all back together, ready for Cabin Fever right? See you in a week. Jim |
#682
Had to order another 2000 0-80 socket head caps screws.
![]() A frame going back together. This part still needs several angle braces added. That will come later when time permits. ![]() Walking shaft ![]() ![]() Machinery frame ![]() Shoes have paint ![]() Parts ![]() ![]() Assembly begins ![]() ![]() ![]() ![]() After about 16 hours got some more assembled. Not painting any brass parts yet. There is not enough time to get these parts done either ![]() Boom attached just had one heck of a time getting the suspension cables untangled.
#683
Steve isn,t it amazing what a little paint will do. Looks great keep up the great work. Ed
#684
Holy Chunky Mother of Hot Applesauce !!! Thats Beautiful Right there.
The Main Attraction at Cabin Fever Expo 2017
#685
#686
Looking good Steve-I see you are giving Walter Bennett a challenge on most bolts used (rivets).
I think I see a brake band on the rear drum. Is this a work in progress? Nice job!!
#687
Brake band is in progress. No time right now. This was one of the reasons for the tear down. Now I have the machining done on the main frame to attach the necessary parts. I was going to use servos to actuate the clutch and another to set the brake. Changed my mind because I think a servo will burn up if the clutch doesn't shift exactly as it should without binding. And if it binds, I can't hear or see it with all the outside noises at shows. I am experimenting with some lineal and rotary solenoids.
#688
Came across this video today of the first time out with my new Marion controls.
https://youtu.be/vEEWWk-L6lo . |
#689
Looks like a good time to me!
![]() Jim |
#690
Decided to spruce up the bucket with some red paint to resemble the ESCO bucket I duplicated some before this weekends "Big Dig" at the National Pike Show. Last time out at the Cabin Fever Expo, I had trouble seeing my bucket with the lighting there. There are still wear plates and better teeth that need made on this bucket but that will come some day.
![]() A quick dusting off in the sand blaster booth ![]() ![]() ![]() ![]() ![]()
#691
Sweet! Gona be fun watching that get dirty!
![]() See you Thursday afternoon! Jim |
#692
After years of searching I picked this little gem up this week. It took a long time to find just one but now I have two. One for each side of the boom.
![]() These are actual porcelain enamel signs Bucyrus-Erie had on their Bulldozer cable controls from the 1940's - 50's ![]() ![]() Here is the other one I have
#693
SWEET You lucky boy. Now it's Perfected. Looks awesome
#694
The bucket looks killer with some paint on. Did it help visibilty as much as you hoped?
But those signs are way over the top cool!
#695
The red bucket was much more easier to see. Shows up better in pictures too.
#696
The model is pure awesomeness in itself, but the signs and red bucket really do add something. Nice touches.
#697
Haven't looked at this thread in awhile and wow great work! I wish I had that good of a detailed bucket for my dragline build!
Question what are your motors running rpm wise, im trying to size my motors for my Marion 8750 and having a hard time figuring that out on speed and torque needed. Thanks! |
#698
My motors are: Swing-2500rpm 1/17hp 130vdc Drag- 500rpm 1/12hp 130vdc Hoist 417rpm 1/29hp 130vdc They are geared down to approx scale feet per minute through the gearing. The drag is too fast so I have the max rpm turned down.Someday I want to build the gearbox for the drag correctly using all the gears exactly like the 1:1 machine. I can also change my speed by changing the stick travel with the limits on the DX7 transmitter. |
#699
It has been very hard to find any time to focus on this due to being busy at work all the time.So I found some time to do a little work on my 9W before Cabin Fever. Since it was very hard to see last year at the show I painted the bucket last summer and I added some lighting to my boom. I bought these bolt LED's and turned them down to fit inside of some old Lionel flood light housings.
![]() Turning down from 11mm to about .360" dia ![]() ![]() 3 Lights installed
#700
Well I found a little time to break out my model again and get to some more parts that need made. I decided to make some roof trusses and get some cover on this thing.
I made a simple fixture to machine the "T" bars since you can't buy the size I need. ![]() A little scrounging around and came up with a cutter stack to mill these with a .040" web and flange. ![]() Four cuts to depth and they turned out nice. Bigger cuts caused some problems. ![]() A few ready for next step
| Currently Active Users Viewing This Thread: 25 (0 members and 25 guests) | |
