Old 09-09-2017, 09:18 AM
Mikhai Mikhai is offline
Mikhai is on a distinguished road
Default 1/14 TAMIYA King Hauler Dump Truck 6X6 chassis (Russia)
Hello, dear friends! I want to build a dumper. I took a truck tractor - 1/14 Tamiya King Hauler. First I built a chassis of 6x4. Now I will build a chassis 6X6.
Old 09-09-2017, 09:35 AM
Default Re: 1/14 TAMIYA King Hauler Dump Truck 6X6 chassis (Russia)
I like the idea of a 6X6 dump truck. How did you get the (looks like a standard Tamiya gearbox) Tamiya transmission to power the front wheels?
Old 09-09-2017, 09:45 AM
This chassis is 6X4! Here is the gearbox 1/14 Tamiya. For a 6X6 chassis, I used a gearbox 1/10 Tamiya Toyota Tundra 4X4.
Old 09-10-2017, 02:30 AM
The Toyota gearbox, is it a 3 speed like the King Hauler gearbox?
Old 09-10-2017, 03:06 AM
Skeeter! I will make detailed photos soon and show you everything. The dimensions of the gear boxes 1/14 Tamiya trucks and 1/10 Tamiya Toyota Tundra are the same.
Old 09-10-2017, 09:02 AM
Panther F's Avatar
I'll be following this!
Old 09-10-2017, 10:10 PM
Me too! Always interested in ways people go for a live front axle.
Old 09-11-2017, 01:21 PM
The first experimental model of a dump truck with a chassis 6X6 was assembled.
Old 09-12-2017, 02:28 PM
Installation of the front drive axle on the chassis 6X6.
Old 09-12-2017, 02:44 PM
I have two types of leading front axles - "1/10 Tamiya Toyota Tundra" and "1/18 Tamiya TLT-1". I installed the front drive axle "1/18 Tamiya TLT-1". The differentials for these two bridges are the same - 40/15. Differential of the middle and rear drive axle "1/14 Tamiya truck" - 40/15.
Old 09-12-2017, 03:12 PM
The front drive axle "1/18 Tamiya TLT-1" is mounted on a 6X6 chassis "1/14 Tamiya King Hauler" dump truck.
Old 09-13-2017, 07:27 AM
Panther F's Avatar
Wow, the things you learn right here on RC Trucks.
Nice work with GREAT pictures, very clear & detailed PLUS one heck of a cool project.
Old 09-13-2017, 09:14 AM
Thank you so much, Panther F!
Electric engine for lifting the body of a dumper.
Old 09-14-2017, 12:01 AM
Yes, thanks for the great pictures and explantion of parts used. Your going to have a great rig there.
Old 09-14-2017, 01:49 AM
Thank you so much, TheBennyB!
In order to build a dump truck I used a Tamiya 1:10 Toyota Tundra High Lift 4005126 (4005127) Chassis Frame L (R).
Old 09-14-2017, 02:18 AM
Old 09-15-2017, 07:31 AM
Lifting mechanism of the dump body.
Old 09-15-2017, 10:53 AM
ditchdigger ditchdigger is offline
ditchdigger is on a distinguished road
A couple of things:
1) you need the truck kit shocks on at least one axle of the tandem so the axles don't over articulate & the dog bone between them falls out.
2) your tie rod on steering axle should be behind axle for correct steering geometry, Google Ackerman principal.
Old 09-15-2017, 01:13 PM
Thank you very much, Ditchdigger! I got it. I'll do everything as you wrote.
I can not understand what it is? - "truck kit shocks". Shock absorbers?!!! (Damper, absorber, bumper, buffer, snubber, dashpot).
Old 09-15-2017, 03:59 PM
Shock absorber. Your pic in last post shows the stock version... But the last pic, as well as your own build, the frame rails are upside down, not certain the hole position in frame for shock absorber will correspond correctly too.
