#2241
Hey Cooper, awesome work! I build offshore oil rigs for a living, quite often the design basis is called "design-build", meaning we start construction way before design is complete. In my experience, it works well but we typically see up to a 30% revision rate based on the count of drawings issued......the idea is you can actually build a project quicker by designing at the same time you build. I'm doing the same in my garage now. I think I enjoy the cam more than the cad.... I ordered a fogbuster today, do you have a particular coolant you like?
#2242
#2243
#2244
And finally the dog was on my side of an argument!! Yes he is chewing on my wife’s head!! Big puppy!! Just had him to the vet and he weighs in at 189#!! Hence the Great Dane construction company
. ![]() And also made the lift cylinder mounts for the lift arms ![]() They are made to be a press fit into the arms and just some small hardware to give some insurance to stay put. In the pictures I don’t have them pressed in just located for pictures. ![]()
#2245
And the framework between lift arms. This part was difficult to cam and to machine, have 5 different set-ups and about 4.5 hours in it. This is a pic mec-eng, where I do use flood coolant because I’m using a 3D toolpath and ball mill. Better finishes.
![]() From block to part ![]() ![]() And the square outside will be welded flush with lift arms, and they are a press fit also. ![]() ![]()
#2246
Great progress! Wow.
Heh cute, big puppy
#2247
Just.. WOW! That will be one strong and beautiful loader!!
Stein :-) |
#2248
#2249
![]() ![]() ![]() ![]() ![]() ![]() ![]() Some nice eye candy you've fed us cooper! That things going to be the bestest thing since sliced bread! |
#2250
Hi Cooper
![]() ![]() ![]() Great work as ever loving the CNC work. Just taken delivery of a small 6040 CNC So will be starting to produce some of my items in metal now instead of plastic. Loving Fusion 360 for my 3D printing so how have to make the move to use the CAM part for the CNC machine Keep up the good work and thanks again for sharing with us all
Regards Mark Over the Pond in the UK Member of Ribble Valley Radio Controlled Truck Club my weather station To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#2251
Thanks, I have no experience in anything else other than fusion 360. But I do think it is fairly easy to figure out/learn and most of all free!!!!!
#2252
Started making the mold for tires. I’m using a five gallon bucket cut up for the mold walls. And this is just one half with the printed master tire in it. Have to make other half then will be able to cast tires.
#2253
Printed a test piece to give me an idea of range of hydraulic cylinder travel. And this piece is going to be 3 different setups , top, bottom and slots on sides. At least this time I am designing with capiablities of macheing in mind and also with the cutters I have.
![]() ![]() ![]() ![]() One hour to print that part, had to slice it in half due to printer size , then just glued together. Having the printer is nice because I can make a physical part that I can wrap my brain around to see just how it is going to fit/work. And basically penny’s worth of material. Verses making it in machine and realizing a change is needed having to make a new one. I’m still fighting with my old habits of keeping everything in my head verses using the computer and knowing it will work 99.9% of the time. . Ya can take me out of the sunlight but my neck is still red!! Lol!!! I wouldn’t know what to do if everything fit correct the first time .
#2254
I also like your homemade daddy longleg
#2255
Lol!! That was some brass soldered together to hold the master tire when I gave it an acetone bath (vapor bath,about 30-45 seconds to smooth out print lines and sanding marks). Then I bent it up and told the wife I made her a hair brush,,, She wasn’t impressed!! Lol!!
#2256
Or better yet bo,,, a real live brain sucker,,, attached to the cat!!!
![]() ,,,,,, I know ,,, stupid cat picture,,,,,, and just for the record,, all animals are harmed in the pictures!!! . By the brain sucker!! Cat lived but it’s dead!! Starved to death!!
#2257
Paint it black and put it as the shopguard
I'm trying to teach my wife to run the lathe and make super wide rims........she isn't impressed ether........why ?
#2258
Squeeze that fist...............
Not ! |
#2259
![]() Back to work,,, top half of tire mold poured. Have to wait till tomorrow to take apart and cut casting holes and cast first tire. Have an idea of how much black pigment to add from making the haul truck tires. But not exact. Hopefully I nail it on first one cuz material ain’t cheep. And I’m casting them a solid tire shore hardness of 40, same as haul truck tires. Too much work to make them hollow verses cost savings.
#2260
And just for those that don’t know , fat malbert is the shop help (well helpless) and he is happy I’m not into rc airplanes ,,,, he is well taken care of and not harmed! (Yes being politically correct and don’t want to post ill-information)
A video of fat malbert , doing his favorite thing, being lazy and transported!! https://youtu.be/l-lHh47xXgY
| Currently Active Users Viewing This Thread: 25 (0 members and 25 guests) | |
