Old 03-16-2011, 12:44 AM
Default tanks for using as starting point for cranes ,tractors or even half tracks
has any one else seen this tanks ?
http://www.raidentech.com/meuptrbbaita.html
most are under $150 dollars us
going to try one as a bottom for a yarder
Old 03-16-2011, 10:02 AM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Default Re: tanks for using as starting point for cranes ,tractors or even half tracks
They are nice start for the tranny's and electronics but the drive sprockets and track links do not fit any of the construction vehicles that I know of.
Lynn
Old 03-16-2011, 10:20 AM
How about a yarder that was built on a Sherman tank that was on that logging show a couple years ago.
Old 03-16-2011, 12:54 PM
tc1cat's Avatar
Super Moderator
My bad I found a pic of a yarder made from a late Sherman running gear. Only problem with it would be the cost of the chassis. Tamiya Shermans are not cheap- most over $400. If someone used a late Sherman chassis, then there has to be one made from an early chassis. Early Sherman models can be had for around $150 if you can find one!!
Lynn
