#121
Nice solutions on the drive. Wish I built smaller so servo could be used. Maybee some day....
Servo city, is that a supplier?? Dan |
#122
Yes, Servo City has some nice unique servo related items that you can't get/find anywhere else. Adapters, sprockets, reduction units, aluminum arms...
#123
Looks very good Scott, you will have more than enough power there. Do you need a speed control , as the servo has it already ?
greg |
#124
Thanks Greg.
You are correct there are no esc's needed, all of the servos just plug into the receiver. The undercarriage electronics will consist of 2 servos, one receiver and a battery. The cranes main electronics will consist of 4 servos, one receiver and a battery.
#125
Well, since I am waiting for parts to build the undercarriage I made a large bucket so that I could load trucks faster at the meets when we use ground up rubber.
![]() Its really too big for actual dirt but, I had to load the Mack up a couple of times just for the fun of it. http://www.youtube.com/watch?v=xtjl5kGhRhc
#126
SmallHaul-looks to my like it handles that bigger bucket pretty good!
#127
I like the quick change system on the backet. Cant wait for more!
"My son will have a chocolate milk" -J.P. Next East Coast Minitruckers Meet: Arioch |
#128
hehe one for show and one for GO GO GO! lol
#129
Yep, it seems like we can never load all the dump trucks fast enough at the meets.
#130
![]() It'll take Steve's drag to load it With the big bucket the hoe works nice Scott IHSteve
#131
Well, I pulled this project back out and started working on it again. I am hoping to make the National Pike show and would like to have this finished for it (May 21st). The chain drive works nice and has plenty of power. It is going to be cool to get the chain rotate setup, it should work smoothly.
Here is a video of it working: http://www.youtube.com/watch?v=ft1fAnn2sIA
#132
Scott. The car body works very nice. When the upper is on there and you have cleats you should be able to go anywhere. I'm surprised at the power the servos have.
Rob |
#133
Thanks Rob, I am a little surprised my self at how much power it has. I also dragged a 10 pound steel weight with it and it pulled it just fine.
#134
That's a cool little robot in it's self
. That won't have any trouble traveling up a pile of dirt. Definitely the "High Walker" version. You'll be able to do pipeline up mountains!
#135
What a neat project!
ServoCity are great, I use their adapters, too. Haven't had a chance to check their chain - good idea. I assume this is the plastic chain here: http://www.servocity.com/html/chain.html |
#136
I couldn't get their servo splined sprockets to work though. They were very helpful trying to help me (GREAT customer support) but, every sprocket they sent me grabbed the chain badly. The only way there sprockets would work smoothly is if the chain only wraps around a small portion of the sprocket. I said to them "simply wrap the chain around the sprocket and you will see that it is STUCK on there" and they just ignore the comment... the standard $3 sprockets I ordered from a discount chain work fine.
#137
Ah, sorry, I was confused! Need to learn to read
![]() Their plastic chain has a spacing of 0.1227, so I thought you meant this. """" Turns out the #25 chain I am using has a smaller roller diameter (.120) than they use (.127) which would explain why my chain binds up when you wrap it around more than 100 degrees or so. They are sending me some of there #25 chain to rectify this. """" But what you wrote is that it's the diameter of the rollers that is different. Never heard that before. However, using a chain with smaller roller diameter on a sprocket designed for a larger diameter should work, I would guess. (Never tried it, though.) Thanks for the heads-up, will have to remember this... |
#138
Got a little more done. The chain drive for the rotates is finished. I maybe over engineered it but, I wanted it to be strong so that I could push dirt sideways with the bucket on occasion and not worry about anything breaking.
#139
#140
This may be a silly question but what are the black wire leads going into the track frames? Are the drive batteries between the rails?
It sure works well on rotation and looks to have a good speed on the tracks
