#161
Hey Steve, That's outstanding, don't worry about the camera. So in scale lbs? how much weight will they handle? Keep the the great work!
Later, Neil#2 aka doodlebug. |
#162
Neil the truck is a 75T compacity I'm guessing the rears , from what I can see on the brochure , in excess of 100,000 # these < I can,t put enough in the box to max them out . I'm guessing 200+# the tires will flatten till I get that much on it .
#163
Very nice work Steve. I just got one of those differentials today to play around with. Might be a little big for my application though. Really nice detail with all the bolting of flanges on the pinion and the bearing caps on the beams.
#164
Incredible so far
#165
Just great!
kerst |
#166
WOW!! I forget to look in on this build for a few days and you go crazy with it! Those axles match the tires and wheels perfectly. Glad to see you have the mill and lathe programming down pat.
Can't wait to see what is next
LYNN |
#167
thanks guys
Lynn , I hope you can make it to york this comming jan. You'll get to see it in person working with some coal wear on the box by then .
#168
Thank's for the info Steve, Still learning how much weight, the scale stuff will handle.
#169
Looks great! Are you going to use rubber bushings between the frame/walking beam and walking beam/axles?
#170
amazing work, this truck is going to be one tough rig. great milling skills. wonderful detail
#171
Awesome work Steve!
#172
WOW !
Looking forward to see your truck working in the pit, great build.. greg |
#173
![]() I got rained out today so I put the mack hubs on the mill while I did other things lousy pics again ![]() ![]() ![]()
#174
IH Steve-you are doing some really nice work there and this should be a great truck!
#175
Sweet! This cnc'ing is quickly becoming a naturally ability for you Steve. Well done on the logo.
#176
Nice looking work.
Jeff Last edited by pugs; 10-14-2011 at 11:31 AM. |
#177
thanks Jeff ![]() I finally made the pivot hanger for the rear boggy . I milled it out of 3.5 X 3.5 Alm bar . I'm a little to show the pics . If I have luck ( ha ) I'll be driving it around by next couple weeks Pics ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I always need more tools so a new cam takes a back seat ![]() ![]() ![]()
#178
Looks great Steve. I have seen this thing in person and the pics don't do it justice as to how big this truck really is. The center sections of the rear axles are as big as a pop can. We need to get Steve to take some pics next to a recognizable object that most can compare the size to. Not to mention this thing is a piece of art.
![]() Travis
AKA "00" Biddle RIP FreddyGearDrive 2-12-59/12-19-11 |
#179
Looking like you got the hang of machining pieces that look like castings. Kinda reminds me of some of my parts.
#180
![]() I took a couple comparison pics next to lil puppy and some 988 oops I mean mammoth tires ![]() ![]() ![]() ![]() 1 of my legthining of a punisher shaft if you can see it ![]()
| Currently Active Users Viewing This Thread: 4 (0 members and 4 guests) | |
