#201
Kinda off/on topic, as I'm sitting here in my cab with the radio and a/c on, it jus hit me, it would probably be cheaper(not including cost of machine) to turn this machine into remote control, everything except throttle, and on/off runs through joysticks, a 14 channel radio would cover it! But I think that would be pretty awesome, but nit sure if it would fit in my garage!
#202
If you ever have camera with you, I would be grateful if you are able to take some photos of the machine, mainly on the back wall of the cab.
#203
I'll grab some shots tomorrow and try to get them uploaded or sent to you, I want tonsay most of the stuff back there is A/C stuff, but no problem!
#204
This build is insane! I can't get enough of it. The level of detail is so incredible. A true matster piece in the making. I have to agree that it will almost be a shame to paint and decal this machine up, as it is a work of art!
Nathan |
#205
Back of cab shots[IMG]http://i1190.photobucket.com/albums/z451/Johnboyee/54184271.jpg[/IMG
![]() ![]() Steps on newer blades ![]() Light bar on newer ones
#206
Best one didn't post first time
![]() Also CAT went back to an I-beam front frame piece instead of tubular due to cracking issues .. |
#207
johnboyee, great pictures. Many thanks
#208
Ari,
Do you know of a source for the step material that you used? Hopefully, on this side of the "pond"! Need some no matter where you got it from ![]() Thanks in advance.
LYNN |
#209
it´s the number 2639 on that page. I have no idea is it available on your side of the pond, but I´m sure you can get something similar there.
#210
I made some details to the back of the cab, I will add some more hoses there.
Many thanks to johnboyee from the detailed pictures of the real machine ![]() ![]()
#211
Just amazing.
Jeff |
#212
This is one amazing build, respect!
#213
nice details, Ari.
Did send you a pm Dan |
#214
Great details! Cant wait to see this in action!
#215
That's just takes the cake, great detail, glad I could help...
#216
I started to decorate the cab
#217
You are a crazy man!
#218
I test fit the valve block and the pump to the grader, and they seems to go in wihtout any problems. I will add second valve block in front of the other and they go so low I can add pump over them and there still over 2 inch clearance to the hood.
#219
Ari, just a quick suggestion. Loosen the set screw that holds the motor to the the pump and turn it 180 degrees to the bottom. That way if there is any pump leakage it will drain out the hole and not gum up the motor. Thanks for showing us that just about anyone can build this caliber of model with just a small shop. Well Done.
Rob |
#220
I found myself starting from the beginning of your thread once more, today. I just can't over how much talent you have, to create a machine like this. We can't even call it a model because it's not. It's a true, functional, working machine, but on a smaller scale. Unbelievable! What a masterpiece. I think even some the best model builders on this site can't help but be humbled, when they view your thread!
Nathan |
| Currently Active Users Viewing This Thread: 6 (0 members and 6 guests) | |
