Old 01-06-2012, 12:59 AM
Default Re: PFB Tri-Axle King Hauler
What's the spec's on that motor?
Old 01-06-2012, 02:21 AM
pigeonfarmboy's Avatar
I've put a fair amount of stress on these ring and pinions before. I know they'll fail eventually though.
Specs on pullers:
You can't find a more powerful brushed motor in this class. You get insane wheelspeed, more torque than any 540 motor, and the finest slow speed control. All in one motor. 7 slot armature allows for better throttle resolution with a high motor speed.
Recommended lipo battery-
6t- 2s only. 40a continuous
7t- 2 to 3s (3s may result in overheating). 45a continous 11.1v use, 35a continuous 7.4v use
10t- 2 to 3s. 40 amps continuous 11.1v use, 30 amps continuous for 7.4v.
14t- 3 to 6s. 35a continuous 22.2v use, 25a continuous 3s use
Slightly longer than a standard 540 motor. Uses standard 1/8" pinions, and 25mm motor mount spacing- bolts up like a normal 540 motor. **Some stock uses 4-40 mounting screws that are included**
Super Strong cobalt magnets
7 slot armature
6.9 ounces, 200g
2.5" long, 1.35" diameter
5-10 volts
160*F max
6t- TBD
7t - 2800 rpm/volt
10t- 1800 rpm/volt
14t- TBD
Old 01-06-2012, 04:03 AM
You should just go ahead and give this truck a powered front axle. I think you'll like having it, and it would raise the front bumper up a touch. You might not even need to mill it. If it's worth building, it's worth over building!
Old 01-06-2012, 11:24 PM
hvy 1ton hvy 1ton is offline
hvy 1ton is on a distinguished road
Originally Posted by pigeonfarmboy View Post
Should have known to look on his channel. Love his vids. That thing would probably be pretty simple to make too. Much easier to hide a winch than a screwdrive lift.
The winch isn't a required bit. The guys up north use winches to pull the trailer up the ramps to save the driveline in less than ideal conditions.
Old 01-09-2012, 09:42 PM
kcjeepn's Avatar
kcjeepn kcjeepn is offline
kcjeepn is on a distinguished road
Very nice rig!!!!!
Old 01-10-2012, 08:53 AM
crawler07 crawler07 is offline
crawler07 is on a distinguished road
great looking rig man.
Old 01-10-2012, 05:59 PM
CustomClod CustomClod is offline
CustomClod is on a distinguished road
I like it! Keep the sleeper off. Looks better!
Scott
Just my opinion
I run a single stack Mack with a dump body on the back!
Old 01-10-2012, 11:35 PM
Bsorenson79's Avatar
Originally Posted by Claus View Post
Here is something to shoot for. This is a "beam" or a "rail" lowboy the deck is just frame rails that are set in narrow, you drive the excavator over the rails straddling them, the whole thing sits lower this way.
Can anyone pick out what is weird about this picture???
Old 01-10-2012, 11:37 PM
YoungGunz's Avatar
Got dish?
Old 01-10-2012, 11:41 PM
Originally Posted by YoungGunz View Post
Got dish?
BINGO!! What is up with that?
Old 01-11-2012, 01:12 AM
Maybe it make's it "GO FASTER" LOL!
Old 01-12-2012, 04:06 PM
SWAGGER's Avatar
SWAGGER SWAGGER is offline
CAT TV?
Old 03-03-2012, 11:11 PM
CHEVYHD496 CHEVYHD496 is offline
CHEVYHD496 is on a distinguished road
this truck is awesome. im a big fan of tri-axles! just wondering, but i was wanting to get new frame rails for my KH and wanted to know what height yall are using? im gona buy aluminum C-channel. thanks
Old 03-11-2012, 04:36 PM
Just buy some from GardenTrucking.com
Old 03-14-2012, 03:43 AM
Got some work done on the rig tonight.
Here's the mount I came up with for the R2HD trans:
It's only mounted to one side so I thought I was going to have to brace it to the other side frame but it feels pretty solid.
00 Biddle KDub grill!
Old 03-14-2012, 08:50 AM
Tamiya Cowboy's Avatar
YEEEEAAAH BUDDY! That motor will do the trick I have one in my tri axle and she pulls like a champ.. I am glad I got a few before they stopped making them.
Paul W. "Tamiya Cowboy"
Old 03-14-2012, 03:25 PM
Thats a pretty nice trans mount! Looks beefy. I'd build another for the otherside, if it was mine, but sometimes when you are making parts like this, by hand, you're lucky if the holes come out where you want them, and they line up the first time! It becomes a question of you deciding if you really feel like making a copy of the same parts!
Old 03-14-2012, 05:35 PM
Theres no mounting holes on that side of the trans. Would have to tie a bracket in from the top. Problem with that is the top of the trans already hits the interior floor. Would like to keep that in tact if possible.
Old 03-24-2012, 10:42 AM
Izzy's Avatar
Izzy Izzy is offline
Backyard enginier
With that frame support just behind the trans I think you will be OK - at least untill most everything else is mounted up. Why not poke some holes in that other side? you would have to take it apart to clean up the shavings and such though...
Old 03-24-2012, 09:57 PM
Why is Izzy always wanting to poke holes in things? Weirdo...
