#41
Thanks! i may have Brian make me some with the right curves so its one piece and not going from big to small.... not sure yet. Right now Im using Russ's bull pipes. Quote:
go from 25" to maybe 30" hmmmmmm
#42
Well Since the wife put a temp freeze on part ordering for a few weeks i took some brass that i had laying around and decided to try a few things. Im quite impressed with what i came up with so far. I decided to try making some air cleaners with what i have around the house and here is what i did.
Started with 3/4 copper plumbing and a thin sheet of brass ![]() ![]() Rounded the sheet brass out and limiting the solder lines ![]() ![]() Took some brass tubing and Chair leg bottom. and came up with this ![]() ![]() ![]() Used some double sided tape (for mock up only will be soldered on) ![]() ![]() ![]() ![]() I just need to make or find something to cap off the bottoms, and solder them on. Since the rack and aircleaners are going to be painted I decided this route as i couldn't cover Russ's sweet work with paint... There are so many thing i still need to do. Including new front bumper, rear bumper, more cab lights, side lights, new stacks (taller and angle cut) fenders, paint, and poss a longer frame still.... hmmm there still may be more then that yet to do... hope you like the update. |
#43
Hi dabears,
great job. It´´s looks really good. I like this truck.
Live is too short to drive an ugly truck The Facebook-Site: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#44
Thanks! I'm still plotting more changes before I can strip and re paint. Then I get to re do the trailer
#45
The breathers and big exhaust look right at home. great job!!!
![]() ![]() ![]() Big John
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. YOU WANTED THE BEST AND YOU GOT THE BEST THE HOTTEST BAND IN THE WORLD...KISS!!!! |
#46
Amazing what can be made at home with bits and pieces lying around. All you need is a good idea. Well done DaBears, great work.
Never judge a man until you have walked a mile in his shoes. Then, when you judge him, you are a mile away and you have his shoes! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#47
Nice job on he breathers. I think you need to put the scoops on the top though.
Brian RIP FreddyGearDrive 2-12-59/12-19-11 |
#48
you talking about the snorkle like scoops? Like you see on the aussie trucks?
#49
I think your intakes turned out very good! Scoops would be cool, but I really don't see them all that often. Seems to me most COEs have a cap, just like you modeled. Nice job.
Nathan |
#50
I concur!
#51
Hmmm that may be incorporated as you don't see them as much...
So as I was soldering the breathers to the rack one of the joints came lose from to much heat and us all crooked and messed up looking now...... So I have to either undo it and rebuild that one and hope it works the second time around or re-think the design a little.change it up with materials, maybe I'll use styrene for it all... I'll post pics of how it turned out tonight when I get home from work.. |
#52
I learned that when you get to the point of having a lot of soldered joints near where your soldering you need to use heat sinks, in my case on the headache rack I used a bunch of vise grips because it was all I had at the time. If you use them put a very light pressure on the part, as the brass gets hot it gets soft, to much pressure and you'll leave a small indentations.
#53
Another option for you might be to simply bolt the breather canisters to the rack instead of soldering them. That way you can paint them separately, and replace them, if you ever need to.
Nathan |
#54
Both those options would work. I'll have to pick up some more vise grips and try that. If that doesn't work I'll go by a tap and dye set to thread the holes needed. If those don't work right then I'll have no choice to out source that part of the build lol.. Still need to figure out the rear frame slope, or notch like I call it..
#55
Some of John's (Stylin-N_Profilin) stack and elbows would look great on there, either miter cut or bull pipes!
Nice build you have going there for sure. |
#56
Got some supplies on my lunch to re make the breathers
#58
Ok so as promised i putting the pics of how the breathers turned out when soldered to the rack. so heres what happened
The left one is the one that came undone while soldering as you see here ![]() Tried to fix it and this is how it is now ![]() Im kinda a perfectionist so i dont like it and will be re doing it again. So when i was tearing the truck down again i noticed something i didnt before. my back wheels although the same are not the same... 2 are 6 lugs and the other 2 are 8 lugs... the fronts are 8 lugs.... YIKES!!! but they are getting swapped out to chrome ones anyways as it will bother me having that difference!!!![]() Got the holes drilled for the lights on the trailer, just gotta figure out how to wire them ![]() made mirror brackets ![]() And re cleaned and organized my cave where i do it all in ![]() ![]() Thanks for looking and all the great comments!!
#59
Nice mirror hoops!
Thats the way to go, a bench for the trailer and one for the tractor, Works for me.
#60
i could prob work on 3 trucks and 2 trailers each in its own spot... its not a big room but its well layed out! (just the other half holds the mess from this half.... still working on that haha)![]() ![]() ![]() Thanks on the mirror hoops... the licence plate holders i carefully cut off the front bumper are decent for the actual mirrors but those will be glues on after its all repainted!
| Currently Active Users Viewing This Thread: 7 (0 members and 7 guests) | |
