Old 08-19-2012, 08:33 AM
Madda Madda is offline
Default Re: CAT 374D L
Yeah slip ring is one of the easiest and best solutions. Some guys make their own custom solutions so I thought I would ask.
Have you started making the tracks? It is probably one of the most pain job to do.
Are you going to use Sabertooth ESC? If not then I recommend it, best solution for tracked vehicles, I'm very pleased with mine.
Old 08-23-2012, 12:47 AM
love the Detail work looks exactly like the real thing look forward to seeing the finishe product
Old 08-25-2012, 06:40 PM
hey guys the 374 does not have a sliding under carriage I am a heavy equipment technician and CAT is the majority of the equipment I work on it has a fixed undercarriage but all in all I think the model looks great and the site is great as well you guys are very talented
Old 08-26-2012, 11:40 AM
I think you are wrong about that, if you look at the picture of 374 on a low loader couple of pages back, you can see how the x-frame is sticking out on the side and the tracks are much narrower than normal. Also the Cat 374 brochure talks about the variable gauge undercarriage. But I also believe that not all of the 374 are equipped with the variable gauge undercarriage.
Here's some progress I've made. Got the swing bearing done
Old 08-26-2012, 11:50 AM
looks great Ari now where did you find that gear ? I've been looking forever for the right size .
Old 08-26-2012, 12:02 PM
Got the gear from HPC gears: http://www.hpcgears.com/
Old 08-26-2012, 01:08 PM
thank you Ari
Old 08-26-2012, 01:23 PM
CAT315C CAT315C is offline
CAT315C is on a distinguished road
If you write for HPC, they will send a Catalogue (book) with all their products and the references thereof.
I requested the book and I was sent.
Carlos.
Old 08-26-2012, 02:21 PM
hmm... so what is the length from center pivot to the bucket teeth in this picture (or what its reach @ ground level)?
The 374 is progressing beautifully Ari... but have you been spending any time with the grader outside this summer? Need more eye candy of that machine in motion, plz!
Old 08-26-2012, 04:44 PM
Once again Ari, you've excelled yourself. It looks stunning - When you taking orders
Technical question from a dumb *** ( me )
Shouldn't the super structure sit on a thrust bearing or can the bearing you fitted take the heavy load from above, ie side load??
Elliot.
Old 08-26-2012, 05:36 PM
Looks to me like you're just stalling off on building those track pads.
Looks great!
Old 08-27-2012, 03:24 AM
rc4ever rc4ever is offline
rc4ever is on a distinguished road
What a great model!!! I'm just speechless!!! I've learned a lottt from y'all. My MASTERS!!!!
Old 08-27-2012, 11:15 AM
It's not a dumb question Elliot, I was thinking that myself but I think they will hold. If necesary I can attach bronce ring under the upper structure that will rotate over the ring gear. Those thrust bearings tends to be too high and they
Old 08-27-2012, 12:26 PM
Has bearings and ball dual layers also have roller bearings that may come to serve for the application.
Carlos
Old 08-27-2012, 12:29 PM
The length from center pivot to the bucket teeth is 95 cm.
And what comes to the grader I have used it few times but didn't have my camera with me
Old 08-28-2012, 12:52 AM
Jared Jared is offline
Wow this is great! I was real interested to see how you did the swing. I think the dual ball bearings will be fine. My milling machine has a similar arrangement for the spindle bearings to keep the spindle from moving up and down and it can spin 3250 rpm.
Old 08-29-2012, 12:18 AM
Great job so far,
I don't think you will have any trouble, with your swing bearing setup!
Cheer's, Neil.
Old 09-02-2012, 10:49 AM
I couldn't make any more excuses not to start making the tracks so I started with the track links. I managed to make about 100 which is half of them. And there's still few a stages to do before they are ready. It's going to take some effort before tracks are finished
Old 09-02-2012, 12:13 PM
fun , is it not ? I'm getting ready to run 400+ of those in aluminum then 160 in steel . I'm just trying to get the track pitch right for the 400+
Old 09-16-2012, 06:33 AM
Finally got all track links done. I had to make a fixture for machining the other side and also for reaming the track pin holes.
It's hard to believe that I used almost 2 meters of 100x6 mm plate for the 200 links. I use to thing that factory made tracks are expensive but as I proceed with these they begin to feel cheaper and cheaper...
I also started to make the track pads but didn't got very far before I broke my last 3mm radius cutter
